Old 02-27-2017, 07:20 AM   #1
FreedomRings's Avatar
1984 31' Excella
Naples , Florida
Pole Barn
Any suggestions on cost and how to build a single sloped basic pole barn. Want just overhead roof, no enclosures. My AS is 31', assuming would have to be 35'x 10'.
FreedomRings is offline   Reply With Quote
Old 02-27-2017, 07:51 AM   #2
Lily&Me's Avatar
Normal , Illinois
Might call Menards or another lumber source, give them your dimensions, and they can probably give you a pretty good estimate.
I think others here have also done something similar, so you might get a nibble from one of them.
Maggie
Old 02-27-2017, 08:28 AM   #3
RLS
RLS's Avatar
2004 25' Classic
Prescott , Arizona
Do not know about cost, but I would think 10' is not enough width. Maybe 12'. I'm planning for one and it will be 14' width.
Julia & Bob
W/ Deedee & Boo
AIR #30685
RLS is offline   Reply With Quote
Old 02-27-2017, 08:41 AM   #4
Mollysdad's Avatar
My friend had one built in Chiefland, Fl. for his fifth wheel. He had a company build it. They did it in one day! He'd have taken a month. My advice is to make it larger than you think. It is smaller inside and things like RV doors, walk around room, take up space. His is like you describe, except he added solar fabric on the sides. It's a scrim, came in big rolls, and it cuts down wind and sun, but allows ventilation. He only put it on the east and west sides and left the north and south open so he could drive through.
His is 40' x 16' (?) I think, and he left the floor sand. Concrete would be better I think. I think they are built in 8" increments. The supports are 8 x 8 rough sawn timbers, the roof is metal, and there are trusses.
Cost ran in the $5,000 range IIRC. Really nice looking in a country way.
Old 02-27-2017, 09:04 AM   #5
dznf0g's Avatar
Oswego , Illinois
I agree. I only built a pad, but in order to have enough solid footing for working, washing and ladder, I went 16'...and that is none too much.
-Rich-
Old 02-27-2017, 09:10 AM   #6
Rg416's Avatar
2017 22' Sport
Cohasset , Massachusetts
Check out Morton Buildings. Class act. Or other companies like them. Had a great storage barn I had them build at my old house and loved it. Unfortunately I didn't have an Airstream to put in it! Now that I'm getting one, I have no room at our new house to put a storage barn.
Rg416 is offline   Reply With Quote
Old 02-27-2017, 09:20 AM   #7
1977 31' Sovereign
Sunset Valley , Texas
I priced out the lumber and materials for a 14'x32'x12' at McCoys in Texas and they were around $1400. I would build myself so labor wouldn't be a factor. Fortunately I have a pole barn at my house but am getting ready to turn it into a workshop so I've been looking at other options. I also looked at ShelterLogic rv shelters, not certain about vinyl covering though.
Iansk is offline   Reply With Quote
Old 02-27-2017, 10:00 AM   #8
2016 30' Classic
Santa Barbara , California
Consider a metal carport
We built a SteelmasterUSA.com (30' long x 16' wide x 11' tall) trailerport for approximately $7K in materials and equipment rental. Took my brother and me a week to do.
https://2.bp.blogspot.com/-312JnsXpd...0/IMG_0517.JPG
DavidLawson is offline   Reply With Quote
Old 02-27-2017, 10:29 AM   #9
Rgentum's Avatar
2016 27' Flying Cloud
Woodinville , Washington
My last Spring's project: 12 x 12 x 32 for an AS FC 27 FB
Name:	Barn front.jpg
ID:	280576   Click image for larger version
Name:	Barn front corner.jpg
Name:	Barn back corner.jpg
ID:	280578   Click image for larger version
Alta & Richard, Seattle area --- WBCCI 8873
"Aurum": 2018 Ram/Cummins 3500
"Argentum": 2016 AS FC 27 FB
"BigDog": M Harlequin Great Dane, 150 lb
WL7Z --- NAUI --- WSBA
Rgentum is offline   Reply With Quote
Old 02-27-2017, 06:19 PM   #10
McDave's Avatar
2014 23' Flying Cloud
Fair Oaks , California
I have a Shelter Logic, 26X12 for my 23' FC. 3 years into it, the vinyl top is showing wear, and will probably have to be replaced in a year or so. I've already bought the replacement, because they had a sale I wanted to take advantage of. Even if I replace the top every 5 years, at $250 or so a pop, I'm quite a bit ahead at an initial investment of hundreds, rather than thousands of dollars. The shelter has proved to be durable, and has stood up well to the record rains we have had this year. I understand that Shelter Logic also has heavier duty replacement tops, which I didn't take advantage of this year because of the sale.
I agree with others about the width. 12' is the way to go, unless you're a much better trailer backer upper than I am.
McDave is offline   Reply With Quote
Old 02-27-2017, 08:19 PM   #11
Can of beans's Avatar
1972 31' Sovereign
Silverton , Oregon
My Dad and I built a pole barn here, 42' wide 36' deep, for our 31' trailer, and the 36' deep is just enough to walk in front of, the 12' wide bays feel a little narrow, but the trailer is scattered all over in there, so that doesn't help it feel any bigger. I'm positive I had less than 12K in it, I think it was closer to 10K if you have the room and the energy, I would build bigger. in the end they are mostly empty space, so a small one costs almost as much as a big one. except for the labor. If i had had more room, I would have made the last bay 12' wide as well instead of 6'. Someday I'll add a concrete floor but for now it's just storage.
"Daddy when's the trailer going to be finished?"
Can of beans is offline   Reply With Quote
Old 03-01-2017, 11:52 AM   #12
2016 30' International
Florence , Alabama
It depends what your end goal is, but a kit for a RV shed with aluminum legs and ribs, and galvanized roofing would go up a lot easier and should be much cheaper.
joshjack is online now   Reply With Quote
Old 03-31-2017, 05:26 PM   #13
Fr Jeff
frjeff's Avatar
1989 29' Excella
Oscoda , Michigan
That is exactly what I want!!!
Fr. Jeff
2016 F150 Ecoboost
1989 Excella 29
frjeff is offline   Reply With Quote
Old 03-31-2017, 06:45 PM   #14
Mollysdad's Avatar
My friend had a pole barn built for his fifth wheel.
It's higher than needed for an AS, I think he went 40' x 16'.
It cost him about $7000, but the company did it in one day and it's beautiful.
He then put a sun block fabric mesh on the sides (E&W). It stops 80% of the sun's rays, but allows the air to circulate. It also keeps it much cooler inside. The rolls were 8' wide so it's stapled to the posts and then a thin wood batten is nailed over that.
flag pole mounting and flag pole in general chrischarles General Repair Forum 42 08-09-2017 02:05 PM
Pole Barn RV Garage? Utah Man Winterizing, Storage, Carports & Covers 65 04-23-2017 01:50 PM
rope and pole awning pole replacement link please greenrig Awnings 10 05-06-2009 12:52 PM
Empty Barn or RV Storage for winter? Mackhopp Winterizing, Storage, Carports & Covers 18 08-14-2006 07:11 PM
Airstream Model by Pottery Barn joe hall Off Topic Forum 7 12-28-2002 07:59 PM
