Old 01-27-2015, 01:26 PM   #1
2008 20' Safari SE
Cerrillos , New Mexico
Mouse Proofing
I am looking for any suggestions regarding mouseproofing. We live in the country and this winter it is especially bad. I've looked for any openings but they are still getting in. Any suggestions would be appreciated. Thanks,
Lou in New Mexico
lkeniley is offline   Reply With Quote
Old 01-27-2015, 01:28 PM   #2
TinTin's Avatar
2009 23' FB Flying Cloud
Canmore , Alberta
You could check for small openings in wheel wells and belly pan. Apply the mouse-proofing foam that comes in spray cans to any openings you find. Ensure there is zero food in the trailer. A few traps inside as backup might be a good idea as well.
I used this stuff in the fall:
http://www.homehardware.ca/en/rec/in...Expanding+Foam
Bob and Nancy
http://www.rwcphoto.smugmug.com
Cheer Up, Slow Down, Chill Out!
TinTin is offline   Reply With Quote
Old 01-27-2015, 01:41 PM   #3
2005 25' Classic
1986 32' Excella
1965 22' Safari
Newark , Delaware
I have been lucky with dryer sheets stuffed into any access point. I guess mice hate the smell of clean laundry. Back up traps are always a good idea.
Chatooga11 is offline   Reply With Quote
Old 01-27-2015, 01:51 PM   #4
DaveFL's Avatar
2000 31' Land Yacht
Central , Florida
Use the second search bar in the drop down above, google does a much better job of searching this forum. Once they are in traps with bait are ok but before advice above stated no food in the camper, that includes bait.
If you can push a pencil in the hole that is all the head room they need, I found one pushed by my electric cord openings, I now wrap the cord with steel wool. My guess is that all electric and plumbing lines penetrating shell are made by a hole specialist worker at AS that doesn't know what the hole is for so just make it big and the guy using the hole if it is off center will make another Carpet guy was responsible to fix, sort of like in housing where it is all left up to the painter.
Old 01-27-2015, 01:58 PM   #5
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
Lou in New Mexico
I don't believe that there is really a way to make anything mouse proof. But poisoned bait OUTSIDE is a good way of keeping them out. I know everyone says, "but what if a small child gets into it?" Well IMHO, it's easier to CHILD proof something than it is to mouse proof it. Buy a cheap lockbox and drill a couple of 5/8" holes in it, lock it with a big hunk of poisoned peanut butter inside. Write - "mouse poison" on it in red paint, and chain it to the trailer tongue, hiding it discreetly behind a stabilizer jack. Renew the poison about every 10 days. You won't see too many carcasses, they go back to their dens to die.
Traps with peanut butter under the Airstream work, but you might get a dog or a coyote or two.
Paula
Old 03-04-2015, 08:45 PM   #6
1965 mustang's Avatar
Stoughton , Wisconsin
If you park inside, put glue traps all the way around the wheels and tongue jack. I found some that are about 3"x9". You need four for each wheel. Peppermint oil on the inside seems to help or at least makes things smell good.
1965 mustang is offline   Reply With Quote
Old 03-04-2015, 10:09 PM   #7
1974 Argosy 20
Kooskia , Idaho
You can try to keep them out of the bellypan area, but that is very very difficult. Too many entrances from the tongue to the rear storage compartment.
My experience is that Airstream has always put much bigger holes through the plywood subfloor than the pipes that go through them need. So, there is a great mouse highway along the drain and vent pipes. Also if you have heat from the furnace going into the tank area, the holes for the heat pipes are too big. So, find all the places that holes go through the sub floor, and seal them with brass wool, expanding foam, metal plates or whatever it takes and you will probably make your rig mouse resistant.
Old 03-05-2015, 05:57 AM   #8
64airstream's Avatar
1964 22' Safari
1968 26' Overlander
Beaver County , Pennsylvania
Lou,
Another product you may want to consider is Fresh Cab. They are pouches of botanical rodent repellant that don't smell bad to humans. Typically farmers use them to keep mice out of their tractor cabs. We've been using them for a few years and they seem to be working well. We even use them in the convertibles while they're stored during the winter. We use 3 or 4 in the A/S and 2 in each car. Fresh Cab is not cheap (for a little bag of potpourri) but it's probably available at your local farm store or a big hardware store. Also available online, although I haven't tried that.
Good luck,
Roy and Marie
64airstream is offline   Reply With Quote
Old 03-05-2015, 06:00 AM   #9
I also heard stuffing steel wool in the frame openings by the ball hitch helps. It is apparently a path to the underbelly. And keep things SQUEAKY clean inside. Haha 😀
Old 03-05-2015, 06:13 AM   #10
paiceman's Avatar
Upper St Clair, PA/Titusville, FL , PA-Summer/FL-Winter
Dryer sheets work for us, SO FAR. I also grease the tongue where it comes out of the A frame and we put dryer sheets in a number of places inside the AS. Used to put traps inside but I actually think that drew them into the trailer. We park in a storage yard on Asphalt and my guess is the little buggers don't like to cross the open area day or night for fear of hawks in day time and owls at night. Several people are backed up to the fence which abuts woods and they have lots of mice issues.
SAFE TRAVELS
Bud
2017 30' Classic - F350 6.7 Diesel Crew
USAF - Military Training Instructor (TI) - 68-72
Old 03-05-2015, 06:48 AM   #11
LiLNomad's Avatar
2007 25' International CCD FB
Northridge , California
Im still using cottonballs with peppermint oil in cabinets, drawers, closets etc and havent had a problem, trailer always smells good. I park on a dirt lot and was concerned bout this same issue. The peppermint messes with their sense of smell.
LilNomad
LiLNomad is offline   Reply With Quote
Old 03-05-2015, 07:05 AM   #12
thehandyman's Avatar
1980 24' Caravelle
corpus christi , Texas
You will find things like this. Shower drain opening just off a little. Problem is it is hard to find these unless you pull the belly pan.
thehandyman is offline   Reply With Quote
Old 03-05-2015, 07:44 AM   #13
1982 31' Airstream 310
Athens , Illinois
I use the electric rodent it puts of sound waves I love it an it works my neighbors are cows I'm way in the boonies but love it
foxybabies is offline   Reply With Quote
Old 03-05-2015, 07:47 AM   #14
1999 28' Excella
New Orleans , Louisiana
I have used the peppermint cotton balls..worked most of the time. Found a product recommended on someone's blog that is excellent. FreshCab..put it in outside compartments and I would not be a full-timer without it.
badkat is offline   Reply With Quote
Ant and Mouse Proofing Laurel62 Winterizing, Storage, Carports & Covers 11 09-25-2013 12:56 PM
Rodent-proofing for storage zimbop Winterizing, Storage, Carports & Covers 10 10-05-2007 07:54 AM
Baby-proofing: screen door grille Chuck Doors & Locks 9 07-27-2004 01:17 AM
Rust Proofing danesh Repairing/Replacing Floor &/or Frame 5 11-18-2003 11:59 AM
Water proofing Rob Leaks - Weatherstrips, Gaskets, Caulks & Sealants 1 08-31-2002 09:37 PM
