Old 10-02-2011, 06:33 AM   #1
2008 31' Classic
Sweet Valley , Pennsylvania
Low point drain petcock spins
hello, I am attempting to open my cold water low point petcock on a 2008 classic for winterizing purposes......the handle just spins and I can't get it open. Does anyone have instructions on how to get it open? If I need to replace I can get a new one but how does it come out? Hoping I can get it open to winterize and I can order a new part as necessary for next yr. Thanks for any help in advance. Jim
TROPHYJIM2 is offline   Reply With Quote
Old 10-02-2011, 07:04 AM   #2
teagues's Avatar
2008 20' Safari SE
Charlotte , North Carolina
On the valve, is there a screw that secures the handle to the stem? If so, see if tightening that screw helps.
teagues is offline   Reply With Quote
Old 10-02-2011, 07:09 AM   #3
Well Preserved
overlander63's Avatar
Colfax , North Carolina
If the ears just spin on the stem, you'll have to replace it. All it is is a radiator petcock you can get from any auto parts store (yay! something cheap and easy to get for a change!). You should find two "spots" for wrenches, just hold the one closest to the trailer, and unscrew the one furthest away.
Some days, it's just not worth chewing through the restraints.
Old 10-02-2011, 07:47 AM   #4
2008 31' Classic
thank you all!
Is there a drain for the AC? perryg114 Furnaces, Heaters, Fireplaces & Air Conditioning 14 11-13-2011 06:06 PM
How to disassemble a drain valve flyflinger Fresh Water Systems 2 09-25-2011 11:17 PM
How to drain? sarasafari Waste Systems, Tanks & Totes 1 09-17-2011 01:02 PM
Can't locate low point drain values MR AIRSTREAM Winterizing, Storage, Carports & Covers 0 09-15-2011 08:57 AM
How low is too low? Mrs. Bale Electrical - Systems, Generators, Batteries & Solar 6 08-16-2011 07:19 PM
