Old 02-10-2013, 02:47 PM   #1
2012 25' Flying Cloud
Tacoma , Washington
Moss and algae
Living in the Pacific Northwest the winters are quite wet and damp and the Airstream is not in covered storage, what can be safely used on the exterior for algae moss removal ???
Thank You
BigGrey is offline   Reply With Quote
Old 02-10-2013, 03:00 PM   #2
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Thank You
White wine vinegar. Works for black mold along the Gulf Coast, should work for algae and moss.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 02-10-2013, 03:09 PM   #3
Tacoma , Washington
Thank You, does it need to be diluted
Old 02-10-2013, 03:21 PM   #4
cameront120's Avatar
1972 25' Tradewind
Warm soapy water and elbow grease always worked for me.
North Vancouver, BC
Old 02-10-2013, 03:23 PM   #5
Tacoma , Washington
Thank You
Old 02-11-2013, 05:47 AM   #6
5% vinegar, 95% water is effective against mold. If you buy Heinz white vinegar, it's already a 5% solution, so no need to dilute it; just use it full-strength from the bottle. Soak a sponge in it, and wipe the affected areas thoroughly.
If you buy other brands, check the label. Those may need to be diluted.
After washing with vinegar, wash again with warm soapy water.
WBCCI #1105
TAC LA-4
Old 02-11-2013, 06:07 AM   #7
Alphonse's Avatar
2010 28' Flying Cloud
Lower Alabama , USA
Doesn't acetic acid (vinegar) passivate aluminum causing it to oxide? Acetic acid - Wikipedia, the free encyclopedia
Alan
"If you must choose between two evils, pick the one you never tried before!"
Air #64439
Southeastern Camping Unit WBCCI #5033
TAC AL-8
2018 Canopenian
Alphonse is offline   Reply With Quote
Old 02-11-2013, 06:25 AM   #8
The chemical process of passivating doesn't happen that quickly. That's why, after you wash with vinegar, you wash again with warm soapy water, to remove any vinegar residue before it has a chance to harm the surface.
In addition, you're using only 5% acetic acid, not 100%.
If you're worried about it, you can always try it on an inconspicuous surface (the belly pan?) first before trying it on the whole trailer. Or keep looking for other alternatives to kill unwanted biological growth on your trailer.
Or leave the biological growth alone and turn your trailer into a chia pet!
WBCCI #1105
TAC LA-4
Old 03-11-2013, 09:48 AM   #9
Puyallup , Washington
go to any marine supply store - they have a pretty good selection of slime control
srpuywa is offline   Reply With Quote
