Old 01-04-2010, 05:41 PM   #1
adonh's Avatar
1976 31' Sovereign
Missouri City , Texas
Mid 20 degree - garage type storage
Here in the Houston TX area we have had a colder winter so far this year than in the past few years. Snow in late November with mid 20 degree nights for a couple of days. I drained the water lines from the Airstream when I took it back to storage last month and I planned on pulling the Airstream out and adding the pink stuff but I have not got around to it. Another cold night is predicted tonight in the mid 20'. The trailer is in a very good garage type storage but not heated. What is the likely hood that the temps in the storage will get below freezing with the temps in the 20' outside for a few hours. I am going to go add the pink stuff tomorrow for sure since the forecast is for temps to be below 20 degrees for Thur and Friday night.
Don
adonh is offline   Reply With Quote
Old 01-04-2010, 07:57 PM   #2
CanoeStream's Avatar
St. Cloud , Minnesota
Don -- the potential for damage is low. Very low. Disclaimer: this is intended for locations near the Third Coast and that's about all.
BryanL in Reno, NV, some years back reported on measuring temperatures near the floor in the morning after almost the same overnight temperatures you're expecting. The Airstream was parked in the driveway without the enclosure that you have. The temperature inside the Airstream remained above freezing. Your results may vary...
Empty tanks - good. Maybe RV antifreeze in the shower traps (goes down through the floor). 'May' is fairly conditional -- you just may be okay. The more steps you took, the better. Watch out if your shower mixer valve is on an outside wall -- these are prone to damage. The gravity drain you did may have taken care of that.
5 meter Langford Nahanni
Old 01-05-2010, 10:26 PM   #3
How did you turn out?
Our local weather tonight was full of stories about Gulf Coast cold. Brrrs! Hate them damp colds!
Old 01-06-2010, 05:19 PM   #4
adonh's Avatar
1976 31' Sovereign
Thanks, it made it just fine, only got down to about 32. But starting tomorrow the forecast for the Houston area is lows around 20 degrees at night through Saturday. I added the pink stuff today so should be fine.
Don, ready for spring.
Old 01-08-2010, 08:06 AM   #5
adonh's Avatar
1976 31' Sovereign
The temp dropped to 27 degrees last night here in the Houston area and the forecast is for even colder weather over the next 2 days. So I am going to run some "non-scientific" test to compare the outside temp with the temp inside my uninsulated and not heated garage. This should give me some idea on how cold it gets in the garage type storage where my Airstream is. Also the thermometer in my Airstream measure the high and low temp by pushing 2 small hands as the temp needle moves. So on my next trip to storage I can see the coldest temp that was recorded inside the storage unit during this cold spell.
This morning the temp outside is still 28 degrees and the temp in my garage is reading 40 degrees. I will check these during the next few days and post the results and then compare them with the actual low temp reached inside my actual Airstream storage.
Don
Old 01-08-2010, 08:45 AM   #6
dstalzer's Avatar
2005 25' Classic
22 degrees at our house and 42 in our insulated unheated garage this morning where our Airstream is kept.
Dennis
dstalzer is offline   Reply With Quote
Old 01-08-2010, 08:48 AM   #7
soldiermedic's Avatar
Florissant , USA
All this cold weather in Houston is making me nervous with the TX Vintage rally being held in a month. Hope we aren't all freezing!
Streaming Soldiers Blog
soldiermedic is offline   Reply With Quote
Old 01-09-2010, 07:18 AM   #8
adonh's Avatar
1976 31' Sovereign
Don
Saturday morning
Another cold night got down to 24 degrees. But the temp in my garage was 33 degrees.
Don
Old 01-09-2010, 07:51 AM   #9
Florissant , USA
It's -3 here right now...wanna trade???
Old 01-09-2010, 08:23 AM   #10
Steve, the birds will be singing and mountain laurel thinking about blooming. Winter starts with a 'J' (january) in Texas.
Old 01-09-2010, 10:02 AM   #11
2008 16' Safari
Destrehan , Louisiana
I'm near New Orleans and it dropped into the mid twenties last night. I keep the trailer here at home so all I did was turn on the heater in the AS and put a light bulb under the water tank. Everything was fine this morning.
Our problem down here is the it just does not get bellow freezing very often. We have no experience with this type of weather. I have never drained the water out of the camper because we can often go out camping this time of year. Many times it's in the 60's or 70's for the weekend so a little trip out can be nice.
We have about two more days when it will drop bellow freezing at night. Any advice that you cold weather campers could give would be much appreciated. We're planing at trip in Oct. or Nov. that will take us up into the mountains. Some nights it could freeze. I'd like to have a plan in place before I go.
dlb435 is offline   Reply With Quote
Old 01-09-2010, 11:34 AM   #12
dstalzer's Avatar
2005 25' Classic
19 degrees this morning in Austin. 41 degrees in the insulated unheated garage at 9:00 AM today.
Dennis
Old 01-09-2010, 11:47 AM   #13
Astroboy's Avatar
2007 28' International CCD
West Hollywood , California
Thanks for the empirical data points, it's good to know as a reference.
How does uninsulated and unheated garage stay above freezing when it's cold outside at 19 degrees?
Do you think this is mostly the residual heat from the warmer days before, or the solar heat that it soaks in during the day (has it been very sunny)?
Astroboy is offline   Reply With Quote
Old 01-09-2010, 04:32 PM   #14
adonh's Avatar
1976 31' Sovereign
That is the question. At what point does the outside freezing temp cause the temp in the uninsulated and unheated garage to reach freezing. So far the spread is between 8 to 10 degrees warmer in the garage. Since it is only dropping below freezing at night the garage does have a chance to soak up some heat inside. prolonged freezing conditions during the day could have an effect on this.
Don
3rd Car Garage Ideas for Airstream Storage Jezibels Winterizing, Storage, Carports & Covers 30 11-17-2010 03:20 PM
Mid twins to mid full size bed? WhiskeyRiver General Interior Topics 3 02-20-2008 07:05 PM
Garage Storage Dimensions for Trailer 1956Safari Winterizing, Storage, Carports & Covers 4 04-26-2007 08:46 PM
under bed storage doors on mid-60's reynolds431 Cabinets, Counter Tops & Furnishings 11 02-07-2006 12:24 PM
Tow bar receiver type or ball type? Astrodokk Airstream Motorhome Forums 2 06-09-2004 07:20 PM
