Old 10-17-2012, 10:23 PM   #1
L911's Avatar
1971 18' Caravel
Cookeville , Tennessee
Images: 12
Mice - 1973 Ambassador
I have a 73' Ambassador, what if anything can I do to keep the mice/critters out?
(We dont leave food or anything in the trailer)
L911 is offline   Reply With Quote
Old 10-18-2012, 12:16 AM   #2
Zeppelinium's Avatar
1975 31' Sovereign
1977 23' Safari
Palmer Lake , Colorado
I used spray insulation foam to seal up their paths through the frame, eg, in those areas where the floor is open (like under the sink) down to the frame.
These are the kind of mice I like...
Name:	IMG_8138 dead mice-s.jpg
Z
Old 10-18-2012, 02:40 AM   #3
mistermike's Avatar
1968 17' Caravel
Marblehead , Hasslechusetts
I use stainless steel hanks used for scouring pots stuffed in the 'A' frame is effective and permanent. Doesn't rust either.
mistermike is offline   Reply With Quote
Old 10-18-2012, 07:06 AM   #4
SteveH's Avatar
Common Sense , Texas
I used to have trouble with mice getting in the trailer here, but after installing a couple of the silent to us plug in sonic things from Tractor Supply, I've not had a problem with them.
When I did have them, I found a piece of pecan shoved into the trap as bait worked the best.
Old 10-18-2012, 07:13 AM   #5
NorthernWind's Avatar
1976 Argosy 20
RR4 Marmora , Ontario
Mice
Steel wool works very well for plugging all the little holes, non or low expansion spray foam works but if you ever have to do work in that area you will curse it for sure. Bounce sheets distributed throughout the trailer work well and don't smell as bad as moth balls which also will keep them away, but the best thing is to make sure that there are no food supplies anywhere near or in the trailer.
NorthernWind is offline   Reply With Quote
Old 10-18-2012, 08:43 AM   #6
Tom Nugler's Avatar
1972 25' Tradewind
McHenry County , Illinois
The Bounce sheets didn't work on our variety of mice. Just stunk up the trailer.
The Ultra-Sonic Rodent Repellers did. Of course You have to be able to keep plugged in.
But then, we found out on a trip this year, the little buggers can climb up the shore power cord.
Tom
AirForums # 2806
WBCCI / VAC # 6411
Not All Who Wander Are Lost.
Avid supporter of trailing edge technology.
Tom Nugler is offline   Reply With Quote
Old 10-18-2012, 01:14 PM   #7
Jinkers's Avatar
1968 20' Globetrotter
Fort Collins , Colorado
Images: 11
I'm trying out Fresh Cab rodent repellent. I haven't had any mice yet and I keep the AS parked in a temp storage tent on a friends farm. Lots of mice and rabbits around.
Probably the best repellent is to thoroughly clean the camper and remove anything that can be eaten or used by rodents for nest material.
Scott
Jinkers is offline   Reply With Quote
Old 10-18-2012, 01:23 PM   #8
SteveH's Avatar
Well, good luck with that. The last time I had a mouse in the trailer it pulled out a bunch of the fiberglass insulation from under the floor to make a nest with.
Old 10-18-2012, 02:13 PM   #9
dznf0g's Avatar
Oswego , Illinois
Please use stainless wool (scrubbers), if contact with aluminum is involved or moisture is an issue.
I used moth balls on the old SOB with great success....but the Missus banned them in the AS due to lingering smell.
-Rich-
Old 12-27-2012, 07:36 AM   #10
2004 30' Classic
Peterborough , Ontario
hello all:
We had those little rodents and were successful in catching them. After some research we have put the Sonic Rodent Deterent in the coach in two areas. Since installing these gizmos we have not seen any signs of the little gremlins. To date we are very happy with the way the Sonic units work. PS Purchased at HomeDepot.
Russ
dirtturner is offline   Reply With Quote
Old 12-27-2012, 08:07 AM   #11
1988 25' Excella
Tucson , Arizona
Pack rats
Here in AZ we have pack rats. They like the electrical wires and go after your most expensive vehicle.
Standard equipment is the sonic devices, "Gopher-Go-Die" in their ground holes and lights under the cars at night.
Other methods include bars of Irish Spring soap placed about inside and mothballs on ground underneath airstream. Then just drive away from the smell!
Compass Rose is offline   Reply With Quote
Old 12-27-2012, 08:32 AM   #12
Harleyjohn's Avatar
1992 33' Land Yacht
Wisconsin Dells , Wisconsin
My method for repelling these critters is to "dissuade" them is to provide mouse bait in both my garage and utility shed--both along side my RV. We live in Central Wisconsin and have lots of critters to contend with. Having no food in vehicles is not a deterant when Winter arrives. Previously I've had mice hole up during the Winter in our garage on/in my Harley side bags--
with no food around. I've had to replenish the bait in outbuildings often, but no evidence of a population in our unit.
John
New Member, Air#45995
WBCCI
1SGT, US Army
Retired
Harleyjohn is offline   Reply With Quote
Old 12-27-2012, 08:35 AM   #13
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
I use this.
Pest Control Non Toxic | Safe Rodent Repellent | VictorŽ Sonic PestChaserŽ Ultrasonic Rodent Repellent 2 Pack
Have not seen any mouse or mouse "evidence" since installing it. However, I am able to have electric power almost all of the time. 100% of the time while in storage at home.
Alan
Old 12-27-2012, 08:38 AM   #14
Harleyjohn's Avatar
1992 33' Land Yacht
PS: My mouse activity--where no food is available (in garage/shed) is when Winter arrives the mice live on fallen bird food from my bird feeders which I found around the engine and inside leather saddlebags of wifes Harley! Apparantly, they can bring their own meals to their "Winter homes"!!
ADVISE: FEED THEM ELSWHERE! (Mouse Bait)
John
WBCCI
1SGT, US Army
Retired
1973 Airstream Ambassador Land Yacht - Rare Rear Bedroom Model eBay Watch Airstreams on eBay 0 01-21-2012 01:40 PM
1973 airstream luxury international ambassador land yacht eBay Watch Airstreams on eBay 0 11-05-2011 10:40 PM
Ambassador :: 1971 Airstream Ambassador nascar427 Airstream Registry Discussions 0 08-19-2011 10:07 PM
1973 Airstream Ambassador with rear bath good condition eBay Watch Airstreams on eBay 0 06-07-2011 03:50 AM
1973 International? value etc. 73Argosy Trailer Values 17 05-06-2011 07:03 AM
