Old 12-23-2011, 11:09 AM   #1
10Smiles's Avatar
2005 30' Classic
Kingston , Washington
New Home for Airstream
I have wanted a "car port" for our trailer for years (our first two trailers were of the SOB variety). Now that we have an Airstream, it seemed more important. Originally, I was going to buy one of those steel pole building kits; a steel pole building kit big enough to fit the trailer was going to cost about $3,000. A neighbor down the road built a pole building that gave me inspiration. I decided to build one instead.
The pole building is 24' by 36'. The vertical posts are 16' 6X6's for the sides and 20' for the middle posts on the ends (there are no posts inside the building). I made trussed out of 2X12's and 2X6's; I built them in place because they would be very heavy and I do not have a crane.
I used steel for the roof (it is all on, but it is not all complete yet). The total cost for the building is about $4,500 ($2,500 for the steel).
It took me all day last Saturday to clean the trailer before moving it into its new home. The roof was covered with cedar needles, maple leaves and seeds, alder leaves, and hemlock needles.
I am very pleased with the results. The next step will be to pour a concrete floor. I may close in the structure in the future.
Pictures...
ID:	147512   Click image for larger version
ID:	147514   Click image for larger version
ID:	147516   Click image for larger version
10Smiles is offline   Reply With Quote
Old 12-23-2011, 11:16 AM   #2
Alumaholic's Avatar
Albuquerque , New Mexico
Beautiful! You'll be very glad you did this. When you pour your floor, make it a 6 inch slab with remesh 2 inches from the bottom.
Ken
2007Chevy 2500 HD Duramax/Allison
NM Unit WBCCI #8654, Affiliate Four Corners Unit
"Those Airstream photos on the internet that fuel your fantasies will always capture the gleam of aluminum, but rarely all the blemishes, and never the smell."
Alumaholic is offline   Reply With Quote
Old 12-23-2011, 11:33 AM   #3
Splitrock's Avatar
1976 31' Sovereign
Sioux Falls , South Dakota
Nice! I'd like to do something like that but I live in Minnehaha County South Dakota and here the government would throw me in prison if I built any building over 120 square feet. My lot is over 5 acres in the country and the county condemned my land for any use at all.
Here, RV storage is a commercial use and can only be done in a commercial zoned area. The exception is if a property is over 40 acres the county will issue a building permit for an agriculture use building. The Rv can be stored in that without challenge.
My advise to anybody looking to build or buy property . . . stay away from Sioux Falls South Dakota and especially stay away from Minnehaha County South Dakota due to the extremely unfriendly zoning laws. Minnehaha County isn't just RV unfriendly, they're everything unfriendly.
http://img.photobucket.com/albums/v1...g?t=1278182564
Splitrock is online now   Reply With Quote
Old 12-23-2011, 11:37 AM   #4
bwoodtx's Avatar
1997 30' Excella
1954 25' Cruiser
1958 22' Custom
1979 28' Airstream Excella 28
San Antonio , Texas
A slab that big I would use 3/8" rebar tied 12" on center and place it on the plastic pedestals you can get in the same section as the ties. You have constructed a beautiful structure so far don't skimp on the foundation and use the mesh. On a 6" floor use the rebar and spec 3000psi concrete. You will be glad you did.
Bruce
WBCCI# 9259 AIR# 38927 TAC-TX 14
Stop Littering-Spay & Neuter-- Adopt From Rescue
He is your friend, your partner, your defender, your dog. You owe it to him to be worthy of such devotion.
bwoodtx is offline   Reply With Quote
Old 12-23-2011, 03:25 PM   #5
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
My building is 24'x24, the slab is 6" thick. No rebar or wire mess but the concrete is re enforced with fiberglass. I also park heavy farm equipment weighing in excess of 14k #'s in this building. No problems with the floor. Well there is one problem; It's not big enough for all of my toys.
TG Twinkie is online now   Reply With Quote
Old 12-23-2011, 03:37 PM   #6
Alumaholic's Avatar
The key point is that a 6" slab is better than 3" for this application.
I won't argue the remesh, versus rebar, versus fiberglass.
It's been almost 50 years since took my construction materials class, and almost 5 years since I poured the slab for Airstream Haven.
http://www.airforums.com/forums/f161...ven-26074.html
From what I can tell the fiberglass works and it is certainly an easy and low cost alternative to rebar or remesh.
Ken
Old 12-24-2011, 07:27 AM   #7
doug&maggie's Avatar
Normal , Illinois
Very nice! I want one!
Maggie
The more you know, the less you need
doug&maggie is offline   Reply With Quote
Old 12-24-2011, 08:26 AM   #8
c_lewis77's Avatar
1982 34' Limited
Brunswick , Georgia
Looks great!
Slab wise, I have used fibermesh on driveways for the most part. WWM (welded wire mesh) for resodential slabs, rebar for commercial slabs.
Make sure you lay out your joints in relation to the structure and sy of concrete to avoid unsightly cracks.
Good luck!
1982 34' Limited
2000 Excursion V10 4x4
WBCCI #3321
TAC #GA-24
c_lewis77 is offline   Reply With Quote
Old 12-24-2011, 10:30 AM   #9
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
Wow - really nice looking! Great work!
Chris
Minno is online now   Reply With Quote
Old 12-24-2011, 11:25 AM   #10
10Smiles's Avatar
2005 30' Classic
Thanks everyone for the thoughts and advice. It is great to have the trailer under cover, especially this time of year.
Old 12-25-2011, 08:49 AM   #11
BrandonJenna's Avatar
2012 27' FB International
Corvallis , Oregon
Definitely pour something, and definitely enclose it.
BrandonJenna is offline   Reply With Quote
Old 12-25-2011, 02:35 PM   #12
CanoeStream's Avatar
St. Cloud , Minnesota
Looks like no new panels on your Classic between frames 1-2 and 5-7. «wipes sweat from brows» You musta already come up with "Move it between hammer swings."
Great project! What width doors will you use?
5 meter Langford Nahanni
CanoeStream is online now   Reply With Quote
Old 12-25-2011, 04:09 PM   #13
10Smiles's Avatar
2005 30' Classic
Yea, pretty dumb eh?? Building the frame above the trailer. Later, I did move it out. Glad to say, nothing was dropped on the trailer!!
Not sure on the door width. I was hoping I can make them 11 feet. The distance from the corner to the center is 12 feet. I do have a receiver on the front of the van so I can push the trailer in with a bit more control.
Old 12-28-2011, 03:47 AM   #14
macofpei's Avatar
2003 30' Classic
Stratford , Prince Edward Island
Send a message via Yahoo to macofpei Send a message via Skype™ to macofpei
Oh-Oh-- I see your property tax going up.
Mac from PEI
Canada
WBCCI #4782
"Southern Belle"
'03 Classic 30'
'10 Toyota CrewMax
macofpei is offline   Reply With Quote
AS Tax Deduction as Second Home boutdoors Dollars & Cents 34 12-05-2011 07:08 AM
1500 Mile Trip to get her home - Suggestions? Bambi_Bandit 1958 - 1963 Overlander 11 03-01-2011 12:23 PM
