Old 11-01-2006, 07:38 AM   #1
Naysayer
Boondocker's Avatar
1968 24' Tradewind
Louisville , earth
Send a message via Yahoo to Boondocker
My latest bad idea....
I want to extend my season in the Trade Wind. I'm thinking if I have cold water in the galley sink that should be sufficent to limp along. So..... say a guy was to put a valve in the the water line just past the galley sink, and winterize everything behind that (bathroom, water heater). I think it would be a lot more manageble to keep the tank to sink section in operation in the cold. Water could be toted to the toliet to operate that. grey and black tanks could be drained when the weather gets to cold and antifreeze added. So tell me where this plan falls apart.
Rodney
Visit my photography page
and the
Favorite camp grounds project map
My Blog
(The artist formerly known as General Disarray)
Boondocker is offline   Reply With Quote
Old 11-01-2006, 07:58 AM   #2
Zeppelinium's Avatar
1975 31' Sovereign
1977 23' Safari
Palmer Lake , Colorado
Rodney,
Not a problem! I do this type of thing routinely by cutting off the water heater and toilet (the toilet is really the biggest problem to drain if you don't have an air compressor to blow out the system--the water heater is a problem because to drain it is to waste 6 gallons of water). See my valves in
http://www.airforums.com/forum...ign-23313.html
Note my last post--the problem with backflow in the sink fixture. Make sure this doesn't happen in yours or you'll have water in the hot side pipes. You'll also get water on the hot side if you're not really really careful when you use the faucet (if it's a single handle type). Any crack towards warm and you've opened the hot side valve, allowing cold water to flow through the fixture into the hot pipes.
I think it's a better idea to just count on draining both sides or isolating the hot to the kitchen, just as you plan to do the cold. My Overlander and Caravel have copper, so I have a drain (hot and cold) under the kitchen and two (hold and cold) near the bath, so no matter if I have a little slope where I'm parked, I can drain everything.
One nice thing about isolating the kitchen is that those lines are all visible, not under the shower or behind the bed or some other place where you're not sure what the temperature is.
Roger
Old 11-01-2006, 08:10 AM   #3
Naysayer
Boondocker's Avatar
1968 24' Tradewind
Louisville , earth
Thanks! I hadnt thought about the problem of mixing the hot and cold, but thats ok because mine are old style two valve types. Your last coment about not knowing about the temp of waterlines is well taken; I'm thinking the approach of turninging off everyting aft of the kitchen would only leave me about 6 ft of lines to worry about.
Rodney
and the
My Blog
Old 11-01-2006, 08:12 AM   #4
Chaplain Kent's Avatar
1994 30' Excella
Milwaukee , Wisconsin
We camp all winter in Wisconsin and have never had a freeze up. I detailed my "winterizing" technique in the current anti freeze thread. Keep you hot water tank working in the winter, you'll appreciate the hot water on a cold day.
Chaplain Kent
2015 Coachman Freedom Express 19RBS, Chummy IV- Ford Excursion- 7.3 Turbo-diesel
Chaplain Kent is offline   Reply With Quote
AirstreamForums.com Member Sticker? Andy R Our Community 171 06-08-2007 10:12 AM
New idea for Cabinets. spaceghost65 Cabinets, Counter Tops & Furnishings 11 08-06-2003 07:13 PM
latest design concepts 53flyingcloud Our Community 3 06-29-2002 10:33 AM
