05-15-2017, 07:53 AM
#41
1972 31' Sovereign
Lexington
Ours has sat outside since we completed her reno (had a makeshift shelter with tarps before that). However, we are planning on biting the bullet and building a carport type shelter this summer. Hail and snow are the two reasons for us. It means moving the trailer to another part of the yard due to regulations in our community, which is why we haven't done it before now. But, worry about hail especially is galvanizing us to reconsider. If you can, I'd do it. Peace of mind means a lot.
Kay
05-15-2017, 10:04 AM
#42
Highlands
, New Jersey
Originally Posted by 68 TWind
I think a cover is the most important "accessory" you can have for your Airstream.
Water and UV are the two worst enemies of any RV. Why pay a premium price for a nice new Airstream add then let it sit outside. Any money you spend on a cover for your trailer will be easily recouped when you sell it. Yes a full enclosed garage is best but just a nice cover will offer a lot of protection. A pristine looking used Airstream will be worth a lot more than one aged by the sun and weather. I would get the cover first and then the trailer. I made the mistake of restoring mine and then a couple of years later getting a cover to park in under, should have gotten the cover first.
Thank you for the info Twind... when you say cover do you mean a cover over the trailer?? I read & heard you should never put a cover over an Airstream trailer.. since it's is aluminum it should be allowed to breather.. if it doesn't have air flow & moisture gets trapped you could be getting into bigger problems of oxidation and or corrosion... that's why I was thinking of a carport or awning that cover the top but doesn't cover the trailer completely like a cover... thanks again for the input!!
Shorefoot
05-15-2017, 10:13 AM
#43
Highlands
, New Jersey
Kay
Kay, thank you for your reply!!! We are thinking the same too.. either a UV tarp shelter to hang above the airstream before we bite the bullet & have a carport built... how did your tarp shelter hold up? We live up in NJ & we do get crazy wind, snow & hot summer sun. Did yours last? Did you have any issues with either strong winds or heavy snow? I am always afraid of it collapsing!!! how did you construct it? Is there a company on line that you can order this type of shelter? Thanks again for the info!!! I greatly appreciate it!!!
Shorefoot
05-15-2017, 11:41 AM
#44
1968 24' Tradewind
Oxford,
, Mississippi
I have an aluminum "car port" shed to park the trailer under. There are lots of companies who make and sell them.Lots of options on style and color. I have a big back yard and it is behind the house. I got it big enough. 18x31ft so I can park my mowers and tillers and get them out of the garage.
Bruce & Rachel
68 Trade Wind
2001 Toyota Tundra
05-15-2017, 12:33 PM
#45
Las Vegas
, Nevada
Airstream storage
So I assume the best way to store an airstream is indoors but that may not be an option for us. We live in the southwest, hot, dry, lots of sun. how would an airstream hold up being stored in open air, not covered? Is that even an option or do I pay for covered storage or indoor storage? Thoughts?
05-15-2017, 01:42 PM
#46
Highlands
, New Jersey
Awesome thanks again Twind!!! I figured you meant some sort of carport & not a RV cover.. enjoy the RV season!!! Safe adventures!!
05-15-2017, 01:58 PM
#47
2011 30' Flying Cloud
Greenback
, Tennessee
PatLee,
My place is a local business in Knoxville, Tn. I found it on-line by using Google and searching for RV storage in Knoxville. I checked out several places and this was the best overall for me. We have used it for about three years and are quite satisfied.
Richard
05-15-2017, 02:15 PM
#48
2014 30' Flying Cloud
Tampa
Plenty of Airstreams being stored in the sun. Keep it waxed and clean. If you can find or afford covered storage, of course it's better. But not required.
2014 Airstream Flying Cloud 30 Recliner - WBCCI #4850 - AIR #110821
2018 Nissan Armada SL Tow Vehicle, Equal-i-zer Hitch
Visit Our Flying Cloud blog for my latest adventure!
05-15-2017, 07:14 PM
#49
1962 28' Ambassador
1961 19' Globetrotter
Mesa
Inside storage is very nice but not required as many have theirs outside in all kinds of weather.
I would say, based on the elements you describe, keep covers on the inside of your windows, cover your fabrics or leathers, cover your tires or wheel wells, maybe some rodent traps just in case (without food on them) and maybe a bucket of water to keep some moisture in there.
Things that are affixed with glue or adhesive only may come off in the extreme heat. Mirrors should have clamps on them too not just adhesive on the back.
Visit often to check on things.
Hittenstiehl
05-15-2017, 08:53 PM
#50
2017 22' Sport
edison
, New Jersey
I live in Central NJ and had my AS for a year out in the elements. No issues here. But it's been warmer than usual here in the winter months.
2017 Ford Expedition EL
2017 Airstream 22FB Bambi
05-15-2017, 10:49 PM
#51
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction
We are based in the Phoenix area. Even though the trailers are stowed under roof, the outside air can be 115 degrees in the summer. We keep three five gallon buckets of water inside the Classic and the 23D to keep all the "furniture" from drying out and glue joints from failing.
05-16-2017, 07:43 AM
#52
2015 22' FB Sport
2018 27' Flying Cloud
2021 30RB Classic
Fredericksburg
Just like a car. Proper cleaning and routine maintenance will keep it looking like new. Take the money you would spend on building a cover for your 16' Bambi and buy a larger Airstream.
05-16-2017, 08:21 AM
#53
1972 31' Sovereign
Lexington
We had built our original "shelter" because everything leaked as we were starting to work on the trailer. We used 4x4 treated posts set into the ground with 2x4's as slanted rafters, and tarps stapled over the top. It was makeshift, we replaced the tarps once in the 3 or so years it was up. Once the trailer was in better shape, it came down. It was also behind my husbands workshop so hidden from the street. Now we're thinking carport style with open sides, raftered roof. Simple but sheltering. On the negative side, we won't be able to open the awning when it's inside because of the supports we need to hold up the roof. If we kept that side open, it would increase the cost dramatically because of the lam beams we'd need to span 22 ft for the awning to open out. We did have hail damage to a white box trailer before we got the AS. The insurance company totaled the trailer, and we bought it back and continued to use it. Didn't affect value when we traded it in for a new box trailer a few years later (and we were completely honest about it because it had a salvage title). The AS now, that might be a different matter. We've also only had enough snow load once here to be concerned about the AS. But we live in MN where we get more cold than snow.
We figure a thousand or so and our labor will build the shelter we want.
Kay
05-16-2017, 09:41 AM
#54
Tampa
I currently have a space at a covered facility.
Positives:
1. covered
2. 30 amp power
3. concrete floors
4. wash and dump stations
5. on site manager/security
6. large security fence
7. 24 hr access through a coded gate.
8. Mostly class A motorhomes, no junk. (and the people who go with it)
9. Very sturdy buildings (steel). Built to withstand hurricanes.
No trees to fall on it.
Negatives:
1. expensive $$$
2. 25 miles from home. easy to ignore.
3. for two years of storage $$ I could build a nice metal pole shelter at home.
4. using the RV means moving all the supplies twice. Once to the truck, then again at the RV.
5. Since the RV is not at home, for a trip the fridge needs to be started, water tanks checked, etc. Nothing is convenient.
05-16-2017, 12:15 PM
#55
Highlands
, New Jersey
Kay
Thank you again for the info Kay!!! Enjoy the RV season!!!!
Shorefoot
05-18-2017, 09:10 PM
#56
2015 22' FB Sport
Toronto
, Ontario
We store outside at an RV rental storage location. We make the time to wax and treat the surface, and so far so good. We're in the Toronto, Canada area
05-18-2017, 09:13 PM
#57
Highlands
, New Jersey
Thanks stsammy enjoy the up coming season
06-29-2017, 08:14 PM
#58
Knoxville
, Arkansas
Hi All! This is my first post on the forum, but I thought I could chime-in since my brother and I have an Indoor/Outdoor storage facility. I see the effects of the different options on a daily basis and they are very drastic. Disclaimer: We offer several storage options and most of you are not located anywhere near us; so this is truly my unbiased opinion and what I would tell a family member (one of the ones I like!).
All of these apply whether you are storing at a commercial facility or your home.
- Outdoor - Uncovered
This of course will be your cheapest option but if you do not take meticulous care of your AS, expect maintenance issues sooner rather than later. When I say "meticulous", I am talking about someone who pays attention to every detail and fixes minor issues as soon as they are visible. If you choose this option make sure you find a space that is NOT under a tree. Sap and bird stains are nearly impossible to remove without a trace. Also, keep your AS very clean and all surfaces well protected, top to bottom. The sun's UV radiation causes lots of damage, but the daily temperature changes also have a major effect. Daily expansion/contraction cycles can cause issues. Also, visit often to air it out.
- Outdoor - Under fabric cover
We do not recommend anyone store like this at all. The cover will either damage the surface finish or you will injure yourself (yes it happens, think "sail"). We've actually had customers come to us because after the first attempt to install the cover, their wife said "Not Again". Also, keep in mind, most covers are "breathable". "Breathable" is not the same as having adequate air flow.
- Outdoor - Under Canopy
This is slightly better than storing in the open, but often cost at least 2-3x as much. It will protect the roof a little better; but indirect UV radiation will still reach the sides, even in 3 sided structures. Also, you will still have the daily temperature/humidity cycles. If you are storing at a "storage lot" or at home make sure the structure is designed and built to local standards. Pole barns or carports can cause significant damage if they are not built to withstand snow/wind loads. A $2500 canopy could easily cause $10-20k in aluminum damage if the wind takes ahold of it.
- Indoor - Non-Climate Controlled
This is about equal to storing "Under Canopy". You will have less UV Radiation, but airflow will be limited which can cause issues with mold/mildew. Also, make sure the building has no chance of rodent issues. Barns often have mice. Mice seem to love chewing some plastics and the insulation on wires.
- Indoor - Climate Controlled
This will be your most expensive option, but provides the best environment for your AS. An insulated/humidity/climate controlled garage or storage facility provides the most protection from UV Radiation and limits temperature fluctuations. Also, it provides the most protection from theft and prying eyes. Yes, we do hear people say it is expensive, but you really do get what you pay for and our long term customers tell us it is well worth it. I personally have a 22 year old boat that has been stored indoors its whole life and it pretty much looks like a brand new boat. Also, I had a customer tell us when he took his 3 year old trailer in for service, they knew he was storing it at our facility based on its condition. If you look at your AS as a "long term investment" that you want your kids and grandkids to experience, this will be money well spent.
As for security, if stored at home or a commercial facility, take precautions to keep someone from hooking up to it and driving away. Don't assume a simple padlock will be a deterrent. Use a high quality coupler lock that inserts into the coupler and has a hardened bar that wraps over the top. Also, as crazy as this sounds, consider removing any valuables (TV's) and leaving the door unlocked. We have several customers who came to us because their RV's were broken into and the only thing that was taken was the TV. Several thousand dollars damage for a $100 tv.
If storing at a commercial facility, make sure it is secure and the operators care about what they are storing and are not just storing RV's because they have extra space and need the extra income.
Basically, it comes down to three things; what you can afford, how long you want to keep the AS and how much maintenance you are willing to perform.
04-24-2018, 08:21 PM
#59
2018 30' Classic
Jacksonville
I store in an RV port cover at the house. We buy houses with space to store our toys and match the toys to the parking space. HOA is never part of the mix.
ps.........I don't winterize any more. We're in Florida. Winter is the time to go.
06-06-2018, 02:01 PM
#60
2018 25' Flying Cloud
St James
, New York
Hi my question is I would like to store my 2018 flying cloud along side of my house, there are many pines trees in that area. I have been keeping it in a storage area wide open area.No trees. Any Idea.Tks
