Old 11-22-2006, 11:12 AM   #1
guy99's Avatar
1984 31' Airstream310
Dunsmuir , California
Images: 16
Is anti-freeze required to winterize?
I don't normally winterize our 1984 310 Limited MH. Our temps seldom get below mid 20's. I usually just leave the furnace on set to about 50. This way I don't have to de- winterize when we want to use the rig (which we do several time each winter). Unfortunately the pilot seat is out of the rig and I'm out of propane with cold weather on its way so I guess I will go ahead and winterize.
I'd rather not fill the system with anti-freeze. Is it good enough to empty all the tanks (including hot water) and blow out all the lines? Or do I need to run anti-freeze through everything?
1984 310 Limited Motorhome
guy99 is offline   Reply With Quote
Old 11-22-2006, 11:22 AM   #2
_
hi guy
simplest approach is install a 20$ bypass hose at the water pump...
run antifreeze into the lines and drains only...
this is done by opening each faucet with the pump on, till pink goes down the drains...
empty the tanks... and you are done....
only flushing needed to undo it, this way is the pump and lines...simple and quick
don't put antifreeze in the freshwater tank, it takes forever to remove the traces...as in 5-10 tanks of freshwater...
if no buypass hose kit is available just disconnect the water pump and add an extension hose long enough to reach the antifreeze bottle...
airing the lines and draining tanks, low water valves works ok on new units (i do this) but given the age and potential low spots in your plumbing, it is unlikely all the water will escape.
cheers
2air'
Old 11-22-2006, 12:40 PM   #3
Pahaska's Avatar
2014 Interstate Ext. Coach
Hays County , Texas
Sounds like where I live
In central Texas, I simply drain all tanks, blow out the lines with compressed air, and put antifreeze in the sink and shower traps. The shower trap, especially is very important; can you envision replacing a broken trap?
I do remove the water pump filter and empty it of water. I then put a sponge over the pump outlet and run the pump briefly to get all water out of the pump.
I first drain the fresh water tank, the water heater, and the low-point drains. I then use my compressed air carry-tank to blow out the lines. My tank has a clip-on air chuck and I use a screw-in Schrader valve which allows me to clip the tank on outside and go inside to open faucets one by one. If I run short of air, I use my 12v compressor to refill the tank.
In this area, we use the trailer every couple of weeks all year 'round. I don't want antifreeze in the lines since it takes a lot of water to flush the lines and I have no water available at my storage site. I drain the water heater, but I make no use of the bypass. When draining the water heater, I find that it is a good time to remove any scale and debris from the tank.
My last step is RV antifreeze in the traps.
John W. Irwin
WBCCI #9632
Old 11-22-2006, 02:06 PM   #4
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
I'll sound like a broken record, but without antifreeze, the pump is not protected. When I relied on compressed air/draining only, my pump was damaged by expanded frozen water...tiny little bits of it, but busted none the less. you'll never get all the water out of the pump.
Probably perfectly fine in more temperate climates, though, where it seldom freezes, or only dips briefly below 32F. The year I had damage, we had a few extended periods of below 0F weather.
the only way to completely remove the water from the system is to pump some other liquid into it to displace it.
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
Old 11-22-2006, 02:11 PM   #5
Just an old timer...
85MH325's Avatar
Tipton , Iowa
Images: 37
I just emptied the tanks and blew out the lines for years. I always disassembled the pump and got all of the water out of it I could, and then dumped anti-freeze in the p-traps as well. Frankly, once you have a water heater bypass and anti-freeze take-up valve installed, it's easier and faster to use anti-freeze. You don't have to take anything apart, you don't have to wait all the time it takes for the water vapor to stop coming out of each faucet, and it really doesn't use more than a gallon or gallon and a half to do the entire rig. I'm a convert. I'm also with 2air... don't put anti-freeze in the freshwater tank. It won't hurt you to drink it, but I don't think it adds anything positive to the taste of the water.
Roger
Old 11-22-2006, 02:21 PM   #6
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
On my 78 I have winterized as suggested above, but I don't see a drain for the water tank. I looked where the book says it is , but I am not finding it. Any ideas?
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Old 11-22-2006, 02:30 PM   #7
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
I do basically everything Pahaska does with an additional step - I run antifreeze through the lines & blow it out afterward.
My reasoning is that, left there, the antifreeze will "flavor" the pipe's walls. This method has worked well for two seasons.
Tom
Old 11-22-2006, 02:36 PM   #8
Images: 59
Did we just give up on the idea of using a 50-50 blend of ethanol? It's good to -25F.
Old 11-22-2006, 02:41 PM   #9
TomW's Avatar
1967 26' Overlander
Not necessarily
Since I'm lazy, it was just easier to pick up three gallons of RV antifreeze at AutoZone for $9 than check ethanol prices.
Does 1-1/2 gallons of ethanol cost less than $4.50?
Tom
Old 11-22-2006, 03:12 PM   #10
Images: 59
No, Tom, but come springtime all you have is a waste disposal problem.
I'll have enough gin for a whole weekend!
Old 11-22-2006, 03:38 PM   #11
1976 25' Caravanner
Campton , New Hampshire
I know everyone says it's OK , but I'm still not a fan of putting chemicals in my water system . I blow out the lines . I do use RV antifreeze in the traps and about a 1/2 cup in the water pump . Just unhook the filter near the pump , fill the hose with antifreeze , then run the pump for 30 sec . Been good for 10 NH winters . Another 2 cents .
ticki2 is offline   Reply With Quote
Old 11-22-2006, 03:39 PM   #12
balrgn's Avatar
1974 27' Overlander
1954 26' Romany Cruiser
1960 26' Overlander
Rockingham County , New Hampshire
Images: 74
Send a message via AIM to balrgn Send a message via Yahoo to balrgn
Ditto here
'74 Overlander (T-O-Bee)
'46 Spartan Manor (Rosie)
'54 Cruiser (Bogart)
'60 Overlander (Hoagy)
WBCCI 1754 - AIR # 6281
www.balrgn.com
balrgn is offline   Reply With Quote
Old 11-22-2006, 06:16 PM   #13
1990 34' Excella
Parsonsfield, , Maine
Drain Valve on 78 Water Tank
Alan, I had a 79 31 footer that had no drain valve. Airstreams method of emptying the tank was to run the pump till it runs out of water or dies. On my 79 there was an inspection plate in the belly pan under the water tank. It was a piece of belly skin about 4 or 5 inches square held to the belly pan by a sheet metal screw in each corner. When the plate was removed and under some insulation there was a white plastic drain plug in the water tank. The plug had a female hex. I found a hex head cap screw maybe 5/8" bolt and placed two hex nuts locked together on the bolt. I placed the bolthead in the drain plug female opening and used a wrench on one of the nuts to remove the plug. Be careful putting the plug back. If you use teflon tape to seal the threads the tape acts like a lubricant and you can tighten the plug too far into the threaded opening. Because the plug is tapered it may be possible to damage the threads or the tank. A friend of mine at Travelers Rest replaced the elbow where the water pump pickup comes out feeding the pump. He replaced that elbow with a brass elbow in which he drilled and tapped a thread to install a drain valve. It always leaked a little but I was afraid to tighten it for fear of damaging the tank fitting. If you remove the drain plug from the tank, be ready to roll quickly out of the way because that water pours quickly through that two inch drain. Charlie E.
CharlieE is offline   Reply With Quote
Old 11-22-2006, 08:39 PM   #14
Chaplain Kent's Avatar
1994 30' Excella
Milwaukee , Wisconsin
The only anti-freeze I use is a small amount in the drain traps. Chummy is primed and ready to roll all winter long and upon each return all I do is blow out the water lines and bring the water filter inside the house. But of course the Wisconsin winter is nothing to complain about we rarely get those balmy 20 degree days.
Chaplain Kent
2015 Coachman Freedom Express 19RBS, Chummy IV- Ford Excursion- 7.3 Turbo-diesel
Chaplain Kent is offline   Reply With Quote
Interior Picts Electrical campcollector 1997 - 2004 Bambi 14 04-21-2004 02:09 PM
Power required to run A/C Ken J Furnaces, Heaters, Fireplaces & Air Conditioning 2 06-29-2003 10:02 AM
Pulling a Bambi with a Ranger? wallycox Tow Vehicles 42 10-17-2002 01:29 PM
How to winterize when you're fulltime? escapeez Winter Living 2 09-15-2002 04:06 PM
voltmeter ALANSD Mechanics Corner - Engines, Transmission & More... 10 07-06-2002 08:13 AM
