Old 10-16-2004, 05:44 AM   #1
luckydc's Avatar
Richmond , Virginia
newbie needs suggestion...
What kind of compressor do I need to blow out the water lines? I have never owned a compressor.
Will something like this work?
http://www.campingworld.com/browse/s...=SRCH&tcode=37
Thanks.
Paul
WBCCI #2468
2006 Ford F-150 Lariart 4X4
2004 19' Bambi Safari LS
luckydc is offline   Reply With Quote
Old 10-16-2004, 05:57 AM   #2
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
paul
that looks a bit small, what you want is something with a tank on it so you have some volume.
if you plan on adding antifreeze to the water lines it may be just fine, if you are going to rely on just blowing the lines out i would find something larger.
john
you call them ferrets, i call them weasels.
Old 10-16-2004, 06:05 AM   #3
luckydc's Avatar
Richmond , Virginia
Thanks, John. Something like one of these?
http://www.sears.com/sr/javasr/produ...id=00915201000
http://www.sears.com/sr/javasr/produ...id=00915200000
I gues they have a PSI regulator on them?
Paul
WBCCI #2468
Old 10-16-2004, 06:17 AM   #4
Moderator Emeritus
Pick's Avatar
1972 31' Sovereign
High Springs , Florida
Images: 36
I use something like this:
Tractor Supply Compressor
You want something that can supply you with air long enough to get most of the moisture out of the lines, so it does not trickle down to a low spot in the piping and cause damage if it freezes.
I am going to replace a run of copper in mine shortly. I "repaired" it with a short length of heater hose, but it keeps coming apart, because it is to far under the bathtub to reach and get a good grip on the pipe to attach the hose. I am going to replace the whole run with copper.
A locking air chuck is also very helpful. Let's you lock the chuck on the schraeder valve so you don't have to sit there and do it yourself.
ARS WA8ZYT
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
WBCCI 1350
Old 10-16-2004, 06:40 AM   #5
luckydc's Avatar
Richmond , Virginia
Thanks, Pick. Seems a bit much for my needs. My Bambi is only 19' and I don't really have any other use for a compressor.
Paul
WBCCI #2468
Old 10-16-2004, 07:39 AM   #6
Ken J's Avatar
1956 22' Flying Cloud
Durango , Colorado
Images: 14
You don't want to use an oil based compressor - it will put oil in your lines. I use a cheapie $9.00 walmart compressor - just let the pressure build up a bit and let it go. I live in deep freeze Siberia country and have never had a problem - I blow the lines out and fill with antifreeze.
Ken
1956 Flying Cloud
Founder :
Four Corners Unit
Albuquerque National Balloon Fiesta
Rally
Vintage Trailer Academy - Formerly the original
restoration rally
Ken J is offline   Reply With Quote
Old 10-16-2004, 09:59 AM   #7
Cracker's Avatar
Pittsfield , Maine
Ken J:
Now you tell me about the oil-based compressor! This is the first year I've blown the lines before installing the anti-freeze. In the past I've simply installed anti-freeze using the valve and tube just ahead of the pump - but I've had so much trouble with the connection from the pump to the tank that I disconnected the pickup last summer. We seldom use the on board water supply for drinking or cooking - preferring the 2.5 gallon water jugs from the grocery store.
Cracker
Cracker is offline   Reply With Quote
Old 10-16-2004, 10:25 AM   #8
Images: 59
Oil contamination can be reduced if you use a little screw-on air filter designed for paint sprayers. On top of that, oil is soluble in proplene glycol antifreeze, so there shouldn't be a hazardous level left after you flush out the antifreeze.
If you're careful.
Old 10-16-2004, 11:37 AM   #9
Ken J's Avatar
Durango , Colorado
Images: 14
It oils your insides..... good for old age
1956 Flying Cloud
Founder :
Four Corners Unit
Rally
restoration rally
Newbie In Need Of Service Manual daveinbama General Repair Forum 2 07-12-2004 07:28 AM
Newbie looking at Vintage AS jay52 Our Community 4 07-01-2004 12:34 PM
Newbie joke (sorry about that) Rick Alston Off Topic Forum 9 02-07-2004 01:34 AM
Hello! (newbie alert) Travel_RN Our Community 14 08-13-2003 11:22 PM
Newbie looking to restore old AS Paul Brown Our Community 1 10-05-2002 05:04 AM
