Old 11-13-2007, 03:47 PM   #1
1998 30' Limited
garden Ridge , Texas
Need Advice - Airstream hangar
I have a 50 acre piece of property in the country, and am thinking about building a metal building out there to put my airstream in and also to have as a shop building for all of my tools, etc. I am thinking about a pretty good sized building..like 40 x60 or so. We will likely be building a house out there next year or two. Have any of you built a building like this to store your trailer in and maybe to live in while the new house is being built? Thanks in advance for any ideas you may have.
Rudy
Crawdad is offline   Reply With Quote
Old 11-13-2007, 04:10 PM   #2
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
I have one
I have one you might like. Its 40 x 40 x 14 (wall height). I have it split into a drive thru, big sliding doors at both ends, and the full length of the other side is made into an apartment with bath, kitchen and living area. I put in a patio door on the side from the living area for access to a small outside patio. This living area has a structural ceiling alowing me to use the upper area as a storage/work area. I had the entire structure interior ...a metal building, sprayed with 2 inches of foam insulation...the ridgid type with no outgassing or fire problems. All the walls and ceiling of the living half are insulated too. A hanging propane heater is used in the outer area and a window A/C with heat strip does a great job for the living side. I did not plumb it for a dump...but it could have been very easily.
Old 11-13-2007, 04:23 PM   #3
1998 30' Limited
This sounds like what we are thinking about building. I like the idea of being able to store stuff above the living area. Do you actually live in the metal building? We have considered making an apartment in ours also, but then got to thinking that the 30 foot airstream trailer takes care of that need.
Thanks for the response
Old 11-13-2007, 04:42 PM   #4
Phil/Edee's Avatar
1999 25' Excella
Bemidji , Minnesota
Sounds like what we were thinking about but !! ours would be in Minnesota (mostly in the summer) and we were thinking about stick built instead of metal. ??? Do you have pictures???
Thanks!!!
Phil & Edee
“Cats and dogs are magical creatures... just petting one can make both of you live longer!"
Phil/Edee is offline   Reply With Quote
Old 11-13-2007, 05:47 PM   #5
lewster's Avatar
Naples, FL , Hood River, OR
Phil,
Search the site for 'Airstrem Haven' posts that klevan did. He built what you are looking for in Albuquerque, NM. I was there before he sold it. Great building and shop!
Old 11-13-2007, 06:30 PM   #6
bibbs's Avatar
1977 Argosy Minuet 6.0 Metre
1973 21' Globetrotter
1975 26' Argosy 26
Vista , California
That sounds just right for size,If you are planing on some heat put it in the floor. ohhh so nice working on a warm floor! My barn is 22x50 and a little tight with the extra junk I cant help acculmating.
Doug
bibbs is offline   Reply With Quote
Old 11-13-2007, 06:37 PM   #7
HowieE's Avatar
Princeton , New Jersey
Images: 12
Consider more that one overhead door. One off center for the trailer and another for general use. Plus a personnel door.
2004 Excursion 4x4
Old 11-13-2007, 06:46 PM   #8
Zeppelinium's Avatar
1975 31' Sovereign
1977 23' Safari
Palmer Lake , Colorado
Rudy,
I just rented space in a very nice barn for my Safari restoration. The first thing I noticed was that it wasn't that easy to back the trailer into a spot along the side using only a center door.
Wherever you plan to put the trailer workspace, make sure you've got enough height to jack up the frame at least 10" and then raise the shell another 3-4' above that (that's a total of 15' clearance). The beams above this spot need to be able to hoist 500 lbs (considering that you may not want to dismount the inner skins, air conditioner, and upper cabinets).
Run a couple of air lines in the vicinity, as well as provide enough electrical power to test the air conditioner (I've found a 20 amp circuit is sufficient, but it's probably right on the edge).
One of the very best things you can do is put in a dump pipe into your sewage system, both inside the barn and outside in a likely parking spot. It's great to have your own and makes the Airstream into a guest house, if need be.
Zep
Old 11-13-2007, 07:50 PM   #9
1998 30' Limited
Lew,
Thanks for sending me to the thread by klevan. That is a great building and helps me to begin to picture what mine will look like. I really like the idea of a 12 x 14 door so that it can accomodate whatever I choose to own in the future.
Old 11-13-2007, 08:42 PM   #10
millvalleyca's Avatar
2008 27' International CCD FB
Mill Valley , California
Hey Crawdad..have you seen the ad for Uncle Howards RV buildings on this website? I wish I had the land where I could build one.
millvalleyca is offline   Reply With Quote
Old 11-14-2007, 02:44 PM   #11
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Quickie Pics
Here are some quickie pics. 'scuse the mess.
The access to the upstairs is a wide stairway right inside the main walk thru entry....beside the entry door to the living area. Hope this helps. This type structure has become a very popular one recently. Lots of folks using them for Hangar homes.
ID:	49346   Click image for larger version
Name:	Interior small barn.jpg
Name:	Small Barn inside.jpg
Old 11-14-2007, 04:21 PM   #12
Mikethefixit's Avatar
1977 27' Overlander
Trotwood , Ohio
Send a message via Yahoo to Mikethefixit
CrawDad
I have a 30x40 Taint big enough. U mentioned 40x60 that sounds better. Consider this ,depending on the site U choose to locate your home. Incorporate it into the building.
We just bought our Airstream and the PO had a gerogious home built for his mother, and the outside was a pole barn. It has a great front porch with cedar railings and the interior OMG I wish I had taken pictures. It was just lovley with hardwood floors ,bathroom laundry room combo and two bedrooms down and a possible 3rd or 4th bedroom up. It was just beautiful.
The possibilitys are endless.
Good Luck
Roger
Mikethefixit is offline   Reply With Quote
Old 11-15-2007, 06:35 AM   #13
1998 30' Limited
Thanks so much for the pictures. I cant wait to show them to my wife. We have considered putting the apartment inside the building instead of a separate free standing house. We will have to really compare the savings of putting the apartment in the metal building instead of a separate structure. I think my preference would be to have them separate unless the savings are really significant. If we build a house it would be approximately 2000 square feet. We are empty nesters about to retire and our kids and grandkids will live on the ranch also, so we probably can't get buy with just an apartment sized house. Thanks again for the suggestions and pics.
Old 11-15-2007, 07:13 AM   #14
Images: 14
consider the rain noise.....
I have a metal (red iron) building. It has one layer of insulation next to the skin. When it rains hard it is very noisy inside. If I were to consider putting living quarters inside this building I would have to sound proof the interior rooms to be comfortable.
bjond is offline   Reply With Quote
Airstream Hangar finally completed alvinator Winterizing, Storage, Carports & Covers 35 11-17-2007 04:21 PM
airstream newbie needs advice Crawdad Our Community 7 12-01-2006 08:27 AM
Forum or Airstream for advice? ldetsf Off Topic Forum 5 11-10-2006 07:03 AM
Airstream Newbies Need Advice Mark&Leslie Member Introductions 7 08-16-2006 07:53 AM
Advice on a first Airstream? indefatigabl 1960 - 1964 Overlander 13 02-09-2006 07:33 PM
