Old 10-25-2008, 09:40 AM   #1
on the hunt
osolow's Avatar
riverton , Kansas
Send a message via Skype™ to osolow
Question leaving furnace on in winter?
I am curious if anyone out there leaves there furnace on in the winter mouths, or if you turn them on if it's going to get extremely cold?
also how many people are lucky enough to store there A/S in a garage or building?
osolow is offline   Reply With Quote
Old 10-25-2008, 10:30 AM   #2
ScottW's Avatar
Hernando , Mississippi
I keep an electric oil filled space heater on during the winter just to keep the temperature swings to a minimum. When freezing temps are forecast, I turn on the propane heater and run it until the temp get higher. The holding tanks are vented and this keeps them from freezing. I do not winterize the trailer, so it is ready at a moments notice. It really doesn't get that cold for very long in north MS, so the cost of the propane is not that bad.
Your mileage may vary. Some settling may occur.
Rgds,
Scott
Air 16426
Fully retired now!
Remember:
Never start anything before noon and always plan on being finished by 5.
I will never HAVE to be anywhere ever again!
ScottW is offline   Reply With Quote
Old 10-25-2008, 10:50 AM   #3
The Hawk's Lair
cooperhawk's Avatar
1985 34.5' Airstream 345
BACK WOODS , Minnesota
Actually have overnighted in Hernando several times in the campground north of town. Used to have friends that lived there. Usually went out to the Casino to eat.
Here in Minnesoooota it gets pretty cold. I pump all the pipes full of Vodka, drain all the tanks, and bring all the flat screen electronics in, along with anything that will freeze and break. Then I put the MH in our barn, close the door and don't look at it again til either we want to go south, or Spring! Whichever comes first.
The cold doesn't seem to hurt it. I do ventilate the barn well in the Spring when all the moisture collects.
AKA THE GUNNER
There is no "I" in the word "team," but there are four in "Platitude Quoting Idiot!"
AIRSTREAM 345 TURBO-DIESEL
VFW, LEGION, NRA
cooperhawk is offline   Reply With Quote
Old 10-25-2008, 11:51 AM   #4
Full Timers/Diesel power.
Mike Leary's Avatar
Cactus Hug , Arizona
Images: 11
They are great, we have one in the bow & one in the stern.
"A settled wisdom, plus the itch to be elsewhere"
Mike Leary is offline   Reply With Quote
Old 11-21-2008, 06:45 AM   #5
kfrere's Avatar
2008 31' Classic
Lenoir City , Tennessee
We will be storing ours in a concrete floor garage that previously housed a MH. There is no heat in the garage, but there is electricity. We want to be able to use our trailer during the winter months. In between trips we were wondering if we should purchase an electric heater to turn on during the coldest nights (tonight in the teens) or if we should run the trailer furnace.
Kelly & Matt
WBCCI - #4335
2005 Diesel Excursion
2008 31' Custom Classic "Moonshine"
2016 Interstate "BugOut"
kfrere is offline   Reply With Quote
Old 11-21-2008, 06:58 AM   #6
flitzwhopper's Avatar
1976 Argosy 24
Tempe , Arizona
once in a blue moon
i know... i know... it doesn't get cold in Tempe. Actually, on occasion it does get into the 20's. When that happens, i use the furnace in the Twink. I leave it on its lowest setting and it keeps it in the 40's. Why? because the furnace has tubes that go into the area where the plumbing collects in the belly and keeps it from freezing. Seems to work.
Donna & Mike
Cowboy up! or go sit in the truck
Charter Member Four Corners Unit
WBCCI #2417
flitzwhopper is offline   Reply With Quote
Old 11-21-2008, 07:00 AM   #7
Images: 59
Let her freeze solid!
My Tradewind has spent the last 49 years outside in the Minnesota winters. It's good for her complexion.
Old 11-21-2008, 07:13 AM   #8
CanoeStream's Avatar
St. Cloud , Minnesota
You (not Don ... just everybody else!) could be risking a complete plumbing re-do if you have copper pipes. Heat from space heaters rises. That may work in the southern tier states. The most effective way to run heat along the floor and pipe areas is to have the furnace running. Be cautious if your shower mixer valve is on an outside wall -- those are very prone to damage and a pain to replace.
I do my own winterizing with RV antifreeze and it's quite easy -- an hour if you can get occasional help. I store in an enclosed garage and that honestly doesn't give much extra protection from the cold. Unless a person is on a southern coast or in Phoenix, what would concern me is that the coldest-in-five-years blue norther is going to mess up your camping and be very expensive to repair.
There are some reasonable ways for folks to deal with snowbirding and heading south in the winter. Drain the hot water heater. You can eventually blow the pipes dry with a real serious session with an air compressor (not my dinky little 3 gallon job). Be sure to put RV antifreeze in the traps. Head south and don't use any interior water until you're clear of winter storms. Summerize it when you get there!
5 meter Langford Nahanni
Old 11-21-2008, 08:09 AM   #9
HowieE's Avatar
Princeton , New Jersey
Images: 12
It is not worth the risk or the cost. The risk being if you run out of gas or have a heater problem you will freeze things solid in less than 2 days st your winter temperatures. Running the heater in KS. for the winter will send you to the poor house.
While the plastic piping used today might survive a freeze, it can take a much greater expansion cycle during thawing than copper, your hot water heater can not. It will be the first to go.
2004 Excursion 4x4
Old 11-21-2008, 08:19 AM   #10
Your heirs won't be happy if the furnace is run in an enclosed space ...and we warned you not to do it.
Old 11-21-2008, 09:46 AM   #11
AZ-JH's Avatar
Peoria , Arizona
It doesn't get that cold here, but we're very lucky to store in a separate garage on our property. The sun is brutal. If we ever had to buy another house, if it didn't have an Airstream barn, we wouldn't want to consider the house. The saved storage rental fees help compensate for a property with room to store.
AZ-JH is offline   Reply With Quote
Old 11-21-2008, 09:48 AM   #12
Images: 59
Originally Posted by CanoeStream View Post
You (not Don ... just everybody else!) could be risking a complete plumbing re-do if you have copper pipes. . . .
Yeah, I should have noted in my post that I:
1. Carefully pitched all my Pex plumbing to low point drains,
2. Blow it all dry with compressed air, including three sprayer hoses,
3. Repeat the blowdown just to be sure,
4 fill the pump with antifreeze,
5. add antifreeze to the traps,
6. drain all tanks,
7. remove the flatscreen,
8. check all cupboards for canned goods.
Then I think you can let it freeze solid.
Old 11-21-2008, 11:56 AM   #13
RangerJay's Avatar
2002 19' Bambi
Northwestern Ontario , - on the backside of the map and just above the big green spot
Images: 44
Nope - no heater - no garage.
Our winter temperatures will drop to -40 on occasion and -30 to -35 for several weeks at a time.
Any long-lasting snowload with heat in the trailer creates large ice sheets on the sides and top of the trailer - and a heated enclosure in this area is an attractive housing option for field mice.
Would be great to have a garage - but can't say that not having one has caused us any grief - this trailer has spent 5 winters as you see it here and does not show any signs of hurting because of it (I did have the vent covers crack from the snowload in the first year - they are now covered with their own plywood enclosure). This is about the maximum snow depth that I allow to accumulate before removing it with a broom.
Jay
Bambi - 2002 (The Toaster)
Pathfinder - 2009 (The Buggy)
"I'm not young enough to know everything ....."
(Oscar Wilde)
RangerJay is offline   Reply With Quote
Old 11-21-2008, 12:24 PM   #14
Images: 59
Wow! Is that -40 Celsius or -40 Fahrenheit?
(yeah, it's a trick question)
full-time winter living problems, questions by college girl (freezing temps, furnace) icedcacti Winter Living 30 08-24-2010 08:07 AM
Leaving batteries connected over the winter StAlphonzo Electrical - Systems, Generators, Batteries & Solar 7 10-02-2008 02:44 PM
Finally leaving Faerymother Our Community 1 02-09-2007 12:13 PM
Sorry we are leaving Happycampers Off Topic Forum 15 02-24-2006 01:24 PM
Leaving!!! LKappenman On The Road... 0 03-07-2003 03:39 PM
