Old 09-07-2019, 05:06 PM   #1
Minocqua , Wisconsin
Issue Winterizing 2020 Flying Cloud
I have drained and blown out all water at 55 psi and turned bypass on water heater. This AS has a winterization kit knob and tubing just before the filter screen. I turned the winterization knob to the correct location and placed the provided clear tubing into the RV antifreeze jug. When I switch the pump on, it doesn't pull the antifreeze out of the jug? All faucets and drains are closed. Does the pump need priming if there is little water left in it? If so, how is that accomplished?
lovemorels is offline   Reply With Quote
Old 09-07-2019, 05:32 PM   #2
2019 27' Globetrotter
Salem , Oregon
According to my manual which should be the same. All faucets need to be open. When you see the pink come out of a faucet close it and don't forget the outside shower. Dave
NoResults is offline   Reply With Quote
Old 09-07-2019, 05:34 PM   #3
Adventure.AS's Avatar
2017 25' International
Port Dover , ON Canada
You need to have a tap open for the pump to move antifreeze through the lines.
Ray B.
“One test is worth a thousand 'expert' opinions”
Sign at Boeing headquarters, posted by test pilot Alvin “Tex” Johnston, c1948
Adventure.AS is offline   Reply With Quote
Old 09-07-2019, 05:36 PM   #4
3rd one is the charm?
pcskier's Avatar
2014 23' Flying Cloud
Park City , Utah
Sometimes the winterization valve is installed backwards. On a Camco kit, the end of the valve stamped with a 'C' will face the water pump. When in service mode, the handle should point toward the pump. If it is, it won't pull from the bottle when in bypass mode. Ask me how I know.
Better yet...now you've blown out the lines, go around and do it one more time, including low points once at a time...and be done with it. I stopped with the anti-freeze a couple years ago and it's been heavenly. Get up and go in the spring. Just some antifreeze in the traps.
pcskier is offline   Reply With Quote
Old 09-08-2019, 07:20 AM   #5
Thanks for the replies! I did open the kitchen sink faucet and then turned on the pump. No flow of pink from the bottle. ?¿
The winterization kit was factory installed. The tube is clear all the way to the junction. I have the knob in the correct direction. I have an appt in Oct for some warranty work to be done and may have to add this to the list. For now, I will open the pump, make sure the water is pumped out and put the antifreeze down the p-traps. I had read that in really cold climates, the RV antifreeze will help keep the rubber pieces within the system from drying out/cracking.
Thank you! HAPPY SUNDAY FUNDAY☆
Old 09-08-2019, 09:19 AM   #6
Orcs
orcs's Avatar
2014 25' Flying Cloud
Winthrop , Washington
Unhappy winterization
Don't forget to disconnect the water supply to the toilet at the base of the toilet. That instruction is not in the operating manual but it is in the manufacture's instruction. The valve can freeze and crack even if you have blown everything out. ( don't ask me how I know this ).
2014 25' FC, RB twin
2018 Ford F-150 Platinum Super crew, 3.5 Ecoboost
2 crazy Border Collies, no sheep
orcs is offline   Reply With Quote
Old 09-08-2019, 09:29 AM   #7
2016 27' Flying Cloud
Niagara falls , New York
Just winterize it through the fresh water tank
just winterize it through the fresh water tank
Cjanese21 is offline   Reply With Quote
Old 09-08-2019, 10:12 AM   #8
Half a Rivet Short
Carlisle , Pennsylvania
Hi
I'm assuming the pump does turn on. If not, then look into that part of things. If the pump turns on and a faucet is open, do you get "stuff" out of the faucet ( like air )? If so wait a bit longer for the anti-freeze to get going. If that still does not do it, check that all the fittings are tight. Also check that you aren't pumping it out through one of the low point valves .... been there done that ....
Old 09-08-2019, 11:13 AM   #9
2019 25' International
Washington , Washington, D.C.
With pump on, start at kitchen sink, open up faucet, cold side, and then hot side until water runs pink. Close. Do same in BR sink. Then toilet. Then shower, hot and cold. Then exterior shower. It doesn’t take long for pink to come out. Pour extra RV antifreeze into drains. Carefully wipe metal around drains to keep it from pittung. Put small bowl beneath faucets to catch drops.
PatLee is offline   Reply With Quote
Old 09-08-2019, 11:19 AM   #10
pcskier's Avatar
Park City , Utah
This doubles my suspicion that the valve is installed backwards And yes, I am completely serious. It's very easy to install backwards if not paying attention.
That pump should start pulling antifreeze out of the bottle almost immediately.
Old 09-08-2019, 11:23 AM   #11
pcskier's Avatar
Park City , Utah
Unless the FW tank is completely empty, which is unlikely, there can be dilution of the antifreeze. But more importantly, trying to flush antifreeze from the fresh tank is an absolute nightmare. He'll smell antifreeze in his water all next summer no matter how much flushing is done.
Old 09-08-2019, 11:34 AM   #12
lsbrodsky's Avatar
2012 25' FB International
Trent Woods , North Carolina
I agree! This is a very bad idea and should never be employed. If you are going to pump pink, either disconnect fittings at the pump inlet or install your own winterizing manifold at the same location.
Larry
lsbrodsky is online now   Reply With Quote
Old 09-08-2019, 08:36 PM   #13
jeffmc306's Avatar
McHenry , Illinois
Tried out of the bottle; ended up using funnel
I tried putting the tube in the gallon bottle but the pump would not prime on our FC23FB and ended up connecting a funnel and tube to the pump. As soon as I did, the pump primed and worked as expected. Your mileage may vary.
2019 27’ Globetrotter FBT Walnut/Dublin Slate
2018 FC23FB (traded)
2019 Ram 2500 Laramie Blue Ox 1500#
WBCCI# 10258
2020 Retirement Plan
jeffmc306 is online now   Reply With Quote
Old 09-09-2019, 07:12 AM   #14
I like the idea of the funnel. Where did you buy that fancy bottle connection?
I also thought the same thing initially, maybe the pump needs to be primed. Plus, if the factory installed winterization kit is backwards, then no fluid should go towards the pump if I tried just pouring the solution in the tube provided, right?
The pump runs when I turn it on, but no air flows from the kitchen sink when I try the hot or cold setting.
You all are so helpful with your ideas♡
I really appreciate this forum!!
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
2020 Flying Cloud Rear Bed Twin on Order! cru-in Our Community 22 06-04-2019 06:49 PM
Winterizing / De-Winterizing Adventure.AS Winterizing, Storage, Carports & Covers 0 03-07-2019 09:25 AM
De-Winterizing - Water Heater Issue redvfr02 2005 and newer - Bambi all models 21 04-19-2017 09:04 AM
Winterizing 2015 30Ft Flying Cloud Cottrell1951 Winterizing, Storage, Carports & Covers 1 09-19-2015 05:15 PM
Winterizing Flying Cloud dbaur Winterizing, Storage, Carports & Covers 5 11-10-2010 05:44 PM
