Old 10-22-2006, 12:55 PM   #1
snpotratz's Avatar
1972 27' Overlander
Belgrade , Montana
Not Dumping?
Can I just pour anitfreeze into the black tank instead of having to drive the TT across town to a dump site? The tank doesn't even read 1/4 full.
Steve
Belgrade, MT.
steven@potratz.net
'72 International Overlander - 27' of happiness
WBICC #4453
Member-at-Large cause I don't know any better
snpotratz is offline   Reply With Quote
Old 10-22-2006, 01:10 PM   #2
balrgn's Avatar
1974 27' Overlander
1954 26' Romany Cruiser
1960 26' Overlander
Rockingham County , New Hampshire
Images: 74
Send a message via AIM to balrgn Send a message via Yahoo to balrgn
Personaly, I don't like leaving that goop in there....
'74 Overlander (T-O-Bee)
'46 Spartan Manor (Rosie)
'54 Cruiser (Bogart)
'60 Overlander (Hoagy)
WBCCI 1754 - AIR # 6281
www.balrgn.com
balrgn is offline   Reply With Quote
Old 10-22-2006, 01:21 PM   #3
Naysayer
Boondocker's Avatar
1968 24' Tradewind
Louisville , earth
Send a message via Yahoo to Boondocker
I have been giving a similar problem some thought. Should I keep some antifreeze in the tanks during winter use, and how much? If I were storing it over the winter howerver, I would drain it for sure. If it aint in the tank it cant freeze there, and a freeze could turn into a nasty scenerio.
Rodney
Visit my photography page
and the
Favorite camp grounds project map
My Blog
(The artist formerly known as General Disarray)
Boondocker is offline   Reply With Quote
Old 10-22-2006, 02:46 PM   #4
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
My solution
Originally Posted by Gen Disarray
I have been giving a similar problem some thought...If I were storing it over the winter howerver, I would drain it for sure...
I drain & rinse my black tank when the fresh water lines are winterized.
For occaisional Airstreaming after that, we use the modern-day equivalent of a chamber pot purchased from Wal-Mart for around $20.
FWIW, although antifreeze can be added to the tank to protect it, I worry more about the dump valve - all that crap suspended in a variety of liquids does not strike me as good for the valve's rubber parts in freezing conditions.
Tom
Old 10-22-2006, 02:48 PM   #5
Janets Husband's Avatar
1977 Argosy Minuet 6.0 Metre
1964 26' Overlander
1977 25' Tradewind
Eastern , Washington
I don't know if that is a good idea, not just because of the freeze. The breakdown of material in a black tank generates ammonia and other things that work in the deterioration the seals in the valves.
Peace
Gary
Janets Husband is offline   Reply With Quote
Old 10-22-2006, 03:25 PM   #6
snpotratz's Avatar
1972 27' Overlander
Belgrade , Montana
Thanks!
Well thanks for the advice all. The weather unexpectedly cleared this afternoon from the freezing fog and snow we had this morning, so I hooked up quick and dumped across town. Now I don't have to worry about it all winter.
Steve
Belgrade, MT.
steven@potratz.net
WBICC #4453
Old 10-22-2006, 04:13 PM   #7
enduroryda's Avatar
1994 21' Sovereign
Down on the corner... , CT
Good advice...I never thought of the residual antifreeze in my grey tank after winterizing. I know I can do a rinse to the black tank but what about the grey? I don't think there is any way around rinsing it out now that I have anitfreeze in the traps except to drain what might be in there from the dump valve. I did put window wash in the toilet...I'm wondering if it would be beneficial to pour the rest of the gallon in the back tank to protect and lubricate the seals. What do you think and is it really something to worry about??
Ann & Eric
WBCCI 6274
TAC CT-4
NEU
enduroryda is offline   Reply With Quote
Old 10-22-2006, 05:31 PM   #8
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
Bosque Farms , New Mexico
Ah, keep in mind that RV antifreeze, if diluted (even with black water), will lose much of its protective capacity. Read the label carefully; you may wind up having to put a LOT of antifreeze in there in order to keep it from freezing.
Lynn
WBCCI 21043
Old 10-22-2006, 05:45 PM   #9
yukionna's Avatar
Massachusetts
Images: 18
Send a message via Yahoo to yukionna
I drain both tanks before I winterize. Water freezes and you don't want it anywhere in your system. After I winterize, I drain the gray tank one last time to get rid of the last bit of water dislodged from the traps when I pour AF in them.
WBCCI Region One
Attitude is the only difference between ordeal and adventure
yukionna is offline   Reply With Quote
Old 10-22-2006, 05:57 PM   #10
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
If you drink enough alcohol, you theoretically won't need antifreeze in your black tank...
Old 10-22-2006, 05:59 PM   #11
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
Terry,
Are you willing to test that theory?
Richard
Old 10-22-2006, 06:11 PM   #12
Well Preserved
1993 21' Sovereign
Originally Posted by azflycaster
Terry,
I would, but I live too far South for any tests to be meaningful. I will have to let someone in a more Northern clime perform the test... If anyone tries this, make sure you use copious amounts of Bacardi 151 rum-- Then even if it doesn't work, you won't care.
Old 10-23-2006, 09:17 PM   #13
snpotratz's Avatar
1972 27' Overlander
Belgrade , Montana
You guys crack me up
Steve
Belgrade, MT.
steven@potratz.net
WBICC #4453
Black Tank Flush JmesDean Waste Systems, Tanks & Totes 34 04-03-2006 04:34 PM
Dumping into the Blue Tank Cracker 1997 -2001 Excella 4 02-09-2005 07:29 AM
Dumping Air swebster Mechanics Corner - Engines, Transmission & More... 25 01-26-2004 07:29 PM
Holding Tank Dumping jalewis Waste Systems, Tanks & Totes 6 10-19-2003 11:06 PM
Shakedown trip--holding tank draining quest. Kistler Our Community 6 12-01-2002 09:21 AM
