Old 03-16-2014, 06:43 AM   #1
Sbb
begorragirl
Sbb's Avatar
2017 25' Flying Cloud
Denville , New Jersey
Partial Dewinterizing
My AS is going in for service next week. I was going to have teck, go under back mattress and change bypass valves. I thought I would leave all pink stuff in and use campground bathrooms. This first trip is really just a two night get away. Do u think pipes would still be ok if I didn't, drain, flush or use? Where I live we have potential for a few cold nights. oR, i could set it all up and run a heater( electric) 24/7. We are close with Spring, but not there yet.
2006 Bambi CCD ("EireStream!!")
2010 Funfinder
2005 T@B
2001 Teardrop, Mountain Hardware Tent
For some perfection takes a little longer...
Sbb is offline   Reply With Quote
Old 03-16-2014, 06:46 AM   #2
dznf0g's Avatar
Oswego , Illinois
If it has been winterized all winter, you could just drain the pink and leave it to flush when you get to your destination. It is not necessary to leave the lines full of anti-freeze. The water that was in there last fall will already be diluted/displaced so no freezing in valves, faucets will occur. Draining will prevent a mess when the tech opens up the system for valve replacement.
-Rich-
Old 03-16-2014, 06:49 AM   #3
dznf0g's Avatar
Oswego , Illinois
I drained, flushed and sanitized in anticipation for my Friday departure. Now it was 20* last night and going to be 10* tonight. I am running the furnace and keeping it above 50* inside. I did drain it again and am leaving the low points and fresh drain open, in case of drips collecting there and freezing.
-Rich-
Partial power to trailer PhiDor Electrical - Systems, Generators, Batteries & Solar 12 01-01-2013 04:11 PM
Partial Stripping - Washing Off Removall - '99 Safari Soyboy Cleaning, Stripping & Polishing 41 05-08-2012 08:46 PM
Boatdoc on partial mend. boatdoc Airstream Lifestyle 7 12-19-2011 08:46 AM
12V Partial power - '76 Argosy 28 Alliesargosy Electrical - Systems, Generators, Batteries & Solar 3 07-14-2011 07:58 PM
'65 Overlander partial recondition log, Mendocino, CA kaulike 1965 Overlander 1 09-30-2006 01:01 PM
