Old 10-23-2012, 09:43 AM   #29
2010 27' FB Flying Cloud
Catawissa , Missouri
I appreciate all the opinions expressed on this topic. I will be winterizing my rig this afternoon, and I think I will opt for the blowout AND antifreeze approach. The cost of a couple of gallons of antifreeze will buy me lots of good nights of sleep this winter.
Thanks to everyone for being so helpful...
FredV is offline   Reply With Quote
Old 10-23-2012, 01:44 PM   #30
1988 32' Excella
Robbinsville , New Jersey
Originally Posted by FrenchBern View Post
Doesn't anybody drain the antifreeze out back into the container for reuse after pumping it through the plumbing? That way I use less than 2 quarts every time.
I have thought about that but I worry about the antifreeze getting watered down too much to be effective.
Old 10-23-2012, 04:04 PM   #31
noreen&sal's Avatar
1981 27' Excella II
mays landing , South Jersey
Does anybody take a plunger and try to evacuate the traps before adding the pink stuff? Sal.
Sal & Nora
Let us live so that when we die even the undertaker will be sorry. Mark Twain
AIR 42483
TAC N.J. 17
WBCCI 24740
noreen&sal is offline   Reply With Quote
Old 10-23-2012, 07:07 PM   #32
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
I used to take a shop vac, reverse the hose and blow out the traps. Then I'd pour in some antifreeze. I quit doing this due to I expel enough antifreeze from each of the fixtures to displace the water in the traps. Usually I also have enough left to pour directly into the drains also. I use about 2 gallons total to winterize. You'd be surprised how little it takes once you blow out the lines first.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 10-24-2012, 04:14 AM   #33
noreen&sal's Avatar
1981 27' Excella II
Jack
That is my usual method. The shop vac idea sounds good. I was just wondering how much it took to displace water in the traps. Sal.
Sal & Nora
AIR 42483
TAC N.J. 17
WBCCI 24740
Old 10-24-2012, 06:44 AM   #34
jcanavera's Avatar
Fenton , Missouri
Images: 143
I'd wrap a rag around the shop vac hose to make a good seal in the drain. It took a couple of seconds in each drain. You can hear the water leaving the drain.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 10-24-2012, 08:34 AM   #35
noreen&sal's Avatar
1981 27' Excella II
Jack
Thanks for the tip. Hoping to hold off til around Thanksgiving and maybe get a short camping trip in before then. Sal.
Sal & Nora
AIR 42483
TAC N.J. 17
WBCCI 24740
Old 10-24-2012, 09:02 AM   #36
SilverRanger's Avatar
2005 19' Safari
1968 24' Tradewind
Rural , Delaware
Originally Posted by CLDuthie View Post
Not sure if this is the way to respond and/or aska question, but here goes. I up-rooted the closet floor of my 2007 Classic 27FB (new to us) and found the water pump. However, it is located such that the inlet is only about two inches from the wheel well cover - not enough room to install a flush kit attachment. How did you make your adapter? dana
Sorry I didn't see your question until now. Been traveling. I may have more space to work with, but I attached my suction hose to a PEX swivel elbow. I found some plastic hose that just slipped on the fitting by hand, and the fitting can also be attached to the pump by hand. That works fine because there's no pressure, only suction. It only protrudes from the pump fitting less than an inch and a half. Pictured below:
Name:	PEX Elbow.jpg
2005 Bambi
1968 Trade Wind
2007 Ford F250 4x4 Crew
WDCU
SilverRanger is offline   Reply With Quote
Old 10-28-2012, 05:49 AM   #37
2009 20' Flying Cloud
Carlisle , Pennsylvania
OK - Until this year, I've only blown out the system to winterized, and have had no problems. You folks convinced me to pump antifreeze through the lines this time to be safe -- I.e. blowing out the lines works...until it doesn't. All drain valves shut and hot water tank bypassed. I left the water filter under the galley sink in place (will use only for winterizing from noe on of course). No problem getting pink to flow through all faucets, stool BUT... The filtered water tap in the galley continues to flow clear after 3 gallons of antifreeze! Could the filter be removing the color and the antifreeze is actually doing it's thing? Excuse the stupid question, but I can't be the first to experience this...or am I?
Ty Trainor is offline   Reply With Quote
Old 10-28-2012, 06:03 AM   #38
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
Ty, sounds like you are pumping into the fresh water tank. You have the bypass on the wrong side of the pump. 1 or 1/2 gal. of antifreeze should be enough.
Gene
Old 10-28-2012, 06:28 AM   #39
Gene -- thanks but the fresh tank is disconnected. Am using the inlet side of the pump with the antifreeze.
Old 10-28-2012, 09:35 AM   #40
Silver Goose's Avatar
2008 27' Classic FB
Burkburnett , Texas
Originally Posted by Ty Trainor
... I left the water filter under the galley sink in place (will use only for winterizing from noe on of course). No problem getting pink to flow through all faucets, stool BUT... The filtered water tap in the galley continues to flow clear after 3 gallons of antifreeze! Could the filter be removing the color and the antifreeze is actually doing it's thing? Excuse the stupid question, but I can't be the first to experience this...or am I?
I've seen an ad on tv where they add some red wine to water in a pitcher and what comes out is clear. The filter cartridge in mine is supposed to be good for 400 gallons of water or 8-12 month per the package. As part of my winterizing routine, I toss the cartridge and put the empty housing back on and remove the 2 AA batteries before running the pink stuff through the system. In the spring, after purging the pink stuff, I put in a new cartridge and batteries.
AIR 47751
Air Safe Hitch, Reese Dual Cam 800#, Centramatics
Silver Goose is offline   Reply With Quote
