02-05-2014, 01:35 AM
2014 25' FB Flying Cloud
Fort Worth
Plumbing parts breaking....
Hello. I've got a 27ft FC FB. I live in one city for 4 days and work in another for 3 days. When I'm at work I live in my AS located in West Texas. This winter has been a huge PITA with the plumbing. It's gotten below freezing several times. 3 or 4 times now I've rolled into town and fired up the AS only to find 1-3 broken plastic plumbing pieces.
Every time before I leave I make sure city water is turned off and the WH bypass is opened to bleed off any pressure. Most importantly I leave the heat pump on and set to 60 degF. I would have thought that setting the heater to 60 would prevent any freeze damage to the plumbing.
Is it a false assumption of mine that setting the heater to 60 would prevent damage? I have no doubt that when it's REALLY cold the heat pump won't keep it at 60, but figured it would at least keep it at a non-freezing temp.
Several parts have broke, the most notable being the flush valve on the Dometic toilet ($50 to replace!! done it twice so far) and a plastic elbow in the PEX cold water line behind the shower valve. Oh... and my shower head fell off too...
It just doesn't make sense to me to fully winterize my AS due to the high frequency of use (antifreeze). Heck, I'de never get any work done because I would be too busy de-winterizing and then winterizing only to come back 4 days later and do it all over again... and again. etc.
Sorry for the long-winded post. Any suggestions?
02-05-2014, 01:46 AM
Salem
, Oregon
Hi, I believe that you should be using your furnace instead of your heat pump to keep your plumbing from freezing.
Bob 2005 Safari 25-B
YAMAHA 2400 / AIR #12144
02-05-2014, 05:38 AM
Figment of My Imagination
2012 Interstate Coach
From All Over
, More Than Anywhere Else
Originally Posted by holtenc
It just doesn't make sense to me to fully winterize my AS due to the high frequency of use (antifreeze). Heck, I'd never get any work done because I would be too busy de-winterizing and then winterizing only to come back 4 days later and do it all over again... and again. etc.
I've rewritten this reply three or four times already, and changed my mind about what to say that many times. Basically, it all boils down to, "I fail to see the problem." Those of us who live in a climate where it's practical to camp in winter, and to winterize/de-winterize multiple times in a season should count our blessings that we can use our Airstreams in winter. If the price for that is a little extra time at the beginning and end of the trip, that's a price worth paying.
I haven't been boondocking this winter; I've gone to campgrounds that are open year-round, and hooked up to municipal water. When I explain that I have a Pirit heated hose, the camp hosts have been perfectly willing to turn on the water for me even when the water is shut off at the mains otherwise. I de-winterize when I arrive at the campground and re-winterize before leaving the campground, so the process is part of the trip and doesn't detract one blessed minute from my at-home free time.
I've been camping five times this winter, and winterized three times. Two times, the trips were on consecutive weekends, with Weather Channel online 10-day forecasts showing no freezing temps in between, so I took a risk by not rewinterizing at the end of those trips. And got away with it. Otherwise I'd have re-winterized five times, and not had one single complaint about having to do so. It sure beats not being able to use my Airstream at all!
02-05-2014, 05:58 AM
2009 27' FB Flying Cloud
1982 31' International
1991 35' Airstream 350
Jay
, Oklahoma
The heat pump will quit making heat with the outside temperature is below about 35 degrees. So, the water left in the plumbing is freezing and breaking fittings.
Use a small electric space heater and as you leave, open the cabinet doors to expose the pipes to the heat. All the fresh water plumbing is inside the trailer routed behind and under the cabinets.
The holding tanks are all outside the heated space, so keep them drained.
We have put off winterizing our trailer between winter trips using this method several times without problem.
Regards,
Jeff & Cindy
'09 27FB Flying Cloud;'82 31 International
'91 350 LE MH; '21 Interstate 24GT
02-05-2014, 06:09 AM
Mantua
, Ohio
The heat pump will not keep the trailer from freezing, the furnace must be used! Keeping cabinet doors open will help circulate the warm air. The furnace sends ducted air to the holding tanks and will operate at any temperature. Using a space heater may defeat the furnace by not letting the thermostat get low enough to make the furnace run to keep the furnace from doing its job. Jim
02-05-2014, 07:57 AM
Jay
, Oklahoma
If the tanks are empty, there is no need to have them warm. One only needs to have the cabin above freezing.
The furnace is fine to use, but with propane at 5.00 per gallon, electric would be cheaper.
Regards,
JD
Jeff & Cindy
02-05-2014, 08:19 AM
1988 25' Excella
1987 32' Excella
Knoxville
, Tennessee
I think that running the propane heat at at a fairly low setting is the best way to keep it from freezing water lines. You could consider blowing the water out of the lines. I made a hookup with a quick disconnect to hook my air compressor to the system. That way I can blow the air out of the lines in just a few min. I think that and the propane furnace would solve the problem. Disclaimer: I dislike heat pumps a whole lot anyway.
02-05-2014, 08:41 AM
Fort Worth
HEY! that Pirit hose would have been useful this morning..... City Hookup was all frozen this morning.. so no shower for me :-(
Thanks for all the replies guys. Good info here. Yes, the furnace would have definitely been better but I just don't know if my bottles would last 4+ days. I think I'll be checking out some space heaters this afternoon
Thankfully nothing that has broke so far has been too much of a PITA to replace myself. Nothing hard to reach anyway. I'ts just those toilet valves that cost $50 each that kill me. Maybe I'll get a small space heater just for the bathroom
cheers all.
02-05-2014, 08:52 AM
Oswego
Regards,
JD
Problem is, at least with my unit, empty is never really empty. There is always some liquid left in the bottom of the tanks, due to the dump valves as well as the fresh drain being a bit above the tank floor. I think you are better off with full tanks and "warm liquid mass".
As far as saving propane for heating the tanks, I designed (with help here on the forums) a variable speed controller on the furnace blower, independent of furnace firing. That way, I can use electric and keep warm airflow to the tanks.
-Rich-
02-05-2014, 09:19 AM
Wise Elder
2010 30' Classic
South of the river
I have a little bit of a different perspective since I'm skeptical that the heat directed from the furnace to the holding tank area helps much.
Whether you're using the furnace, the heat pump, or some other heat source, you have to understand two things. One is the actual temperature you achieve inside the trailer. The other is how well heat is distributed. Using an IR thermometer helps greatly with this.
The rule of thumb that I use is that the inside of the trailer has to be two degrees above freezing for every degree that the outside temperature drops below freezing. So to support an overnight low of 22 (=32-10) degrees I set the thermostat to 52. (=32+20)
A question I would have is whether the heat pump is really working and keeping the trailer at 60 degrees. It's supposed to switch automatically to the furnace -- is it doing that? Do you have the propane turned on so that the furnace will work?
If the bathroom stays cooler than the rest of the trailer, you may need to keep it even warmer to protect the toilet valve. Or open doors and use fans.
02-05-2014, 09:38 AM
Jay
, Oklahoma
I understand what you are saying, but the tanks are in that same condition in a completely winterized, unheated trailer.
Of those who choose to flood "pink stuff" throughout the plumbing, most do not add antifreeze to the freshwater tank.
I also agree with Jammer, if the cabin is 65 degrees, it would have to be very cold to freeze the tanks inside the underbelly.
Regards,
JD
Jeff & Cindy
02-05-2014, 09:47 AM
2016 30' Classic
Hinckley
, Ohio
Hi, You have a 2014. Is the damper to the bathroom heater vent open if you have one? Are the tank heaters on? I small ceramic heater in the bath would keep it from freezing.
My budget won't stop me from buying something online that I don't need, but the threat of getting promotional
emails every day for the rest of my life just might!
02-05-2014, 11:04 AM
Oswego
That's true. That is precisely why I leave the FW valve drain valve open on my last road trip of the year....to help fully drain the FW out while rounding corners, etc. I also leave it open during winter storage so any drops in the valve won't crack it.
I also do put copious amount of AF in the black and gray tanks and the lines and traps. Kitchen water filter and lines blown out and filter/housing left off.
-Rich-
02-05-2014, 11:15 AM
Alamo Heights
Since you're leaving the trailer unattended in adverse conditions, you might want to consider a belt-and-suspenders approach. Electric space heater set to hold 60ish, furnace set to 50ish or its minimum setting (whichever is higher). That way, if there's a long power failure at the campsite, the furnace can tide you over until the power comes back on (hopefully... the batteries should be good for more than a day if they're only running the furnace enough to hold 50F).
As mentioned above, leaving cabinet doors open for warm-air circulation around pipes and fittings helps.
— David
02-05-2014, 11:30 AM
2012 28' International
Olympia
Use Auto Mode on the thermostat, not HP. This way when it gets too cold for the heat pump, the furnace will kick on.
Dave
2014 Ram 2500 CTD
Pro Pride
Centramatics
02-05-2014, 11:57 PM
Fort Worth
More good tips. As far as I know I don't have a damper in line with my furnace vent in the bathroom. It's just open.
If I recall correctly, the last time I set the thermostat to auto, it gave the furnace priority over the heat pump, which I thought was odd. It wasn't even freezing outside. Although, I could be mistaken in this. It's a good idea none the less in case my propane bottles go dry while I'm away.
Today I invested in a 1500w space heater. It was the biggest I could find on short notice. Space heaters are in VERY short supply around here this winter. LOTS of RVs/campers around. Had to hit 5 stores before I found one in stock. I'll take DKB_SATX advice and use his thermostat/space heater temp configuration. Although according to weather.com the low temp for the next 10 days barley touches on 32 degF.
I'll also be taking a few more extra measures such as blowing the plumbing with compressed air, and completely disconnecting the toilet when I leave this time. All this should have been done since the beginning of winter but I really thought the HP would keep the AS at a decent enough temp to not warrant the extra effort. Hindsight is 20/20 eh?
Thanks to every one for taking the time to leave their advice/feedback/experience. This is honestly the most helpful forum I've ever used (for any topic/interest).
02-06-2014, 04:46 AM
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction
Since the trailer is stationary for the winter per the information posted, perhaps acquire a 100 pound bottle of propane as primary with one of the 30 pound bottles as backup to use during the winter?
