Old 11-03-2015, 07:44 PM   #1
2017 25' Flying Cloud
1964 17' Bambi II
Ogden , Utah
Maintaining my Airstream through the winter
We just purchased a 2016 Bambi Sport. The trailer will be stored in an inclosed, insulated poll barn & it has been winterized. What other precautions do I need to do? I will be taking it out periodically just for a drive around the neighborhood. Thank you for any comments or suggestions.
mcaslaon4449 is offline   Reply With Quote
Old 11-03-2015, 08:01 PM   #2
CRH
1995 25' Excella
xxxxx , xxxxxx
Air up tires. Mouse proof building.
CRH is offline   Reply With Quote
Old 11-03-2015, 08:28 PM   #3
2015 16' Sport
Pineola , North Carolina
Do not leave any food items at all inside. Anything that has a smell like toothpaste or even scented cleaning wipes should be removed due to risk of mice. Also take out anything that could be used for nesting material such as paper products, towels, etc.
"Certainty on any matter is not one of the human attitudes the Gods admire or tolerate."
A. Cross
D Greene is offline   Reply With Quote
Old 11-03-2015, 09:37 PM   #4
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
If there is even a risk of winter road salt on the roads, do not take it out. Be sure the batteries are fully charged, then disconnect them. There are a few items that will draw down the batteries over time even though all switches are off and the Battery Disconnect is in STORE position. If birds can get into the building you may want to throw a tarp loosely over the top to protect from bird droppings, just be sure it isn't tight and can trap moisture.
Doug and Cheryl
Old 11-03-2015, 09:46 PM   #5
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
I would raise then "cribbage" or use jack stands to ensure tires do not touch the ground. I would spray insecticide around all "ground contact points" monthly to keep bugs out...at least the crawling ones.
Remove and store batteries on "maintenance" charger in a place it won't freeze.
I would add some "RV antifreeze to the sink and shower "P" traps... If you don't have that, buy some cheap vodka and pour int the drain. The evaporation will be slow... Add more if you think it needs it, once a month...
Do a good "wax" job... Rejex is a great product, but there are others you may prefer.
If it doesn't freeze there, consider a dehumidifier.
Peace and Blessings..
Channing
WBCCI# 30676
Old 11-04-2015, 05:48 AM   #6
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up
X2
On jack stands and keeping it off the salt.
In fact. my tires have found themselves indoors at times.....
If nothing else, covered and off the pavement, I use a 'wet mat' tile to keep the footprint dry.
Oh..... and 20psi is fine during storage.
PFC
"Tahawus"
RLC
Its a crooked piece of time that we live in.
John Prine
Old 11-04-2015, 06:24 AM   #7
dznf0g's Avatar
Oswego , Illinois
OP says he will drive around occasionally, so I wouldn't be too concerned about jack stands. That said, I don't think you need to drive it around while "stored". Mine sits for 5 months...yes on jack stands with tire covers over the tires. Remove all freezables, winterize lines and b/g tanks, mouse proof, remove batteries from items, like remotes etc., remove ALL food items. Check on it from time to time for mice, etc. Oh, and come up with an appropriate plan for house battery maintenance.
-Rich-
Old 11-04-2015, 10:28 AM   #8
2015 22' FB Sport
West Halifax , Vermont
Do most people jack their AS to keep tires off the ground through the winter? Is it OK not to, if I check and top off the tire pressure every few weeks? Thanks!
Kellycanoe is offline   Reply With Quote
Old 11-04-2015, 10:37 AM   #9
timhortons's Avatar
2015 16' Sport
Oakville , Ontario
It has been alleged that a dryer sheet in each of the bins, cupboards will dissuade mice.
Also mice in storage are largely a function of your climate(such as the south). They'll move into your Prevost if there are enough of them out there.
I wasn't aware my trailer needed regular exercise in the winter.
timhortons is offline   Reply With Quote
Old 11-04-2015, 11:23 AM   #10
B00merang's Avatar
2010 20' Flying Cloud
Hailey , Idaho
Just to save you some money...dryer sheets do NOT work. Distributed 2 boxes worth through the engine compartment and inside of my Yukon... three months later had to pay $550 to repair all the gnawed wiring around the nest they built (yes, using parts of dryer sheets) and $120 for inside detailing to get rid of all the stains. Don't know about mothballs, 'tho. jon
B00merang is offline   Reply With Quote
Old 11-04-2015, 12:24 PM   #11
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
I second that, no scented dryer sheets , they draw mice, no food inside...open frige to air out...
Old 11-04-2015, 12:36 PM   #12
Cannonball's Avatar
2014 22' FB Sport
San Antonio , Texas
We leave the roof vent open to promote some air circulation. Our rig is approaching two years of ownership and still has that "new rig" smell. We also hook the battery up to a "BatteryMINDER" trickle charger, and check the water level periodically.
Cannonball is offline   Reply With Quote
Old 11-04-2015, 12:45 PM   #13
dkottum's Avatar
Our trailer sits unused all summer, except when company comes and WE sleep in it. I like the idea of moving it around just enough to exercise the tires and flex the rubber suspension rods. But I would never take out onto a salty road to do it, easier to deal with tires than a corroded Airstream.
When winter nears we are headed to warm weather, sitting in our Airstream in Arizona right now.
Doug and Cheryl
Old 11-04-2015, 12:48 PM   #14
Thumbs up
Yes, off the ground, if you want to prolong their life
Unloading also extends the life of the torsion axles, preventing the rubber "springs" from developing set.
PFC
"Tahawus"
RLC
John Prine
Maintaining a stripped and polished airstream bluesteel Cleaning, Stripping & Polishing 2 06-27-2012 06:47 PM
Maintaining Exterior Finish BigGrey Airstream Lifestyle 5 05-07-2012 09:22 AM
Furnace Maintaining Temperature Erratically 10Smiles Furnaces, Heaters, Fireplaces & Air Conditioning 7 02-07-2012 07:43 AM
Maintaining cooling system RetiredGuy Tow Vehicles 5 08-26-2009 06:00 AM
Maintaining your Batteries joshua32064 Batteries, Univolts, Converters & Inverters 17 04-29-2008 10:03 PM
