Old 12-14-2015, 10:56 PM   #1
HankO's Avatar
1997 28' Excella
Eden , Utah
Leaving Dump Valves Open
Hi all,
I just was talking to a mechanic friend of mine that owns a RV campground, he seems to know a lot about RV's. We were talking about winterizing the RV and he said it is important to leave the dump valves in there open position when putting the RV away for the winter, as this saves the seals from freezing against another object and causing premature failure of the seal. I'd never heard of this before, but I trusted him and besides I just spent a ton of money replacing all my seals last year and don't want to go through that again. Has anybody had any issues doing this?
Hank
HankO is offline   Reply With Quote
Old 12-15-2015, 04:33 AM   #2
GeocamperAS's Avatar
1974 Argosy 28
1978 Argosy Minuet 6.0 Metre
Wauwatosa , Wisconsin
Images: 37
I drain all my tanks but that doesn't necessarily mean all the water is out. All it takes is a tablespoon to freeze and have nowhere to expand but to break something. So I always add about a 1/2 gallon of RV anti-freeze to each tank. The anti-freeze helps keep the seals lubricated.
Leaving the value open wouldn't work for me.
Judging a person does not define who they are, it defines who YOU are.
GeocamperAS is offline   Reply With Quote
Old 12-15-2015, 04:39 AM   #3
IanPoulin's Avatar
2011 28' International
Aldie , Virginia
I always leave my gate valves open when storing with no ill effects to date.
2011 Airstream International Serenity 28'
2016 Ford F250 Crew 4x4 KR Diesel
IanPoulin is offline   Reply With Quote
Old 12-15-2015, 06:54 AM   #4
dznf0g's Avatar
Oswego , Illinois
Likewise for me.....23 years with two trailers, in freezing storage weather, never an issue with this method.
-Rich-
Old 12-15-2015, 06:57 AM   #5
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
I also close valves because I use antifreeze.
If I were only draining the system, not using antifreeze, I would definitely open the valves.
Alan
Old 12-15-2015, 10:30 AM   #6
kdickinson's Avatar
1969 23' Safari
Palmer Lake , Colorado
antifreeze in the tank and closed valve
kdickinson is offline   Reply With Quote
Old 12-15-2015, 11:04 AM   #7
WBCCI # 23456
2000 30' Excella
Greeneville , Tennessee
I put antifreeze in the tanks and leave the valves closed. I don't want critters looking for a place to spend the winter.
jimfa440 is offline   Reply With Quote
Old 12-15-2015, 01:33 PM   #8
Cape Coral , Florida
He is correct in my opinion
jeffbec51 is offline   Reply With Quote
Old 12-15-2015, 01:40 PM   #9
2015 30' International
FREDERICK , Maryland
That is what I do...
Doc Foster is offline   Reply With Quote
Old 12-15-2015, 02:14 PM   #10
2007 22' International CCD
Consider a sturdy screen over the open end to keep critters out. Like 1/4 inch mesh galvanized hardware cloth.
KE4GNK/AE
Old 12-15-2015, 06:34 PM   #11
dcasr's Avatar
1990 29' Excella
Stone Mountain , Georgia
For 44 years I have drained the tanks and put in potable RV antifreeze and closed the valves leaving enough antifreeze in the tank to cover part or most of the valve. It has worked for me from northern Montana to California to Atlanta. If I leave the vaves open and uncovered except for critter mesh, I'm afraid that the valves would dry out. Just saying this is what has worked for me for 44 years.
WBCCI 2456 Georgia Unit 32
1990 Excella 29' Centramatics
2016 GMC Sierra Crew Cab 2500 HD 4x4
6.6L Duramax + Allison, 3.73 axles
dcasr is offline   Reply With Quote
Old 12-15-2015, 07:30 PM   #12
CRH
1995 25' Excella
xxxxx , xxxxxx
Keeping the seals wet sounds like the better plan to me.
CRH is offline   Reply With Quote
Old 12-16-2015, 11:35 AM   #13
2007 27' Classic FB
Ridgefield , Washington
Closed. Antireeze keeps seals lubed. Keep little animals out.
John & Lisa
Woosch is offline   Reply With Quote
Old 12-16-2015, 02:38 PM   #14
garry's Avatar
1969 31' Sovereign
Broken Arrow , Oklahoma
Another "closed with antifreeze". I prefer to have the valve lubricated.
Garry
Can old LP tank valves be upgraded to OPD valves? jimblacker LP Gas, Piping, Tanks & Regulators 8 03-26-2014 06:07 AM
Thetford valves hard to open/close LI Pets Waste Systems, Tanks & Totes 7 10-08-2011 06:30 PM
Leaving table open while towing tnsue General Interior Topics 14 08-30-2004 02:35 PM
Leave Propane Bottle Valves Open? heyskipper LP Gas, Piping, Tanks & Regulators 3 02-23-2003 08:19 PM
Valves and Valves smily Plumbing - Systems & Fixtures 5 08-22-2002 04:01 AM
