Old 11-27-2014, 07:29 AM   #1
CLOUDSPLITTER "Tahawas"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up Polonis disc heater....
After 25 years this little bugger is still doing it's thing.....
Turned it on last night.
When I checked it this morning the unit was running on it's lowest setting, shortly after entering it switched up to compensate.
Can't vouch for the quality of the newer units but this one is terrific.
Old 11-27-2014, 07:31 AM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Agree, mine is a newer model. Works like a champ. Pretty amazing how much heat it puts out.
MICHAEL
Old 11-27-2014, 07:50 AM   #3
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
Bob, good to have you back on board.
The electric heaters with a fan work well in the Airstream. We use a newer version of this classic from Dyson, but works on same principle.
Doug and Cheryl
Old 11-27-2014, 08:05 AM   #4
Been 'on board' but very little posting...I doubt you'll see me posting on the.....“If your happy with what you're using......it's adequate.
If others are unhappy with what you're using......it's not.” threads.
vacuum power disc brakes trumpwer Brakes & Brake Controllers 3 05-14-2009 07:38 PM
Kodiak Hydraulic disc brakes thenewkid64 Brakes & Brake Controllers 1 07-06-2004 10:48 PM
Rear disc brakes mcneon Mechanics Corner - Engines, Transmission & More... 7 04-26-2004 09:58 PM
disc brakes overlander Brakes & Brake Controllers 10 01-25-2003 11:29 PM
Disc Brakes? J.Hemingway Brakes & Brake Controllers 2 08-22-2002 07:56 PM
