Old 08-25-2016, 09:12 AM   #1
Airboutique's Avatar
1972 25' Tradewind
Montrose , Colorado
Insulation for the winter
I am going to attempt another Colorado winter in my Airstream. I noticed that some people who live year round in their rv skirt their rigs in thick foam board. I am thinking that instead of skirting I would attach the insulation directly to the bottom of my a/s. Any thoughts? It would be a lot less labor intensive for me but wondering if it would be effective. Thanks for any input.
Shelly😆
Airboutique is offline   Reply With Quote
Old 08-25-2016, 09:39 AM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
I have seen hay bails used effectively in extreme cold around mobile homes, tiny homes on wheels and travel trailers.
MICHAEL
Old 08-25-2016, 09:44 AM   #3
richw46's Avatar
Lexington , Kentucky
You need to restrict air movement under the trailer, keep an air pocket under there. Homes with crawl spaces underneath do the same thing but there is additional insulation under the flooring to keep the pipes from freezing and the floors from being cold. I would think that however you keep air movement at a minimum would work for you. Maybe have some bales of straw on standby.
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE
richw46 is offline   Reply With Quote
Old 08-25-2016, 10:09 AM   #4
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Hay bales make great homes for mice and other critters. Not a good idea. IMHO
Skirting is the best and most efficient way to keep things warm.
Old 08-25-2016, 12:04 PM   #5
2000 34' Limited
1985 25' Sovereign
LaGrange Highlands , Illinois
Between U and me I would not spend a winter where it gets below 25 degrees. Check out the insulation in the walls of UR trailer they R only rated about an R-7. BRRRRRRRRRRRRRRR that is not much insulation to keep U warm. And for another problem because the insulation R-rating is so low it will create condensation behind the curtains and then mold will set in. I know from experience.
rmatkovich is offline   Reply With Quote
Old 08-25-2016, 12:17 PM   #6
Penokee , Kansas
Hay bales work well but another issue other than mice and rats is a fire hazard.. we live in a very rural area with less than 2000 people in over 1000 square miles.. the number of trailers that folks winter in is just a hand full.. but every winter we have a trailer fire due to hay bales stacked around the base. Smoking would be my guess but a lot of things start Bale fires..Sodbust
Sodbust1 is offline   Reply With Quote
Old 08-25-2016, 12:46 PM   #7
IanPoulin's Avatar
2011 28' International
Aldie , Virginia
There's a thread worthy to review of member deauxrite winter camping at the Grand Canyon south rim; and includes their experiences which, if I remember right, include their insulation methods. It's also a phenominal "no-move travelogue" thread wise.
http://www.airforums.com/forums/f459...yon-98031.html
2011 Airstream International Serenity 28'
2016 Ford F250 Crew 4x4 KR Diesel
IanPoulin is offline   Reply With Quote
Old 08-26-2016, 05:48 AM   #8
2016 28' Flying Cloud
Moneta , Virginia
Do not use hay bales, use STRAW BALES
Hay is inclined to combust.
Straw has almost zero green matter (nitrogen source) that would cause it to heat up.
One can never know how well hay is cured, straw on the other hand is only stems that have usually dried for sometime before cutting and bailing.
Buy a bale of hay and a bale of straw, wet them outside in a safe place, stick your hand in the bale and check for heat, check it again over the next few days, if the hay was any good as hay there will be a significant temperature rise, the straw will not show a significant change.
Straw, either wheat or oats, will do a great job for you.
I would buy contractor sized trash bags, put the bales in the bags and then place them, use smaller bags stuffed with loose straw to seal up any odd holes. Purchase one 10 piece of slotted drain tile to place under the trailer, just tape it to the botom and let the open ends stick out either side, it will provide enough air exchange to manage moisture and you can regulate the air flow duct tape on the ends or stuffing the ends partially.
Good luck .
KenBrodin is offline   Reply With Quote
Old 08-26-2016, 06:45 AM   #9
AWCHIEF's Avatar
Images: 33
Good luck .
Learn something new everyday. I am basically a city boy and did not know there was a difference. Thanks for the info.
MICHAEL
Old 08-26-2016, 07:19 AM   #10
richw46's Avatar
Hay is for eating and straw is for putting on the floors in stables to make cleanup easier. You can get straw in bales at your local Lowes or Home Depot in rectangular bales. I've seen hay in fields as large round wheels, not sure if it comes in other forms, but probably does. As KenBrodin pointed out, hay is fresh and can spontaneously combust while straw is dried out before baling. Both can contain mice, ants and other critters.
The key to insulating, however, is dead air. You don't want the wind blowing away any heated air. Storm windows/doors, insulated glass and the like all depend on preventing or limiting air movement. Styrofoam is good too but also liked by woodland creatures.
-Rich
Rich & Yvonne
2004 4Runner SE
Old 08-26-2016, 07:59 AM   #11
1972 25' Tradewind
Montrose , Colorado
Thanks everyone for your input. Hay bales not an option due to the critter element. Guess I will have to try to level the ground around the base and puzzle the insulation in as I skirt the rig.
Old 08-26-2016, 09:25 AM   #12
1978 31' Excella 500
Barrie , Ontario
I lost a barn full of hay from hay heating up due to being damp when stored,but I don't think a single row of bales would do this, however straw is usually much cheaper.
Bev1940 is offline   Reply With Quote
Old 08-28-2016, 04:33 AM   #13
LYCAN92's Avatar
1963 19' Globetrotter
Chowchilla , California
Just a thought for you, I put rubber on the underbelly, then attached with caulking a black rubber trim on the bottom edge of the outside, then on the inside I sprayed Plasti Dip rubber coating on the inside underbelly, then caulked all the screws, gaps, old utility holes and seams where the aluminum connects, then let dry, then sprayed on Great Stuff foam, let dry, then added pink insulation, then cut out and sanded down a pice of plywood to fit, caulk the edge of inside underbelly, slide it in, caulk the top of it in, then screw it down to the Steel frame.
Just a idea for you, besides hay.
Name:	ImageUploadedByAirstream Forums1472379320.268406.jpg
ID:	270181Click image for larger version
Name:	ImageUploadedByAirstream Forums1472379338.335805.jpg
ID:	270182Click image for larger version
Name:	ImageUploadedByAirstream Forums1472379350.721042.jpg
ID:	270183Click image for larger version
Name:	ImageUploadedByAirstream Forums1472379360.370737.jpg
ID:	270184Click image for larger version
Name:	ImageUploadedByAirstream Forums1472379370.503425.jpg
LYCAN92 is offline   Reply With Quote
Old 08-28-2016, 04:52 AM   #14
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
Modern Airstreams are designed and built for recreational travel. They are not 4 season vehicles for winter housing. There are mobile homes specifically designed for that kid of useage. Two inch PE foam insulation partially buried around the trailer is the best solution to reduce the cooling under the trailer and will help to protect the three tanks. A bigger dehumidifier is also a must have.
Insulation- Prodex or Foam Insulation Board? Danny Z General Interior Topics 7 08-26-2015 08:21 PM
Does old fiberglass insulation equal new fiberglass insulation? Petethefeet General Interior Topics 7 11-14-2010 12:16 PM
Winter? What winter??? Pahaska Off Topic Forum 21 01-06-2006 09:17 AM
Insulation Cat General Interior Topics 6 11-26-2002 06:31 AM
Pipe insulation niftypkg Plumbing - Systems & Fixtures 1 09-22-2002 09:34 PM
