Old 10-19-2016, 01:38 PM   #1
2015 23' International
Old Bridge , New Jersey
Newbie confused
I admit I haven't looked very long but I can't find any info as to how to winterize without using an air compressor. I purged the water using the water pump. Now where do I put the anti-freeze? Do I pour it in to the water fill of fresh water tank or the water fill when I hook up to city water? Also, not clear as to what I need to dissconnect from the water pump. Also, not sure as to how to turn off the electric heating element on the hot water heater.
I own a 2015 23D Serenity. I owned other Airstreams but luckily never had to winterize. Please help.
LiaG is offline   Reply With Quote
Old 10-19-2016, 01:57 PM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Pretty detailed and well made video,
https://youtu.be/pm2hTs3Nmoc
Check list,
http://rvservices.koa.com/rvinformat...-checklist.asp
Glad I do not have to currently worry about it Camping year around. Are you heading north for the winter?
MICHAEL
Old 10-19-2016, 04:21 PM   #3
LFC
Memphis , Tennessee
Drain the fresh water tank....put in 3 or 4 gallons of RV anit'freeze open the faucets and turn on the pump run until you see pink.
When I blew my lines with an air compressor the next spring the water pump diaphram was busted.
Next spring drain the tank....fill and re-drain a few times and let the water pump pump the lines clear.
LFC is offline   Reply With Quote
Old 10-19-2016, 04:36 PM   #4
retired USA/USAF
2001 30' Excella
Somerset , New Jersey
I've never had the water pump freeze. My last step is to disconnect both lines and run the pump a few seconds with a absorbent towel to sop up any water that discharges. This past summer I wired my pump with push connections and plan to simply remove the pump entirely.
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
polarlyse is online now   Reply With Quote
Old 10-19-2016, 04:51 PM   #5
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
I use compressed air. The Floject pump installed in my Airstream has clip in connections. I remove them and like the previous poster run the pump after blowing out the pipes. I keep the faucets, low drain point and water tank drain open. So far, after a couple of 0F winters, the plumbing system hasn't had any issues. I drop a couple of gallons of antifreeze in the black and grey tanks, shower and sink traps. If my pump was more accessible and I could get to the pipes easier I'd install a diverter valve between the pump filter and pump so I could pump in antifreeze.
Kelvin
Old 10-19-2016, 04:58 PM   #6
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Anti freeze in the FW tank is a bad idea.
Your coach may have a winterizing kit already installed. There will be a 3 way valve with a piece of hose (not connected on one end) which is meant to stick into a bottle of AF. You rotate the valve handle to the point where AF will be drawn from the bottle when the pump is started. Pump required amount of AF into the system. When done the pump will have AF in it and will not freeze.
If you don't have the winterizing kit in your coach. It is a simple matter of disconnecting the hose from the intake side of the pump. Attach a length of hose long enough to connect the intake of the pump to a bottle of AF. When done remove the temporary hose, then connect the tank hose to the pump.
Old 10-19-2016, 05:08 PM   #7
1976 31' Sovereign
Oswego , Illinois
Like to add 1 thing to Twinkies post. Put cup of AF in each drain other wise he is spot on, also he stated do not put AF in FW tank odors and taste all most imposble to get out
Old 10-19-2016, 05:19 PM   #8
Gainesville , Florida
Why is it a bad idea? It's not poison.
Old 10-19-2016, 05:55 PM   #9
nickclifford's Avatar
1972 31' Sovereign
felton , California
Didn't know it got that freezing in Florida !!
I'm in the Santa Cruz area, about 7 miles inland and we can get to freezing point for sure but not much below. My local RV place says they've never had an issue with burst pipes but my '72 has copper of course and most RV's would have plastic right ? He told me not to worry, but I'll drain my tank and blow out best i can ... not too sure what to do residual water in my on-demand water heater. I put a bunch of foam around the pipes last year... Good luck .. !
nickclifford is offline   Reply With Quote
Old 10-19-2016, 06:28 PM   #10
FCStreamer's Avatar
2014 30' Flying Cloud
Winterize? What's that?
2014 Airstream Flying Cloud 30 Recliner - WBCCI #4850 - AIR #110821
2018 Nissan Armada SL Tow Vehicle, Equal-i-zer Hitch
Visit Our Flying Cloud blog for my latest adventure!
FCStreamer is offline   Reply With Quote
Old 10-19-2016, 08:51 PM   #11
ericpeltier's Avatar
Superior , Colorado
It's when I don't see my DW naked from Sept to May.
1972 33' Streamline Emperor Crown Imperial
1949 30' Spartan Royal Mansion
2012 Nissan Armada
Most of China
ericpeltier is offline   Reply With Quote
Old 10-19-2016, 10:29 PM   #12
2007 22' International CCD
Rimshot!!!!
KE4GNK/AE
'The Silver HamShack' (2007 International 22FB CCD 75th Anniversary model)
rmkrum is online now   Reply With Quote
Old 10-20-2016, 12:06 AM   #13
I've never winterized here in north Florida, of course im plugged in all the time and use heat on the very rare occasion that it gets into the low twentys or teens..
Old 10-20-2016, 07:16 AM   #14
Sorry, forgot to change my profile address. I just moved back to New Jersey. Yep, don't ask me why I thought it was a good idea. So, for the first time I am winterizing and since I am not mechanically inclined, I am on here asking stupid questions. One such question is which end of the pump, pictorial would be helpful, do I stick in the AF bottle?
Confused newbie rad1 Member Introductions 21 04-24-2014 12:03 PM
Confused Newbie-Help! gooddoc316 Towing, Tow Vehicles & Hitches 16 12-08-2012 05:41 AM
confused Argosy newbie Dave Cole All Argosy Trailers 23 09-15-2006 09:36 PM
Help - I'm Confused timcumming Clearcoat, Exterior Paint & Trim 16 02-26-2003 01:23 PM
