Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Winterizing, Storage, Carports & Covers
Old 01-18-2007, 03:30 PM   #1
campadk
campadk's Avatar
Profile:  2007 19' Bambi
Ottawa , Ontario
My Airstream Won't Fit in the Garage!
I know our Bambi won't fit in our itty bitty single car garage.. but I have discovered the solution...
We're going to BUY A NEW HOUSE!
So my question is what is the height, overall width and overall length including tongue of a 19ft Bambi? (can't measure ours.. its in storage).
I'm thinking of a house with a double wide garage with extra height... or ability to maybe increase the entrance to accommodate.
My our Bambi is sooo spoiled!
Dave
Camp ADK
Our Bambi - The 40 Winker
campadk is offline   Reply With Quote
Old 01-18-2007, 03:39 PM   #2
wahoonc
Rivet Monster
wahoonc's Avatar
Profile:  1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 35
Dave,
I am not sure about the new ones but the 70's vintage will clear a 10'-0" door with inches to spare. Overall length on a 19' Bambi should be pretty close to 19' I would get a 12' high by 40' long garage...then you can upgrade to a Classic
Aaron
WBCCI #2449 AIR #2495
Old 01-18-2007, 03:39 PM   #3
Silvertwinkie
Aluminut
Silvertwinkie's Avatar
Profile:  2004 25' Safari
Northern Suburbs , Illinois
I would say 10' tall. I think Airstreams are about 9.5' tall, so 10' would be the min I'd have.
If you plan on ever upgrading to a wide body (25' or larger newer Airstream) I would say you'd want about a min of 9.5' in width.
If you stay with the 8' wide Bambi or non widebody, then I'd say 9 feet. That will give you 6" of clearance on each side.
Depth of the garage would depend mostly on what you might have in the future.
Old 01-18-2007, 03:42 PM   #4
smccollister
04Bambi
smccollister's Avatar
Profile:  2004 16' International CCD
Santa Barbara , California
Would 10' also include the A/C unit at the top? I have a 2004 Bambi 16ft CCD.
smccollister is offline   Reply With Quote
Old 01-18-2007, 03:48 PM   #5
rickandsandi
Always Airstreaming!
rickandsandi's Avatar
Profile:  2005 22' Safari
1960 24' Tradewind
Anytown , Connecticut
New House
We actually have some houses near us that have RV garages in their houses. They have two standard garage doors and one RV door. Your AS is actually 19.5' from tongue to bumper, 96" wide and 9.5' tall. Of course you will need navigation room and walkaround.
Make sure that if you are north that it is heated and south, that it is A/C!
J. Rick Cipot
Sandi Gould
NEU New England Unit
Airstream Life Magazine
WBCCI #3411
AIR #17099
rickandsandi is offline   Reply With Quote
Old 01-18-2007, 03:48 PM   #6
Silvertwinkie
Aluminut
[quote=smccollister]
quote]
Yes. Most of the newer Bambi line is between 9.4' and 9.5' per the Airstream website. The Classics are about 9' 7". So, 10' would cover it, but that would be the minimum height I'd suggest. If you could go 11', that would give you a wider margin for error if you replace an A/C unit that is taller or upgrade to a Classic someday and say you want to put on an accessory....if you plan on ever getting a sat dome, then you'd want much more than a 10' high opening regardless if you had any Airstream.
Old 01-18-2007, 03:58 PM   #7
campadk
campadk's Avatar
Ottawa , Ontario
Great! Thanks all. I'm now ready to go measure a bunch of garages attached to houses for sale
Dave
Camp ADK
Old 01-18-2007, 03:59 PM   #8
wahoonc
Rivet Monster
wahoonc's Avatar
1980 31' Excella II
Images: 35
It does on mine...I think the normal road height on mine is 9'-7"...if all else fails load it down to compress the suspension and/or let some air out of the tires
Aaron
Old 01-18-2007, 04:00 PM   #9
Silvertwinkie
Aluminut
Good luck...not a lot of houses have this as an option in the suburban parts around here, at least attached. Even the one's that I've seen in the rural areas are most mostly detached...I'm thinking that's the case because it's hard to incorporate a 30' deep part of the house and a 10' door into a house design....
Old 01-18-2007, 04:14 PM   #10
RUSSELL
Desert Fox
Profile:  1985 31' Sovereign
Tucson , Arizona
Smile My Bamby will not fit
Hi dave,
If you are going to buy a new house with a garage that will hold your trailer, buy one that has at least 12 foot doors and is at least 50 feet deep. This way you can park your tow vehicle and trailer in the same place. My rv garage has 16 foot door, is 50 feet deep and 16 feet wide. This gives me enough room to park our AS and the jeep, but not enought room for the tow vehicle and trailer. For this I would need about 55 feet lenght.
Regards Russell from Tucson Az.
RUSSELL is offline   Reply With Quote
Old 01-18-2007, 05:23 PM   #11
Royce
Royce's Avatar
Profile:  1977 Argosy Minuet 6.0 Metre
Colorado Springs , Colorado
While you are looking, remember to get the pull through model. Doors at both ends.
Royce (K0RKK) and Karen
AIR# 3913
Royce is offline   Reply With Quote
Old 01-18-2007, 06:05 PM   #12
CanoeStream
CanoeStream's Avatar
St. Cloud , Minnesota
Images: 13
Hi Dave -- Airstream lists the length as 19' 2". Garage door widths usually come in even multiples down here in the "South" -- so 8' or 10' wide. I have the widebody and there is a 10' wide door at our storage garage. Sweet! I've backed the 7'10" wide Argosy into a garage with a couple inches clearance on each side and can virtually guarantee you'd want at minimum a 9' wide door. I won't even begin to suggest that you'd ever move away from your 8' wide 75th Anniversary ultra-Bambi!
Old 01-18-2007, 06:42 PM   #13
clancy_boy
clancy_boy's Avatar
Profile:  2003 22' International CCD
1966 17' Caravel
Kiln , Mississippi
Images: 8
Remember - the 10 foot in high door is probably only good if there is little or no slope to the driveway - that 4-5 inches of comfort goes away with the trailer going in at an angle, up slope is bad. Good advice is to let some air out - just remember to inflate once in and then LET THE AIR OUT to pull out.
Wish I had built my garage after I bought my AS instead of before. Oh well, I need another building.
Michael and Tina BZ
1966 17' CARAVEL
2003 22' INTERNATIONAL CCD
WBCCI 30962
><((((º> ¸.·´¯`·.¸¸><((((º> ¸.·´¯`·.¸¸><((((º>
¸.·´¯`·.¸¸><((((º> ¸.·´¯`·.¸¸><((((º>¸.·´¯`·.¸¸><((((º>¸.·´¯`·.¸¸><((((º>
Old 01-18-2007, 06:57 PM   #14
flyfshr
flyfshr's Avatar
Profile:  1959 24' Tradewind
Phoenix , Arizona
That's funny Dave, we came to the same conclusion. Now we're looking for a new house for us and later on for building a two bay RV shop/garage.
FF
WBCCI/VAC #2699
Air #10
I'm haunted by aluminum.
http://www.airztream.com
http://59tradewind.blogspot.com
flyfshr is offline   Reply With Quote
Airstream vs. Avion? 68 Suburban Vintage Kin 29 11-21-2008 08:35 AM
Cost to restore a gutted Airstream Draco General Interior Topics 19 02-06-2007 02:04 PM
future airstream motorhome betteleal Airstream Motorhome Forums 11 02-12-2005 02:39 PM
Airstream Related List Servers Andy R Link Archive 0 02-22-2002 03:05 PM
AirstreamTrailers.com - Airstream Link Library Andy R Link Archive 0 02-22-2002 02:31 PM
