Old 11-05-2012, 05:33 PM   #15
2005 19' Safari
GLENDALE , AZ
See my comments in previous posts below:
* http://www.airforums.com/forums/f462...ml#post1096310
* http://www.airforums.com/forums/f368...ml#post1157482
Old 11-06-2012, 05:31 AM   #16
1965 22' Safari
California , Kentucky
Originally Posted by RiverRat View Post
Last year I winterized using the 1965 manual directions and all was fine. This year I decided to put RV antifreeze throughout the system and used a propylene glycol based pink antifreeze. I thought it was alchohol based and am worried about this stuff. Should I flush everything now and start over or can I flush the system in the spring? I do not drink the fresh water but use it to wash dishes. Also should i use a soap to flush the system or just fresh water?I would appreciate any suggestions. thank you
Well i feel better about having put the stuff in my potable water system.Think I'll go with the vodka next year although it will make a grown man cry to see it go down the drain. Thanks for all the suggestions..RiverRat
RiverRat is offline   Reply With Quote
Old 11-06-2012, 07:03 AM   #17
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
I think you did it correctly. I winterize my trailer by pumping it from the fresh water tank through the system. It flushes out pretty well in the spring.
Old 11-06-2012, 08:44 AM   #18
Alumaholic's Avatar
1966 24' Tradewind
Albuquerque , New Mexico
Images: 33
Thanks for the Thread, RiverRat
Thanks to you, I learned about Vodka from Rebee!
Whereas I once dreaded it, I can now look forward to winterizing!
Ken L
1966 Tradewind 24
2007Chevy Silverado 2500 HD Duramax/Allison
Four Corners Unit WBCCI #8654
Alumaholic is offline   Reply With Quote
Old 11-06-2012, 10:42 AM   #19
aftermath's Avatar
Spokane , Washington
Originally Posted by Protagonist View Post
If it happens again, try leaving the heating element turned off and just run cold water through it until the odor is gone. Heating the antifreeze is probably what caused the smell to persist.
I never turned on the HW heater during this mishap. I spotted the problem when I ran water through the heater. Like I said, there wasn't really that much pink stuff in there as I spotted the open bypass before the tank filled. I was surprised about the time needed to flush all this out. In an older tent trailer I would add the pink stuff directly to the FW tank and pump it from there. I never had trouble flushing the system. The only difference I could come up with was the metal HW tank. I had the smell and foaming water out of the HW tap for at least a month. Lesson learned.
aftermath is offline   Reply With Quote
Old 11-06-2012, 10:58 AM   #20
au_ee's Avatar
2007 31' Classic
Pulaski , Tennessee
Originally Posted by dznf0g View Post
No, you don't have to worry about a lot of hydrogen gassing and plumbing damage...IF you follow what I say in my first post. I NEVER suggested putting Clorox in WITH the antifreeze. I said to sterilize the system with Clorox AFTER flushing well with clear water. If the flushing is done correctly and completely any minute AF left would be so dilute so as to be virtually non-existent. I addition, the Clorox is being diluted to a few cups in 63 gallons of water. I have used this process for 3 decades and never had any gassing, ill effects, nor any plumbing issues of any kind.
That being said....DON't mix Clorox with the high concentrations of AF in your lines proir to flushing well with clkear water.
dznf0g, we too have used the same one you have described for the past 30 or so years and never had a problem. This is also the process described in many RV manuals.
Steve & Beth
TAC AL-4
AIR 22763
07' Classic 31, 11' Dodge 3500 Cummins
au_ee is offline   Reply With Quote
Grey tank for rear bath '66 TW. FreshAir Waste Systems, Tanks & Totes 15 02-13-2012 09:06 PM
Time for a new Black Tank Where to start? NicheVintage Waste Systems, Tanks & Totes 2 12-26-2011 09:25 PM
Fresh Water Tank Size and Gauges ednspace Fresh Water Systems 4 05-23-2011 08:19 PM
No black tank in 62 Tradewind tlsmit1 Waste Systems, Tanks & Totes 1 05-15-2011 04:53 PM
