Old 11-21-2008, 02:34 PM   #15
mustang's Avatar
1986 31' Sovereign
Kent , Ohio
It gets down to -40F here in NE Ohio also. Sometimes colder.
We filled my buddys trailer fresh water tank with Pepermint Schnopps. His wife swore she could still tast it all summer, when she was taking a shower I was told she could smell it.
That was there Honey Moon trip.
I think electric or any heater would get expensive to run.
mustang is offline   Reply With Quote
Old 11-21-2008, 03:06 PM   #16
RangerJay's Avatar
2002 19' Bambi
Northwestern Ontario , - on the backside of the map and just above the big green spot
Images: 44
Science may tell us that -40C is the same as -40F ... but of course that's before you factor in the Canadian/American exchange rate ... we generally haven't done so well there ... and then of course you have to factor in the wind chill (not sure about American meteorologists but our Canadian counter parts are quite fond of reporting "wind chill") ... and I have to admit - it always seems that the windchill from a Colorado Low seems colder than the windchill from an Alberta Clipper ... but no matter how you cut it .... -40 feels like it would freeze the brass @#$% on the same monkey anywhere .....
Jay
Bambi - 2002 (The Toaster)
Pathfinder - 2009 (The Buggy)
"I'm not young enough to know everything ....."
(Oscar Wilde)
RangerJay is offline   Reply With Quote
Old 11-21-2008, 04:45 PM   #17
HowieE's Avatar
Princeton , New Jersey
Images: 12
Years ago I worked with 2 guys from Winnipeg. Their explanation of cold was when a 6ft. relieved himself outdoors and it crackled upon hitting the ground that was 60 below.
You Canadians are sure brave people to attempt such an experiment, looking at the thermometer is how we tell the temp.
2004 Excursion 4x4
Old 11-21-2008, 06:23 PM   #18
CLOUDSPLITTER "Tahawas"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
From Buffalo...
It's also a good idea to take the wheels and tires off.
I know we're a little anal here in WNY.
Name:	2007 WINTERIZE 006.jpg
PFC
but I’m the Husband, so we went to Cleveland. 😂
RLC
Step aside Starbucks, this is a job for alcohol.
Old 11-21-2008, 06:30 PM   #19
94Tri's Avatar
1994 34' Excella
Mount Vernon , Kentucky
Originally Posted by markdoane View Post
Yeah, I should have noted in my post that I:
1. Carefully pitched all my Pex plumbing to low point drains,
2. Blow it all dry with compressed air, including three sprayer hoses,
3. Repeat the blowdown just to be sure,
4 fill the pump with antifreeze,
5. add antifreeze to the traps,
6. drain all tanks,
7. remove the flatscreen,
8. check all cupboards for canned goods.
Then I think you can let it freeze solid.
This basic winterizing has served me well with no heat added. It takes me about 45 minutes to complete and then no worries until spring.
94Tri is offline   Reply With Quote
Old 11-21-2008, 08:41 PM   #20
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
Originally Posted by flitzwhopper View Post
i know... i know... it doesn't get cold in Tempe. Actually, on occasion it does get into the 20's. When that happens, i use the furnace in the Twink. I leave it on its lowest setting and it keeps it in the 40's. Why? because the furnace has tubes that go into the area where the plumbing collects in the belly and keeps it from freezing. Seems to work.
That's what we do with the furanace on the really cold nights, too, since we don't winterize...as we go camping in the winter months...(I know, we re wooses...that's why we live here!) It's just enough to keep it from really getting too cold... At those times we also crank up the water heater and run hot water through the system ...then we turn off the water pump and open the faucets so it's not a closed system...then if something does get too cold, there is room to expand with out damage.
TB & Greg and Abbey Schnauzer
#3954
Old 11-23-2008, 09:31 AM   #21
Here in Colorado, we winterize.
Running the furnace uses lots of propane. When winter camping, I go through a seven gallon tank of it in a few days
R.V. furnaces are not as reliable as home furnaces and the possibility of shutdown and freezing your rig is significant.
I winterize like markdoane, except I drain the water pump. It takes me about an hour and uses a half a gallon of r.v. antifreeze and I am not that handy. Just fill the tank and turn on the pump when you are ready to go camping.
handn is offline   Reply With Quote
Old 11-23-2008, 10:17 AM   #22
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
Originally Posted by osolow View Post
I am curious if anyone out there leaves there furnace on in the winter mouths, or if you turn them on if it's going to get extremely cold?
also how many people are lucky enough to store there A/S in a garage or building?
Nope, we winterize the trailer so how cold it gets is inconsequential. The only time we've used the furnace to warm the unoccupied trailer is when it's at home in the drive and we are early or late in the season with a night forecast for freezing temps.
We are extremely fortunate to have an indoor storage locale where the trailer spends it's idle time.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 11-23-2008, 10:46 AM   #23
Stray
1987 32' Excella
1978 28' Argosy 28
Springfield , Missouri
As we use our unit throughout the winter, it get's winterized in late October-early November. All that means is that it gets a shot of antifreeze in all the right places, water and waste containers brought out of storage and put in trailer and three backup heating systems double checked. Winter camping has it's unique pleasures/challenges, but I just love a 12-month camping season. Would be nice to have inside storage, but we've not had any problems being outside.
Stray
nohillgrish is offline   Reply With Quote
Old 11-26-2008, 08:52 PM   #24
78GussyTX's Avatar
1978 Argosy 30
Alvin , Texas
Images: 8
Wow, I am glad to live in Texas! I'm surprised AS has not developed some kind of plug-in electric option to keep things above freezing, like the diesel block heaters. As for -40 F or C, neither one sounds very hospitable to me!!
78GussyTX is offline   Reply With Quote
Old 12-21-2008, 07:31 AM   #25
Sky
Classic 30
Sky's Avatar
Sum Wear , Ohio
I winterize the trailer, but I still try to maintain a constant temperature of 40F inside. I set furnace to 40F and supplement it with a ceramic heater on very cold nights to conserve propane. I am afraid a cycle of freezing and thawing is not good for the joints throughout the interior (especially the wood cabinets).
I am guessing this costs me about $100 over the winter months that we are not snow-birding. Am I wasting my money?
"Only dull people are brilliant at breakfast" - Oscar Wilde
2500HD DMax............30' Classic
Sky is offline   Reply With Quote
Old 12-21-2008, 07:48 AM   #26
Keeping the interior at about 40 degrees in the freezing weather pays huge dividends.
First of all that heat must come from the furnace, since it forces the heat near the water lines and holding tank(s), which prevents a freeze up.
Should the ambient temperature be forecasted to be below 10 degrees, then it would be wise to increase the interior temperature another 5 degrees or so.
Another wise step is to open all the cabinet doors that hide the water lines and other plumbing. That permits even better circulation.
That saves winterizing costs.
Oil or electric heaters have no way of circulating the heat around the water lines and holding tank(s).
Keep an eye on the propane level.
Don't run out of fuel.
Old 12-21-2008, 07:55 AM   #27
Silverhobby's Avatar
1967 26' Overlander
1968 30' Sovereign
Mosheim , Tennessee
"That saves winterizing costs. Andy" --- Where I live, a couple of gallons of antifreeze, even installed multiple times, is CHEAPER than P R O P A N E !!
//------AIR # 7303------\\
WBCCI 17109
visit my restoration blog at:
Old 12-21-2008, 08:13 AM   #28
jcanavera's Avatar
Fenton , Missouri
Images: 143
My gut on this is if the only reason is to protect the cabinets, you're wasting your money. Consider the fact that your cabinets flex big time when you are under tow, the temperature change that occurs is minor in the big picture. Also consider that any appliance has a limited amount of uses. Personally the wear and tear on your furnace is not worth the amount of flex that might occur with the joints. Especially in light of what goes on when you tow.
One final thought, if you consider the temperature varriance when considering flex, summer creates a much bigger temperature gap considering the temps in a closed trailer. My advice, winterize the plumbing and turn off the heat. You'll save money and lengthen the life of your furnace.
Jack
Jack Canavera
STL Mo.
AIR #56
full-time winter living problems, questions by college girl (freezing temps, furnace) icedcacti Winter Living 30 08-24-2010 08:07 AM
Leaving batteries connected over the winter StAlphonzo Electrical - Systems, Generators, Batteries & Solar 7 10-02-2008 02:44 PM
Finally leaving Faerymother Our Community 1 02-09-2007 12:13 PM
Sorry we are leaving Happycampers Off Topic Forum 15 02-24-2006 01:24 PM
Leaving!!! LKappenman On The Road... 0 03-07-2003 03:39 PM
