Old 10-18-2015, 02:13 AM   #1
IanPoulin's Avatar
2011 28' International
Aldie , Virginia
looking for a lock-open shrader valve fitting for my compressor
I am using the Camco metal blow-out plug to assist with clearing my lines off my air compressor. The camco blow-out plug uses a standard automotive shrader valve to allow/isolate pressure. The issue is I am doing this process solo and currently only have a manual tire chuck for my compressor, so I need to either:
(a) -- open up a tap inside the trailer and then externally apply pressure, "trusting" that physics does its job correctly multiple times in a row (yeah, I know - difficult to trust that stuff since when I fall down, it always hurts)
- or -
(b) -- apply a level of pressure to the system until it equalizes with the pump and then enter the trailer to operate the valve; giving me 5-8 seconds of pressure before it dies out.
Faucets are fine; my worry is the toilet and toilet wand which must have human intervention to operate and cannot be left on.
Since I am a relative air-compressor n00b, can someone suggest a fitting I may want to try to permit me a "constant on" shrader fitting that will let my compressor equalize to the Airstream-manual required 60 PSI without any intervention on my part, allowing me to stroll through the trailer opening up the valves in one continuous sequence without multiple entrance/exits to finish the job?
Ian
2011 Airstream International Serenity 28'
2016 Ford F250 Crew 4x4 KR Diesel
IanPoulin is offline   Reply With Quote
Old 10-18-2015, 03:26 AM   #2
IanPoulin's Avatar
Aldie , Virginia
... and the mods may want to delete this thread -- I just realized via amazon searches that camco makes another type of blow-out plug with the female adaptor directly compatible with air-hose operation... This will solve my issue and allow me to put a steady air pressure into the water systems of the trailer.
Old 10-18-2015, 10:03 AM   #3
richinny's Avatar
2011 34' Classic
ARB ARB607 - ARB Air Chuck with Clip - Quadratec
this will work if you have room for it. i don't know if milton still makes just the clip.
Ricky
Open or not open, that is the question RoadHungry On The Road... 58 06-22-2015 03:47 PM
Replaced city water SHURflo pressure relief valve fitting silverback Fresh Water Systems 3 06-01-2010 01:32 PM
My 1975 Overlander lock won't open, it just keeps turning LucyPepper Doors & Locks 2 06-22-2009 06:36 PM
Main door lock broken..can't get open Becky B. Doors & Locks 12 08-05-2008 05:06 PM
Dump valve fitting for 63 Safari srgntpepper Waste Systems, Tanks & Totes 5 06-05-2005 05:36 PM
