Old 11-23-2006, 06:27 AM   #15
Just an old timer...
85MH325's Avatar
Tipton , Iowa
Images: 37
The nice thing about using the anti-freeze (for those of us who actually use our trailers during the winter a bit) is that you can winterize on the road with it. There's no need to find a compressor, and you don't have to worry about the pump. You drain the tanks, suck the anti-freeze into the lines, and you're on the road again without worry of freezing while driving. It's less than a ten minute process.
BTW, guys... the anti-freeze doesn't hurt the plumbing, is non-toxic, and flushes out of the lines within seconds of seeing clear water at the taps. The old stuff was kind of nasty (the reason I used to just blow mine out), but the product(s) they make today are really easy to use.
Roger
Old 11-23-2006, 06:35 AM   #16
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
That won't work for me
Originally Posted by 85MH325
The nice thing about using the anti-freeze ... is that you can winterize on the road with it. There's no need to find a compressor, ...
My shore water plumbing (checkvalve, reg) will hold water that does not drain with anything but compressed air. Granted, it is not much water, but then not much is required to freeze and have a problem.
And the checkvalve does not "check" 100%, so water will backfill the area in question even when only the pump is being used.
Tom
Old 11-23-2006, 08:24 AM   #17
Chaplain Kent's Avatar
1994 30' Excella
Milwaukee , Wisconsin
Good point. I forget not everyone, like us MHers, have heated tanks and water lines while they travel.
Chaplain Kent
2015 Coachman Freedom Express 19RBS, Chummy IV- Ford Excursion- 7.3 Turbo-diesel
Chaplain Kent is offline   Reply With Quote
Old 11-23-2006, 08:34 AM   #18
85MH325's Avatar
Tipton , Iowa
Images: 37
Tom
Tom, if you're talking about the back-flow preventer on the incoming water line, the accepted method of dealing with that is: once the plumping is charged completely with anti-freeze, go outside and hold the tip of the back-flow preventer in with your finger until anti-freeze comes out the hose connector, then let it seal again. The anti-freeze will displace any water on the back side. Generally though, that water on the back-side of the valve shouldn't be a problem as it's open to the air and can freeze and expand out the hose connector without causing any damage.
The back-flow preventer on the water tank is usually inside the pump, and the intake valve installation is done on the intake side of the pump, so the pump's back-flow preventer is taken care of automatically with anti-freeze on both sides.
Roger
Interior Picts Electrical campcollector 1997 - 2004 Bambi 14 04-21-2004 02:09 PM
Power required to run A/C Ken J Furnaces, Heaters, Fireplaces & Air Conditioning 2 06-29-2003 10:02 AM
Pulling a Bambi with a Ranger? wallycox Tow Vehicles 42 10-17-2002 01:29 PM
How to winterize when you're fulltime? escapeez Winter Living 2 09-15-2002 04:06 PM
voltmeter ALANSD Mechanics Corner - Engines, Transmission & More... 10 07-06-2002 08:13 AM
