Old 01-11-2018, 11:57 AM   #29
2007 22' International CCD
Yup. Although it’s tempting to pitch a tent or park a trailer under a shady tree, it’s best to stay well clear of ANY overhanging branches.
They don’t call them ‘widow makers’ for nothing. There have been several cases of tenters being killed or injured by falling branches as well.
KE4GNK/AE
Old 01-11-2018, 01:57 PM   #30
dznf0g's Avatar
Oswego , Illinois
That's a bit difficult in the forest. What is important, for a lot of outdoor skills reasons, is to develop a habit to regularly "look up".
-Rich-
Old 01-16-2018, 12:35 PM   #31
2018 30' International
Fort Worth , Texas
We traveled from Texas to Colorado over the holiday. We were winterized on the way up, but when we arrived at our destination, our tank valves would not open, frozen? I had a small ceramic heater that I placed under the trailer at the valves and let it run until the valves opened.
In the evening before bed, I drained the hot water heater into the gray tank and manually put hot water in the toilet/black tank. Nothing froze overnight while temps were in the mid teens.
A couple days into the trip I put some foam board insulation around the underside of the trailer as we were in one spot for 2 weeks, made a huge difference and freeze up was not an issue...for what its worth...
2018 Airstream International Signature 30 - Salsa
2013 Ford F350 CC 4X4 SRW
bka4tcu is offline   Reply With Quote
Old 01-16-2018, 12:57 PM   #32
Snow Chasing Dog Wrangler
2018 16' Sport
Golden , Colorado
Originally Posted by Adventure.AS View Post
The fresh tank on a 16' Sport is inside the trailer under the front bench and is heated by the ambient air in the trailer. If the furnace is on it will circulate warm air and prevent the water tank and pump and pipes from freezing. Some other models like the 22 and 23 have the black tank in the cabin (the toilet sits up on the tank box.)
That part we understand , but what about the optional 12 Volt tank heaters. How many watts do they draw and when do you recommend using them (obviously while it's freezing out), for example during towing vs while parked, etc. Thanks.
AirstreamAbe is offline   Reply With Quote
Old 01-16-2018, 01:07 PM   #33
Adventure.AS's Avatar
2017 25' International
Port Dover , ON Canada
Originally Posted by AirstreamAbe View Post
... but what about the optional 12 Volt tank heaters. How many watts do they draw and when do you recommend using them (obviously while it's freezing out), for example during towing vs while parked, etc. Thanks.
eTrailer sells the Therma Heat RV tank heaters. According to the specs for the 18" x 12" model, they would likely only work when plugged in to shore power because they need an input of 13.5 volts and a fully charged house battery would only supply around 12.6+ volts.
  • Input voltage: 13.5V DC
  • Power draw: 4.8 amps
  • Wattage: 78 watts
Ray B.
WBCCI #6497
“One test is worth a thousand 'expert' opinions”
Sign at Boeing headquarters, posted by test pilot Alvin “Tex” Johnston, c1948
Adventure.AS is online now   Reply With Quote
Old 01-16-2018, 01:31 PM   #34
2018 16' Sport
Golden , Colorado
That is exactly what I was looking for. Thank you!!!
Old 01-16-2018, 02:09 PM   #35
  • Wattage: 78 watts
Those are nominal maximum specifications for the heat pads, not minimums to operate them. They will still generate (slightly less) heat at lower input voltages, since they are a simple resistance heater.
They will, however, deplete batteries fairly quickly at that current, so it is best to have shore power to run the convertor to keep the batteries charged...
We have lived in our AS for extended periods camping in 26 degree or below weather, and reliable shore power is a must to run the propane forced air heater (big 12 volt draw), keep the tank heaters on, use the hot water heater, and run the water pump, etc. when the fresh water hose is disconnected because the exposed shore water hose freezes up rapidly at those temps. We won't talk about the Camco filter that froze fairly badly before I pulled it inside to thaw out. Fortunately it did not split, but it could have...after a few more hours sitting out in the cold and wind...
Except for running through lots of propane, we were quite comfortable for a week of those conditions in Northern Alabama...late into November...
KE4GNK/AE
freezing temp, water not going into fresh tank dpurpose1 Fresh Water Systems 17 12-06-2016 04:44 AM
Extended Winter Traveling Below Freezing eliasurbina Sprinter and B-van Forum 7 11-19-2014 09:36 AM
Freezing up while traveling in cold climates TG Twinkie All Argosy Trailers 27 11-21-2011 08:13 AM
Freezing temp ext. Water line LisaP Winter Living 11 01-10-2011 03:45 AM
Pullrite owners--lessons learned markparker22 Hitches, Couplers & Balls 10 04-17-2005 11:57 PM
