Old 10-09-2014, 09:49 AM   #1
2014 28' International
Pittsburgh , Pennsylvania
Non-winter winterizing
I know this title seems a little ambiguous but I am in need of some sage advice. I will be storing my 28 International Serenity in a storage facility in Western PA. It is an abandoned limestone mine and the company that owns and manages the facility has stated that the temperature is a constant 57 degrees. Should I do anything different in this environment? I am required to remove the propane tanks and will also be bringing my batteries home to maintain on trickle chargers. I normally drain the fresh water tank, keep some water & chemicals in the BW tank and put a dehumidifier chemical bucket inside when I store for the mild seasons. Is there anything else that you veteran Airsteamer's can recommend?
vetman93 is offline   Reply With Quote
Old 10-09-2014, 09:53 AM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Constant 57 degrees! Brew beer.
MICHAEL
Old 10-09-2014, 09:59 AM   #3
Goal15's Avatar
Dallas , Texas
Watch out for stalactites . . . I'll bet the drips coming off those would do a number on your AS I'm only half kidding... am not a chemist but would wonder if the ph levels in a limestone mine environment might be a concern with an aluminum trailer
Dana and Olga
2006 Safari 23
2011 Tundra Double Cab
Goal15 is offline   Reply With Quote
Old 10-09-2014, 10:23 AM   #4
The mine is extremely dry. I have friends that store their RV's there and they say that their issue is dust.
Old 10-09-2014, 10:28 AM   #5
Wise Elder
Jammer's Avatar
2010 30' Classic
Remove any items of food that might interest mice, and be sure the freezer and fridge doors are blocked open.
I would use RV antifreeze in the drain traps and toilet, not as protection from freezing, but to keep them sealed. Water evaporates more quickly than RV antifreeze.
Old 10-09-2014, 01:25 PM   #6
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
Very good point, especially on the toilet. If that flush gasket gets dry, it might tear on the first flush of the season.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 10-09-2014, 01:35 PM   #7
Alumaholic's Avatar
1966 24' Tradewind
Albuquerque , New Mexico
Images: 33
I would sanitize and drain the freshwater tank.
I would also drain the water heater. Your H20 heater has a sacrificial anode that promotes the growth of a bacteria that produces H2S (hydrogen sulfide). That has been a real problem for me when I haven't drained the H20 heater.
I also remove the carbon activated filter from the filtration device beneath the kitchen sink and keep it immersed in water in a closed container in the garage refer.
Ken L
1966 Tradewind 24
2007Chevy Silverado 2500 HD Duramax/Allison
Four Corners Unit WBCCI #8654
Alumaholic is offline   Reply With Quote
Old 10-09-2014, 03:01 PM   #8
retired USA/USAF
2001 30' Excella
Somerset , New Jersey
Our trailer was stored from new until we got it in a limestone cave in Missouri by the original / previous owner. He didn't do anything other than drain the water I think.
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
polarlyse is offline   Reply With Quote
Old 10-09-2014, 03:07 PM   #9
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
Sounds like a perfect environment for storing your AS over the winter!
I would make doubly sure that both my black and grey tanks are completely clean, then leave a small amount of fresh water in each to keep the seals on your dump valve(s) from drying out.
I would also completely empty the fresh water tank and the hot water heater as previously stated.
If you can, blow out the city water system and the various faucets with compressed air to minimize any possibility that the water in those lines will "turn nasty" over the winter with the lack of use.
In the spring, I would sanitize the entire fresh water system with diluted bleach. Instructions for this can be found elsewhere on the forum.
Replace the under counter water filter (if you have one) annually in the spring, don't save the old one for re-use.
Make sure your tires are filled to your desired pressure.
Chock at least one wheel (or set of wheels) to prevent any shifting in case your AS gets nudged, or God forbid, there would be a minor tremor over the winter.
Bob Martel
WBCCI# 5766
Old 10-09-2014, 03:14 PM   #10
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
You can also minimize evaporation by wrapping the toilet in Saran Wrap after adding either water or antifreeze.
Sidebar - Since you know it's not going to freeze anyway, you can minimize your antifreeze expenditure by using a 50-50 blend of antifreeze and water. Your engine block and radiator don't use pure antifreeze, so why should your pipes use pure RV antifreeze?
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 10-10-2014, 11:19 AM   #11
Alumaholic's Avatar
1966 24' Tradewind
Images: 33
If You Must Use Antifreeze
I realize this is a thread about winterizing for non-freezing storage.
But if you ever must use antifreeze, it's fine to use RV antifreeze in the traps and drains.
But I use cheap vodka colored with red food dye in the fresh water lines, a technique some other Airstreamer recommended on this Forum some years back.
Use it and you'll never be bothered by the taste (or feel when you take your first shower of the season) of RV antifreeze again.
Ken L
1966 Tradewind 24
Old 10-10-2014, 11:45 AM   #12
80-proof vodka freezes at -16°F. 100-proof vodka freezes at -40°F. 190-proof vodka (Everclear) freezes at -173°F. By comparison, typical "pink stuff" antifreeze freezes at -50°F.
WBCCI #1105
TAC LA-4
Old 10-10-2014, 12:58 PM   #13
Alumaholic's Avatar
1966 24' Tradewind
Images: 33
Thanks Protaganist. I should have acknowledged that where you live should determine which type of antifreeze to use. Here in Albuquerque, 80 proof vodka works great when I blow out the lines with compressed air first so the vodka will not be diluted.
Ken L
1966 Tradewind 24
Old 10-10-2014, 01:27 PM   #14
Chelsea , Michigan
Images: 12
I make it a point to spend winters where a nice IPA would suffice to winterize my Airstream!
Bob Martel
WBCCI# 5766
Non Traditional AC - Not on the roof Bryanhu Furnaces, Heaters, Fireplaces & Air Conditioning 63 03-12-2006 02:38 PM
Winter? What winter??? Pahaska Off Topic Forum 21 01-06-2006 09:17 AM
Florida New Years non-rally get together thenewkid64 The Rally Zone 20 12-30-2003 10:47 PM
Retrofitting Old Propane Tanks (non-opd) leslie LP Gas, Piping, Tanks & Regulators 18 09-20-2002 10:24 AM
