Old 03-31-2011, 02:16 PM   #1
cloudflyer's Avatar
2011 23' FB Flying Cloud
Missoula , Montana
No Power to Hydraulic Jack
Greetings All,
Couldn't find a relevant thread by search, so here goes:
I took my batteries out of storage last night and dropped them back into the trailer (2011 Flying Cloud 23 FB), they were stored in a heated area and kept charged, there is plenty of electrolyte solution in them. All systems are functioning nominally except the hydraulic jack isn't getting any power. Double checked and the batteries are hooked up correctly, checked for blown fuses at the jack (which I replaced with a new one anyway) and inside the trailer, no dice.
It's always been a touchy piece of equipment in my experience.
Any suggestions?
Thanks!
cloudflyer is offline   Reply With Quote
Old 03-31-2011, 02:23 PM   #2
clancy_boy's Avatar
2003 22' International CCD
Kiln , Mississippi
Images: 8
If you mean the jack at the front - that is not hydrolic, it's a screw mechanism with a motor on top. Check that when you replaced the battery you did not leave off the small power wire that goes to the jack. It's usually powered directly off the battery with an inline fuse for protection. The gear mechanism sticks sometimes, try the manual handle that came with the trailer and see if you can turn it by hand. The acces is under a cap on top of the unit, then try the power switch.
Michael & Tina with Layla and Preston BZ
The family has grown.
2003 22' INTERNATIONAL CCD
Old 03-31-2011, 05:02 PM   #3
cloudflyer's Avatar
Missoula , Montana
Thanks to clancy_boy, problem solved.
It was the power wire, which I mistook for a ground, and attached to a (-) battery terminal. Switching it to a (+) terminal did the trick. Lesson learned!
I stand corrected on the jack type, I should have known from the sound it makes that it wasn't hydraulic.
airforums helps a n00b once again!
Old 03-31-2011, 05:28 PM   #4
clancy_boy's Avatar
Kiln , Mississippi
Images: 8
Yep, and if I could spell while I think and type I would not look so foolish when I answer.
HYDRAULIC
OK to use a jack instead of blocks to level? KYAirstream Jacks, Stabilizers, Lifting and Leveling 27 09-18-2012 06:42 AM
Jack point on 20 foot-Caravelle/Argosy ? glacierrunne Jacks, Stabilizers, Lifting and Leveling 1 03-16-2011 10:53 AM
Power Steering Not Working - 310 Motorhome steveturk Classic Motorhomes 27 02-18-2011 05:00 PM
Hydraulic leveling system. boatdoc Jacks, Stabilizers, Lifting and Leveling 18 02-08-2011 05:30 AM
Power cord length-recommendations? SilverHoot Electrical - Systems, Generators, Batteries & Solar 17 01-23-2011 02:39 PM
