Old 02-22-2012, 09:39 AM   #1
chrischarles's Avatar
1977 31' Sovereign
Jacksonville , Florida
Keeping the pipes from freezing and busting
Is it possible to travel through temperatures that may be prone to freeze with water in the holding tank, hot water tank, and the grey and black tanks? Should all of these and the lines be empty?
chrischarles is offline   Reply With Quote
Old 02-22-2012, 11:50 AM   #2
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
It depends on the outside and inside temperatures. Along with the temperature of the material in the holding tanks. You can add RV anti freeze to the grey and black water tanks but it would be better to just empty them before hitting the road. The fresh water tank is more likely to freeze but it holds a large amount of water so it would take some time. If the water sloshes around in the tank it will take longer to freeze.
The water heater is insulated and will hold temp for quite some time.
The water lines will freeze before anything else, especially those that run thru unheated areas such as behind cabinets and across vented areas like the refer vent.
Keeping cabinet doors open will help but not eliminate the problem totally.
You can travel with the furnace running but you will consume considerable propane.
TG Twinkie is online now   Reply With Quote
Old 02-22-2012, 01:41 PM   #3
Silver Otter's Avatar
1999 30' Excella 1000
Nellysford , Virginia
Send a message via AIM to Silver Otter
Not to hijack, but related: A park host asked if my city water hose and my Sewer Solution hose were "winterized" or insulated at a recent camp. The temp. was predicted to drop to the mid teens. I decided to boondock, leaving the hoses safety curled up in storage. What did she mean by asking, i.e., are there ways to insulate the outdoor hoses and still use them in severe cold. I have heard not, but would investigate the options if there are any. . .?
Greg and Linda Heuer
'99 Excella 30 w/HAHA - The Silver Otter
'08 Chevy 2500HD 6.6 DuraMax w/MBRP dual pipes
TAC VA-18 | WBCCI 1927 - Unit 149 | AIR 53869
http://www.linkedin.com/in/gheuer
Silver Otter is offline   Reply With Quote
Old 02-22-2012, 02:00 PM   #4
wasagachris's Avatar
1973 31' Excella 500
1961 30' Sovereign
1947 22' Liner
Durham , Ontario
Send a message via Skype™ to wasagachris
Greg I think what she meant was did you have a heat trace cable attached to your lines.
EasyHeat AHB Constant Wattage Pre-Terminated Lengths
I used this product on both water and sewer lines then wrap them in the foam pipe wrap and then use duct tape to hold them closed.
1973 Excella 500 31ft Center Bath
1963 Overlander 26 ft
1961 Sovereign 30 ft Custom
1955 Overlander 26 ft
1947 Liner 22 ft.
2010 Ford F450 Crew Cab Dually Diesel
TAC ON-11
Every day is a gift, but does it always have to be a pair of socks.
wasagachris is offline   Reply With Quote
Old 02-22-2012, 07:03 PM   #5
1977 31' Sovereign
This might sound funny but did you have to dismantle the trailer to install the foam pipe wrap and heat strip?
Old 02-22-2012, 07:18 PM   #6
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
I think it would be counter productive to wrap the pipes inside the trailer with insulation. This would prevent or at least slow down the ability of whatever warm air is in the space from getting to the pipes.
Old 02-23-2012, 01:39 PM   #7
Very neat solution. I wasn't aware of this product. Looks like just the ticket for a multi-day stay with full hookups in the cold. Thanks for the lead.
Old 02-23-2012, 03:18 PM   #8
bwoodtx's Avatar
1997 30' Excella
1954 25' Cruiser
1958 22' Custom
1979 28' Airstream Excella 28
San Antonio , Texas
I would think that if interior pipes were wrapped it would help considerably .
However, if rebuilding and using PEX it should not matter.
Bruce
WBCCI# 9259 AIR# 38927 TAC-TX 14
Stop Littering-Spay & Neuter-- Adopt From Rescue
He is your friend, your partner, your defender, your dog. You owe it to him to be worthy of such devotion.
bwoodtx is offline   Reply With Quote
Old 02-23-2012, 09:42 PM   #9
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
If you use the EASYHEAT it would make sense to insulate the pipes because the heat from the heat tape would be held next to the pipes with the insulation. But if you are using the amient air around the pipes to prevent freezing. Why would you insulate the pipes from the heat source?
02/12: New Tire Discussion on Woodalls: LT versus ST and more. REDNAX Tires 128 04-10-2012 05:09 PM
Yosemite, Yellowstone and Glacier reccomendations. danlehosky On The Road... 5 02-24-2012 10:52 PM
Hello from a New owner of a 2009 Sport! AirTer Member Introductions 5 02-22-2012 09:33 AM
How can you tell the brakes are...? AIR-Quarius Brakes & Brake Controllers 11 02-22-2012 07:20 AM
Popped rivet near the top door Hodum Ribs, Skins & Rivets 3 02-21-2012 09:53 PM
