Old 04-15-2011, 05:12 AM   #1
1989 29' Excella
Tyrone , Georgia
Parking on mulch over clay
I am in the process of using a tractor to make a parking spot next to my garage. I was initially going to bring in gravel but am now thinking it would be smarter and more attractive to cover the hard clay ground with landscape fabric and mulch.
The trailer will be up on concrete blocks and the spot will have good drainage, but what do you all think about this route?
mikeandnora is offline   Reply With Quote
Old 04-15-2011, 07:07 AM   #2
2011 27' FB Classic
Masontown , West Virginia
While not knowing what type of mulch you have in mind, many of the common mulches will grow a type of mold that will "throw-off" spores that will leave black specs all over whatever is nearby. White cars look really strange when parked near a flower bed mulched with oak and other hardwoods............don't ask.
Seems like gravel of some sort would do better.
Good luck.
Bill & Dorothy Reeves
Betsy the Beagle
2011 27FB
2016 F250 6.2L
TAC # WV-2
MountaineerStreamer is offline   Reply With Quote
Old 04-15-2011, 08:18 AM   #3
CanoeStream's Avatar
St. Cloud , Minnesota
Where do you plan on supporting your coach? Any labeled "jack points" at either end of the trailer are intended for stabilizers only. The frame is not rigid enough to have those points support substantial weight of the trailer. Makes me wonder what will happen when clay swells as moisture conditions change.
Steel channel that the axles are bolted to can take all the weight you load there.
Not sure that cinder blocks are the best idea. See here and here. This issue keeps coming up -- hope someone with informed opinions speaks up.
5 meter Langford Nahanni
Old 04-15-2011, 08:37 AM   #4
1977 Argosy 24
Milltown , Wisconsin
Mulch will hold a lot more water then gravel. I would think that the humidity level under the trailer with mulch would be much higher then with gravel. More likely to cause the steel axles/frame to rust.
ventport is offline   Reply With Quote
Old 04-15-2011, 08:46 AM   #5
Good point. And nothing is worse than letting grass or any vegetation grow up to the belly wrap.
Old 04-15-2011, 08:58 AM   #6
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
Packed gravel. No Mulch. It will lead to accelerated corrosion underneath.
Michelle TAC MT-0
Sarah, Snowball
Old 04-15-2011, 01:45 PM   #7
1989 29' Excella
Tyrone , Georgia
Gravel it is. Thanks guys.
Courtesy parking or rental parking needed, Perris Valley, California skydiva Our Community 1 01-13-2011 06:13 PM
