Old 06-24-2016, 07:31 AM   #1
2016 30' Classic
Bend , Oregon
Send a message via Skype™ to synapticon
Need Specifications for Power and Sewer
My son-in-law has graciously made a portion of his property in Palm Springs, CA available for storage of our 2016 Classic. He has a contractor lined up to pour a slab and make hookups for power and dumping waste (connection to sewer line). I need help getting him the specific details of how to set up 50 amp service and what sort of connection to make with the sewer. What experience have people had with this and where can I find the best information for these specifications?
Rob
Rob
2016 Classic
2016 Ford F250 Lariat 6.7 L Diesel Powerstroke
ProPride
For those who understand, things are as they are. For those who don't understand, things are as they are.
synapticon is offline   Reply With Quote
Old 06-24-2016, 07:48 AM   #2
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
If the Classic has two air conditioners, it has 50 amp 240 Vac service. #6 wire to the four prong receptacle is required, or larger if there is a long distance to the home circuit breaker box. A RV park type pedestal that has a 50 amp 240Vac receptacle,a 30 amp 120Vac receptacle and a duplex 20 amp like in the house receptacle is the best solution so any power combination is supported.
A standard 4" clean out plug and 4" pipe is used to go from the trailer side to the home sewer line. Venting comes from the trailer when dumping.
Old 06-24-2016, 07:59 AM   #3
Gainesville , Florida
Double check the voltage for 50 amp service. Make sure you have it correct.
Old 06-24-2016, 08:28 AM   #4
Images: 59
A RV style pedestal with a 50a 120/240V receptacle, a 30a 120V receptacle, and a 20a GFCI 120V Duplex receptacle will really be a 80a service or larger.
Old 06-24-2016, 11:54 AM   #5
1977 31' Sovereign
Lynnwood , Washington
I sure hope that site has a carport cover. That desert sun is brutal.
Tom
TomKirk is offline   Reply With Quote
Old 06-24-2016, 08:30 PM   #6
rvb
rvb's Avatar
1977 Argosy 28
Euless , Texas
Electric outlets
I believe the 50 amp outlet is a NEMA 14-50R and a 30 amp is a TT-30. If you wire both a 30A and a 50A make sure the electrician wires the 30A as 120V not 220V. They are sometimes confused with a dryer outlet and will fry your trailer electrics if wired to the higher voltage!
rvb is offline   Reply With Quote
Old 06-25-2016, 06:03 AM   #7
Trnpk Crsr's Avatar
Baltimore , Maryland
If I was able to design my own hook ups, I would copy the design of a company that ran ads in the back of Trailer Life in the early 70's.
They had the electrical panel like the one that someone has already shown a picture of, on a pedestal. At the bottom of the pedestal was basin about 10 inches deep and 12 inches square. The sewer connection was at the bottom of the basin. The bottom of the basin was sloped so that any water in the basin would run into the sewer. A water facet was next to the electrical panel facing the basin and it was on a stand pipe about 2 or 3 ft. high. If you turned on the facet, the water would run into the basin. More than one facet would be a good idea.
With the basin being lower than grade level, the water in the sewer hose would flow down into the sewer without having to put anything under the sewer hose to slope it toward the drain.
The basin could be formed when you pour the concert for the pad.
Trnpk Crsr is offline   Reply With Quote
Old 06-25-2016, 06:21 AM   #8
Images: 59
No need in this unit as the receptacles are prewired. The electrician just needs to attach feed wires to the main lugs like any breaker panel.
Old 06-25-2016, 06:34 AM   #9
2011 30' Flying Cloud
Greenback , Tennessee
Do be sure you have water at the site. You need it for cleaning tanks, filling FW tank and washing the rig.
Gneiss Guy is offline   Reply With Quote
Old 06-25-2016, 08:56 AM   #10
2016 30' Classic
Bend , Oregon
Thanks everyone for your thoughtful responses. This is very helpful.
Rob
Rob
2016 Classic
ProPride
Sewer solution to home sewer-so difficult? lsbrodsky Plumbing - Systems & Fixtures 39 05-05-2018 09:35 PM
Attention New to Airstream owners - sewer line outlet info - Thetford sewer systems Catman6 Waste Systems, Tanks & Totes 29 04-01-2011 05:22 PM
Airstream Specifications and Floorplans TinShack Airstream History 0 07-21-2010 10:07 AM
Staining Sewer vent from sewer gas TheProfessor Cleaning, Stripping & Polishing 6 02-16-2008 01:42 PM
New and looking for specifications. bill_bravo Member Introductions 4 08-07-2006 08:35 PM
