Old 10-03-2012, 04:13 PM   #1
2008 23' Safari FB SE
Boulder , Colorado
Newer AS (2008) - correct air pressure to blow out water lines
Every post I read about blowing out your lines when winterizing says to use between 35 and 40 lbs. I just ready my 2008 safari manual and it says use no less than 60 pounds pressure.
I was able to get an air to city water adapter but the max pressure it supports is 45 lbs.
What is the right pressure to use to clear the lines? Is the airstream manual correct?
So confused on what will be adequate and not destroy the lines...
Thanks.
bonginator is offline   Reply With Quote
Old 10-03-2012, 04:18 PM   #2
dznf0g's Avatar
Oswego , Illinois
I use 60 - 65 lbs static. (That is, 65psi in the closed air line from the compressor) Once you let the air flow it is more like 45 - 50 constant flow pressure in the system.
-Rich-
Old 10-03-2012, 04:28 PM   #3
Wise Elder
Jammer's Avatar
2010 30' Classic
I don't think it matters much. The PEX will take more than 90 pounds at reasonable (not excessively hot) temperatures.
Old 10-03-2012, 04:37 PM   #4
Boulder , Colorado
What kind of adapter do you use? The one they sell @ camping world only takes 45 pounds max (with the rubber hose)
Old 10-03-2012, 04:52 PM   #5
dznf0g's Avatar
Oswego , Illinois
Well, I don't know, it's nylon, screws into the city water inlet, and has a rubber valve stem in the center. I've had it and used it as described above for ....well over 15 years, I think. I have no clue where I got it.
-Rich-
Old 10-03-2012, 07:13 PM   #6
richinny's Avatar
2011 34' Classic
questions:
will the water pressure regulator in the trailer regulate air pressure as well as water pressure?
would it be correct to say that the line before the regulator it subject to whatever pressure is applied? is this section any stronger?
Ricky
Old 10-03-2012, 08:22 PM   #7
Boulder , Colorado
Originally Posted by richinny View Post
questions:
Great question!
Old 10-04-2012, 05:11 AM   #8
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
OSHA requires the use of air pressure less than 30 psig for cleaning purposes. You shouldn't need more than that to blow out your lines anyway. 30 psi is equal to 831 inches of water column in terms of pressure.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 10-04-2012, 06:18 AM   #9
dznf0g's Avatar
Oswego , Illinois
Static or working?
-Rich-
Old 10-04-2012, 06:24 AM   #10
Static or working?
At the nozzle. Air tank pressure can be higher.
WBCCI #1105
TAC LA-4
Old 10-04-2012, 06:30 AM   #11
dznf0g's Avatar
Oswego , Illinois
That's not what I mean. Static = set the regulator at 30 psi with no air flowing out of the hose....or working = set the regulator at 30 psi with the air gun at wide open at hose end. That would be more like 40 or 45 psi static pressure.
-Rich-
Old 10-04-2012, 06:37 AM   #12
Actually, my answer IS what you meant. Set the regulator at 30 psi with the air gun wide open at the hose end, i.e. 30 psi at the nozzle.
As an engineer, I have often been accused of making my answers more complicated than they need to be, so I thought I would experiment with using non-technical terms. Guess it didn't work this time. Should have stuck with the technical term.
WBCCI #1105
TAC LA-4
Old 10-04-2012, 06:44 AM   #13
dznf0g's Avatar
Oswego , Illinois
Yeah, 30 psi working is probably OK, but I once left a drop or two in the shower faucet of my old SOB and it froze and cracked. I was using lower pressures back then. Now, whether it was low pressure, or not allowing enough "blow time" is definitely arguable, but since then, I use higher pressure. More like 45 psi working pressure.
I do keep all facets open after blowing out, adding AF and while in winter storage.
-Rich-
Old 10-04-2012, 07:19 AM   #14
Boulder , Colorado
Just received the official response from airstream cust support. They say 60 pounds. Indicated that anything lower would not be enough to clear the lines reliably. They said the newer piping can take more pressure than older model airstreams.
