Old 03-19-2015, 01:30 PM   #1
2015 25' FB Flying Cloud
Georgetown , Texas
Location of Water Heater Bypass
Although I winterized my trailer (2015 25' FC FB with twin beds) last fall, for the life of me I can't remember where the water heater bypass valve is located. I looked in the cutout beneath the mattress of the curbside bed, but don't see it there. Any suggestions? Thanks
GLovedahl is offline   Reply With Quote
Old 03-19-2015, 01:38 PM   #2
I have that exact model.
The bypass is located under the curbside bed stick your hand into the hole and you will feel the valve. It is almost impossible to see it unless you have a good flashlight.
woof is offline   Reply With Quote
Old 03-19-2015, 01:41 PM   #3
Georgetown , Texas
Thanks, woof...That seemed to be the only logical spot for it, since it's to the rear of the hot water heater. I'll go back out to where I have the trailer stored and take another look.
Old 03-19-2015, 04:25 PM   #4
Georgetown , Texas
FOUND IT!! I had looked in that hole, and remembered doing something in there last Fall. I just took another look, with a good flashlight, and sure enough, there it was....stuffed below a bundle of cables and PEX. They sure don't make it easy, do they? Hard to turn in that restricted space, but I got it rotated back off bypass mode. Thanks again.
Location: Water heater bypass valve? Will_Brule Water Heaters, Filters & Pumps 16 11-10-2014 05:44 PM
Int'l 23D HW tank bypass valve location? DreamsInSlvr 2011 - 2015 International 2 09-17-2013 05:08 PM
location location location goransons Airstreams on eBay 0 12-05-2009 09:29 AM
Location, Location, Location........... ROBERTSUNRUS Brakes & Brake Controllers 5 08-29-2009 06:13 PM
Location of water heater bypass buckeroo2 Water Heaters, Filters & Pumps 2 04-02-2004 06:43 AM
