Originally Posted by Tombomb68
It’s right near the white plastic drain for the water tank.
That is one of them. There should also be two more, one hot and one cold, under the bed near the hot water heater. Reach in through the holes under the mattress, or you can see them inside the rear storage compartment if you can reach in there. You should be able to see rubber hoses sticking out under the coach beneath them.
Looking carefully under the trailer for any more hoses would clue you in to other drains but for the 23cb that should be it. Assuming Airstream hasn't changed anything the last year or two--which is never a certainty.
