Old 03-03-2014, 08:39 AM   #1
1969 21' Globetrotter
Banner Elk , North Carolina
Is it road worthy.
I am looking at a 1973 Airstream and it has been parked and not used for a few years. Before this the trailer was not used on the road for quite a few years, but parked and lived in. I want to use this on the road and wonder if it would be worth buying. The owner has had a small heater inside to protect the interior while not in use. I wonder if this is workable for what I need? I am worried about the running gear.
dennydwk is offline   Reply With Quote
Old 03-03-2014, 09:26 AM   #2
mandolindave's Avatar
I have a 1973 Argosy
Don't bother worrying about the running gear, just accept that you need to replace tires, brakes and bearings. The propane fridge is probably ready to fail, as is the water heater. The original charger will cook your batteries, and the battery will most likely need to be replaced. Check for rotted floor and signs of leaks. But you didn't give us enough info. How much does he want for it? Are you handy? How much can you spend? Almost all used campers are money pits.
It's worth it if you camp a lot or if you love Airstreams.
mandolindave is offline   Reply With Quote
Old 03-03-2014, 09:31 AM   #3
adonh's Avatar
1976 31' Sovereign
Missouri City , Texas
Based on the information you provided I would have to say no it is not road ready. The running gear is just one of the things that will need to be looked at and either repaired or replaced. You still have to consider, water lines, holding tank, frame separation, flooring rot, fixtures and appliances, AC/furnace and electrical. Good luck. Pictures would help.
Don Hardman
1976 31' Sovereign
adonh is offline   Reply With Quote
Old 03-03-2014, 09:41 AM   #4
Colin H's Avatar
1957 30' Sovereign of the Road
1959 28' Ambassador
1949 24' Limited
Peru , New York
All of the above applies, however don't bother replacing the bearings & brakes as it will need axles anyway. Towing it home shouldn't be an issue as long as you check the bearings to make sure they're ok. We have discussed this & more, numerous times on The Vintage Airstream Podcast | Vintage Trailer Restoration .
Colin
Colin H is offline   Reply With Quote
Old 03-03-2014, 09:41 AM   #5
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Short Answer... No
At bare minimum just to move it you will probably need tires, brakes and the bearing repacked. Then there is a whole laundry list of things that will need to be checked.
Aaron
WBCCI #XXXX AIR #2495
OFF the road... SteveSueMac On The Road... 25 09-24-2014 10:13 AM
Need help with road trip from Oregon through ID, MT, WY, & Banff Canada Chad-sarah On The Road... 14 11-17-2011 10:22 AM
State Bridge to Kremmling road quality tlcbuilder On The Road... 3 07-02-2011 12:55 PM
The Road to San Antonio Foiled Again Solo Streamers 5 06-04-2011 10:25 PM
