Old 12-27-2013, 08:56 AM   #1
1971 18' Caravel
Westminster , Maryland
need instructions with photos to winterize
I need detailed instructions, with good photos, to winterized my
1971 Air Stream.
Does anyone know where I can get them?
Thanks for the help.
sweetdlb is offline   Reply With Quote
Old 12-27-2013, 09:09 AM   #2
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
Bosque Farms , New Mexico
There are several YouTube videos on the topic. Just type "winterizing RV" into their search box.
Lynn
WBCCI 21043
Old 12-27-2013, 09:15 AM   #3
1981 31' Excella II
New Market , Alabama
Well the chance you will find photos and instructions with your exact plumbing layout are small. There are two ways to do this. One is to blow out the lines and the other is to fill the system with antifreeze. I use the first method but there are some in colder climates that prefer the antifreeze method. Anyone can blow the lines out. All you need is an adapter that hooks to the hose connection and has a quick disconnect for an air compressor on the other end. You can put one together from parts at Lowes or Home Depot. You need to drain the water heater and then reseal it. You set the regulator to about 60psi and let the pressure build up and then open valves till little or no water comes out. Do this several times and come back to places you have purged before and do them again. Pay special attention to low points like the toilet flush valve. Also don't forget the shower. You may find a low point drain outside under the trailer where the tanks are and you can open that as well. Not a bad idea to pour some antifreeze in the drain traps.
Perry
Old 12-27-2013, 09:49 AM   #4
retired USA/USAF
2001 30' Excella
Somerset , New Jersey
AND don't forget to remove any water filter elements you may have. I had one built into the kitchen sink fixture. Moen no longer supports these and replaced mine with a similar type faucet, no filter and pull out sprayer. We also have a previous owner installed whole house filter. I keep xtras on hand and put in a new one for the spring.
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
polarlyse is offline   Reply With Quote
Any Photos Out there? bevman Airstream History 4 06-28-2011 07:58 PM
Bug report: Blogs link broken from Photos pages DKB_SATX Forum Admin, News and Member Account Info 1 04-21-2011 07:42 PM
Vintage Photos mwells4654 Off Topic Forum 4 04-12-2011 09:28 AM
Need curtain track photos circa '79 blickcd Upholstery, Blinds, Walls & Interior Finishes 5 01-11-2011 05:06 PM
