Old 01-06-2016, 06:09 PM   #15
Sbb
begorragirl
Sbb's Avatar
2017 25' Flying Cloud
Denville , New Jersey
I think I will add oil too, I had new seal put in last year, they are tender and need care.
2006 Bambi CCD ("EireStream!!")
2010 Funfinder
2005 T@B
2001 Teardrop, Mountain Hardware Tent
For some perfection takes a little longer...
Sbb is offline   Reply With Quote
Old 01-06-2016, 06:21 PM   #16
65CV's Avatar
Western , Massachusetts
I've tried both the good quality antifreeze for marine use and the wally world stuff. The latter is garbage. I used it once and it took forever to rinse out after winterizing.
Your local chandlery or West Marine carry really good quality antifreeze. That said, we no longer use it now that we have drains in all low points and blow the entire system out well. Colin Hyde describes the technique well in one of thevap episodes.
65CV is offline   Reply With Quote
Old 01-06-2016, 06:33 PM   #17
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Originally Posted by ROBERT CROSS View Post
If it frozed in the bottle it will freeze in the lines...that's my reason for blowing the lines for at least 20min @ a steady 30psi, pump AF thru and blow again 'til it mists pink.
Antifreeze rated for -50F has a freeze point of +12F (I just now looked it up). That's when it starts to form slush, ice crystals in a liquid suspension. Antifreeze is a eutectic mixture, made of components with different melting/freezing points. It starts to freeze at +12F— forming a slush— and finishes freezing at -50F— forming a solid.
It's important to shake antifreeze thoroughly before use because otherwise the components can separate and develop a frozen layer along with a liquid or slush layer, and thus provide a lesser degree of protection. That's probably what happened with the OP's jugs. They were left to sit, and the components separated. One component froze.
I thank the OP for starting this thread. It gave me a chance to learn something new.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 01-06-2016, 06:46 PM   #18
2015 30' FB FC Bunk
Ayer , Massachusetts
I recall there are two basic kinds and a third which blends the two. Ethenal (SP?) is the worst which is flammable and ruins seals and poly- something or other which is better. Then I read they recapture some of it and resell but it may have foreign chemicals in it, so they say get virgin stuff
After much research I found the Prestone to be the virgin good stuff.
Ted S. is offline   Reply With Quote
Old 01-06-2016, 07:00 PM   #19
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Cool
Just add the veggie oil, no AF, water or other stuff.....I tried Olive oil, it worked but I couldn't get used to the tas...never mind.
but Im the Husband, so we went to Cleveland. 😘
RLC
Its a crooked piece of time that we live in.
John Prine
Old 01-06-2016, 07:06 PM   #20
Sbb
begorragirl
Sbb's Avatar
Thanks ProtG, what u say makes sense, off to fine a better grade then add my veggie oil. I was spouled by our mild weather. The night it frozrpe it wS4' with lots of wind, factor wind chill and, selarTion od ingredients and bingo.
2010 Funfinder
2005 T@B
Old 01-06-2016, 07:35 PM   #21
More fun facts to know and tell wind chill makes absolutely no difference to when something freezes.
Here's an example that illustrates the point, using the National Weather Service wind chill chart for reference At a temperature of 40F, above freezing, a wind of 30mph lowers the wind chill to 25F, supposedly below freezing. Will water freeze under these conditions? No, because regardless of the wind chill, the actual temperature is still 40F. Wind chill affects how fast something gets cold, but doesn't allow anything to get colder than the actual temperature.
WBCCI #1105
TAC LA-4
Old 01-06-2016, 07:44 PM   #22
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
Originally Posted by Protagonist View Post
...Most other natural and manmade liquids contract when they freeze...
George Costanza would definitely agree with this statement!
Bob Martel
WBCCI# 5766
Old 01-06-2016, 11:24 PM   #23
crisen's Avatar
2012 25' FB Eddie Bauer
Fairbanks , Alaska
I've tried every brand available in Fairbanks and the are all solid by -15F. As said they don't expand but are way past slush.
Rick
"When you find yourself in a hole - quit digging!"
2012 1/2 Eddie Bauer, 2016 Ram Laramie 3500 SWB 4x4 6.7L Cummins 68RFE
crisen is offline   Reply With Quote
Old 01-07-2016, 08:02 AM   #24
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
Try using cheap vodka. It will never freeze and leaves zero taste in the plumbing. Been doing this in my Airstreams for 25 years!
Old 01-07-2016, 08:14 AM   #25
Not true. 80-proof vodka freezes at about -16F. 100-proof vodka freezes at about -40F but that's certainly not the cheap stuff! 190-proof Everclear freezes at -173F, providing adequate protection even for the great frozen North as long as it's not in contact with anything made of rubber. And because vodka only has two ingredients, ethyl alcohol and water, the high water content (60% water for 80-proof, 50% water for 100-proof) means that vodka will expand when it does freeze.
Alcohol has the effect of drying and cracking rubber seals over time, unlike RV antifreeze.
WBCCI #1105
TAC LA-4
Old 01-07-2016, 08:33 AM   #26
1999 30' Excella 1000
small town , Maryland
A Airstream with two wet bars. Let me know when you have the dewinterizing party
streaminwild is offline   Reply With Quote
winterizing - removed water filter - will it leak anti-freeze? Pudentane Fresh Water Systems 8 02-19-2013 09:39 PM
Water Dripping From Fan During Freeze/Thaw/Freeze/Thaw Fly at Night Roof Vents, Skylights & Fans 5 12-16-2011 10:54 AM
Remove Anti-Freeze Stains In Shower DEITZ645 Sinks, Showers & Toilets 4 03-23-2008 02:32 PM
Is anti-freeze required to winterize? guy99 Winterizing, Storage, Carports & Covers 17 11-23-2006 08:34 AM
No Anti-freeze smily Plumbing - Systems & Fixtures 8 04-15-2003 11:11 AM
