01-06-2016, 03:00 PM
begorragirl
2017 25' Flying Cloud
Denville
, New Jersey
My Anti-Freeze Froze
How is it that my anti-freeze froze. I get my AS winterized by a dealer. I always add extra to the grey and black tanks, the jugs were outside, we had our first cold weather of the season two days ago, when my husband went to pour it in, it was frozen. I use Walmart brand pink anti-freeze. Any ideas?
2006 Bambi CCD ("EireStream!!")
2010 Funfinder
2005 T@B
2001 Teardrop, Mountain Hardware Tent
For some perfection takes a little longer...
01-06-2016, 04:03 PM
Rivet Puller
2003 28' Safari S/O
Atlanta Burbs
, Georgia
Mixed and packaged off shore?
Sir Tristan
Air #48582, S/SO #003, WBCCI #4584
01-06-2016, 04:20 PM
2007 22' International CCD
Corona
Buy better antifreeze😄
01-06-2016, 04:25 PM
Retired.
, At Large
There's a reason it is only $2.50/gal. Seriously. I got some, and it was pretty much pink water.
01-06-2016, 04:28 PM
Figment of My Imagination
2012 Interstate Coach
From All Over
, More Than Anywhere Else
Not all antifreeze is created equal. Check the temperature it's good to before you buy. It should be marked on the label. The good stuff protects to -50°F.
Also, antifreeze that has been mixed with water provides lesser protection. The rated temperature is only for pure antifreeze.
01-06-2016, 04:33 PM
2000 25' Safari
Davidson County
, NC Highlands County, FL
That's a question I would ask the dealer that did your work. BUT,
You said two things:
1. winterized by a dealer
2. I use Walmart brand pink antifreeze
You bought antifreeze and took it to the dealer?
Or, did the dealer winterize the trailer with their antifreeze and you poured the Walmart antifreeze into the tanks.
Which part froze?
I've used Walmart brand many times. My trailer winterized with it did not freeze at -5F last year.
Alan
01-06-2016, 04:53 PM
1998 30' Excella 1000
Livingston
Was that the Supertech stuff? While it is supposed to have burst protection down to -50 degrees, I understand it gets "slushy" at much higher temps. Was it just too slushy to pour out of the narrow opening?
If frozen solid, then it sounds like a faulty mix/bad batch from the factory.
01-06-2016, 05:06 PM
From All Over
That is an excellent point. Antifreeze doesn't necessarily provide protection by remaining liquid. It provides protection by not expanding as it gets colder.
Water is one of the few materials in nature to expand when it freezes. Most other natural and manmade liquids contract when they freeze, and so will not harm your pipes even if frozen solid.
01-06-2016, 05:08 PM
Senior Member
2012 27' FB Eddie Bauer
Sparks
, Nevada
Sounds like it's time to head south!
2015 F350 CC 4X4 6.7 Diesel
2010 27FB Silver Cloud "The Silver Spoon"
01-06-2016, 05:17 PM
Retired.
, At Large
The stuff I got was the Supertech stuff. It froze at 20 degrees. I can't answer for the OP, only my own experience.
01-06-2016, 05:31 PM
begorragirl
Denville
, New Jersey
Here area swers to your questions
- I got winterized at dealer
- I have always added extra on my own to be extra safe in grey and black tank
- I purchased three bottles of pink at. walmart
- we have had very mild winter except last two days
- I asked husband to put jugs in drains
- since I purchased in November, the jugs sat in driveway near AS
- Dennis reported the jugs were frozen solid
- he brought them i side to thaw
- I have no idea where to purchase better RV fluid
- the frozen jugs were not misshaped like a bottle of water would be
- all seems odd, I thought Antifreeze did not freeze
- all three jugs froze
2010 Funfinder
2005 T@B
01-06-2016, 05:32 PM
begorragirl
Denville
, New Jersey
It was rated -50 degrees
2010 Funfinder
2005 T@B
01-06-2016, 05:50 PM
2015 30' FB FC Bunk
Ayer
, Massachusetts
RV antifreeze freezes, it just does not expand. You are fine.
01-06-2016, 05:57 PM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
If it frozed in the bottle it will freeze in the lines...that's my reason for blowing the lines for at least 20min @ a steady 30psi, pump AF thru and blow again 'til it mists pink.
I gave up on the WallyStuff 8yrs ago after it froze in the toilet and ruined the flapper seal. The bowl now gets 1/8 cup or so of Crisco veggie oil.
01-06-2016, 06:09 PM
begorragirl
Denville
, New Jersey
I think I will add oil too, I had new seal put in last year, they are tender and need care.
2010 Funfinder
2005 T@B
01-06-2016, 06:21 PM
Western
, Massachusetts
I've tried both the good quality antifreeze for marine use and the wally world stuff. The latter is garbage. I used it once and it took forever to rinse out after winterizing.
Your local chandlery or West Marine carry really good quality antifreeze. That said, we no longer use it now that we have drains in all low points and blow the entire system out well. Colin Hyde describes the technique well in one of thevap episodes.
01-06-2016, 06:33 PM
From All Over
Antifreeze rated for -50°F has a freeze point of +12°F (I just now looked it up). That's when it starts to form slush, ice crystals in a liquid suspension. Antifreeze is a eutectic mixture, made of components with different melting/freezing points. It starts to freeze at +12°F— forming a slush— and finishes freezing at -50°F— forming a solid.
It's important to shake antifreeze thoroughly before use because otherwise the components can separate and develop a frozen layer along with a liquid or slush layer, and thus provide a lesser degree of protection. That's probably what happened with the OP's jugs. They were left to sit, and the components separated. One component froze.
I thank the OP for starting this thread. It gave me a chance to learn something new.
01-06-2016, 06:46 PM
2015 30' FB FC Bunk
Ayer
, Massachusetts
I recall there are two basic kinds and a third which blends the two. Ethenal (SP?) is the worst which is flammable and ruins seals and poly- something or other which is better. Then I read they recapture some of it and resell but it may have foreign chemicals in it, so they say get virgin stuff
After much research I found the Prestone to be the virgin good stuff.
01-06-2016, 07:00 PM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
Just add the veggie oil, no AF, water or other stuff.....I tried Olive oil, it worked but I couldn't get used to the tas...never mind.
01-06-2016, 07:06 PM
begorragirl
Denville
, New Jersey
Thanks ProtG, what u say makes sense, off to fine a better grade then add my veggie oil. I was spouled by our mild weather. The night it frozrpe it wS4' with lots of wind, factor wind chill and, selarTion od ingredients and bingo.
2010 Funfinder
2005 T@B
