Old 10-06-2015, 08:22 PM   #15
2003 31' Classic
Terra Alta , West Virginia
The small airport hangar is a great idea. That's what I have done and they appreciate the extra little revenue. I live in a rural area and that probably helps the rate and availability. Most years we have about 200 inches of snow so it's nice to see our baby under roof. When getting heavy snow I always hope the hangar roof is strong! So far so good. Maybe someday SOUTH for winter.
Dave in northern WV mountains and not looking forward to winter!
wvstreamer is offline   Reply With Quote
Old 10-07-2015, 10:19 PM   #16
NWRVR's Avatar
2015 30' Classic
Sherwood , Oregon
Originally Posted by AKJohnson View Post
Thanks. Do you know how much space there is between the air conditioner and its cover? AK
Good question, does anyone know the answer for the new Penquine II low profile A/C? I also need a few inches to get under the header on my garage door.
2015 Classic 30A, Blue OX Sway Pro, 2016 F350 4x4 Ultimate Lariat crew cab SRW, LWB, 6.7 PSD, 20" wheels, Ingot Silver Metallic, DiamondBack tonneau cover, TrailFX wheel-to-wheel step bars.
Sold: 2014 25FB International Serenity
NWRVR is offline   Reply With Quote
Old 10-07-2015, 10:28 PM   #17
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up
Let some air out of the tires.....
PFC
"Tahawus"
RLC
Step aside Starbucks, this is a job for alcohol.
Old 10-08-2015, 05:51 AM   #18
paiceman's Avatar
Upper St Clair, PA/Titusville, FL , PA-Summer/FL-Winter
When winterizing if you have an outside shower don't forget to purge the water from that line as well when blowing air thru the system.
SAFE TRAVELS
Bud
2017 30' Classic - F350 6.7 Diesel Crew
USAF - Military Training Instructor (TI) - 68-72
Old 10-08-2015, 08:14 AM   #19
Mission , Texas
Some put them up on jackstands so the axles are unweighted, then let some air out of the tires and block the sun.
nrgtrakr is offline   Reply With Quote
Old 10-08-2015, 08:04 PM   #20
Ohiobrits's Avatar
2015 27' FB International
Howard , Ohio
I took the cover off the AC to fit a cellular antenna on top of the cover. There is not much extra clearance with the cover off, maybe 1-2"? If you are that tight I'd be concerned about any slope or uneven ground on the approach causing the rig to be higher than expected at the wrong time. Maybe take the cover off then let some air out of the tires as suggested here. The cover is very easy to take off, 4 phillips screws. Its light and easy to handle. You should be be able to get to them all with a tall ladder from each side - be careful!
2015 27FB International Signature "Danielle"
ProPride / 16" wheels / 600W solar / 864 AHr Lithium
Victron MultiPlus Inverter / BlueSolar / ColorControlGX / BMV 702
Porsche Cayenne Diesel
Ohiobrits is offline   Reply With Quote
Old 10-08-2015, 08:46 PM   #21
NWRVR's Avatar
2015 30' Classic
Sherwood , Oregon
Thanks Ohiobrits, I thought as much since Dometic was going for low profile. I have already calculated lowering by defeating tires and removing tires to place drums on dollies but it appears I will have to go with plan "B", cut a 8" high slot in the garage door header.....
Old 10-08-2015, 10:53 PM   #22
Long Island , New York
[snip]
. . . but it appears I will have to go with plan "B", cut a 8" high slot in the garage door header.....
Will this leave enough structure in the header for it not to sag, or even fail?
OTRA15 is online now   Reply With Quote
Old 10-10-2015, 07:58 AM   #23
NWRVR's Avatar
2015 30' Classic
Sherwood , Oregon
Yes, the header is only for the 18' garage door. Before making the cut, I will tie the opening ends back to the double top plate and hinge the opening block to swing out of the way when moving the AS in and out of the garage.
Old 10-15-2015, 10:08 AM   #24
2007 20' Safari
North Brookfield , Massachusetts
Hi, we just had our 2007, 20' Safari LS winterized at a local RV dealer for $80. We figure money well spent as this is our first AS and don't want to ruin it. Little did we know there was water in the fresh water storage tank. We never needed it and would have been in trouble if we had winterized our selves. We have made arrangements at the local fair grounds to store her inside one of their huge building for the winter. Great deal. Check out fair grounds in your area. Good luck. SisterK
SisterK is offline   Reply With Quote
protecting the fresh water tank? sugarloafin' Fresh Water Systems 10 06-15-2007 10:07 AM
Protecting Bumpers SmokelessJoe Bumpers & Bumper Storage 2 08-04-2006 02:11 PM
Protecting the wood trim during the stripping. Chaplain Kent Cleaning, Stripping & Polishing 2 01-03-2005 12:07 PM
Protecting vista view shades Bluegirl Windows & Screens 2 10-31-2004 08:55 AM
protecting the radiator and other coolers PeterH-Airstreamer Airstream Motorhome Forums 18 04-28-2003 07:00 AM
