Originally Posted by T Reno
I added hot water to the fresh water tank from my house then I took the AS over to a buddy's shop and we placed a torpedo heater at the drain point went & had breakfast came back & it drained thru the fresh water drain between the two wheels just fine.
Just in time as the temp had gone from 55 > 25 degrees in 2 hours, its now 15 outside and the low is to be 3 tonight…..
That's good to hear. Keep in mind that those drain spigots are pretty hopeless & their routing is very suspect. I had an 05 Safari in here a couple of years ago complaining about a drip on the bottom of the tank shroud. We removed the tank & discovered that the spin welded inlet fitting was half broken away from the tank. This allowed the tank to leak when it was relatively full. This was a very poorly welded fitting that caused this problem. We did however notice that draining the tank through the original spigot was very slow. Once the tank was removed, we discovered that the drain spigot was not lined up with the drain fitting in the tank. This allowed the vinyl tube that connected the two of them to become kinked...............really poor workmanship
Anyway, we replaced the fittings & realigned the pipes, using a pex ball valve & pex tubing, so now it drains really well.
Colin
