Old 05-16-2011, 04:04 PM   #1
retired USA/USAF
2001 30' Excella
Somerset , New Jersey
Master switch / Storage question
I posted this question in the electrical forum but did not get a response so here it goes here. I have an '85 Excella. It has an on/off master switch behind the sofa for the batterys. Is it advised to shut it off during short term periods of non-use during the traveling season or is it intended as a cut off for long term storage ??? I remove the batteries and bring them indoors and keep them on a tender for the winter. So this is a non issue for me in winter storage but still curious if it is wise to shut them off for short terms.
Thanks all,
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
polarlyse is offline   Reply With Quote
Old 05-16-2011, 05:26 PM   #2
Dwight's Avatar
1999 34' Excella
Joshua , Texas
The "STORE/USE" disconnect switch behind the couch removes 12 volt power from the batteries to the 12 volt circuit breaker panel. Anything else that is wired directly to the batteries like the LP Detector are still being powered. You can add a battery disconnect between the batteries and that will kill any 12 volt power.
History doesn't repeat itself, people do!
Dwight is offline   Reply With Quote
Master Switch question polarlyse Electrical - Systems, Generators, Batteries & Solar 0 05-13-2011 08:17 AM
univolt converter switch position? godaddy64 Electrical - Systems, Generators, Batteries & Solar 8 02-25-2011 12:17 PM
A Switch with no apparent function Aviator Lights - Interior & Exterior 8 01-24-2011 06:18 PM
3 way switch just went kaput...replacing? MonaxLisa Lights - Interior & Exterior 24 01-20-2011 04:51 PM
Battery switch behind the sofa LawChick Batteries, Univolts, Converters & Inverters 9 01-13-2011 08:52 PM
