Old 10-24-2013, 09:43 AM   #15
Moflash's Avatar
2007 28' International CCD
Springfield , Missouri
I use a 12 volt portable jump box with compressor, works just fine let a little pressure build up and open faucets one at a time
Old 10-24-2013, 09:59 AM   #16
John&Vicki's Avatar
1990 25' Excella
Sisters , Oregon
Originally Posted by Howard L. View Post
I spoke with the knowledgeable owner of a large RV shop here in Central Oregon and this is what he uses. I went in to buy an adapter for the compressed air approach and he went over the pro's and con's of the two methods with me. He said that he uses his rig all winter here - we can get sub-zero temperatures - and winterizes 5-10 times a year. Says he uses this device, never uses compressed air, and that it takes him less than 10 minutes to winterize. Parks outside and has never had a problem in 10+ years.
Poppy
John & Vicki
WBCCI #4291
Grown men don't need leaders. ~ Edward Abbey
John&Vicki is offline   Reply With Quote
Old 10-24-2013, 10:43 AM   #17
Moflash's Avatar
I do both blow out water lines with air and fill lines with antifreeze.... takes 15 extra mins
Old 10-24-2013, 10:45 AM   #18
Ready-to-Travel
pmclemore's Avatar
2012 30' International
Walkerton , Virginia
I use the antifreeze approach.
I also agree that when you are facing barely freezing temperatures, you should not worry too much.
Pat
Somebody, please, point me to the road.
AIR 3987
TAC VA-2
WBCCI 4596
pmclemore is online now   Reply With Quote
Old 10-24-2013, 11:06 AM   #19
1996 28' Excella
Mobile , Mississippi
Originally Posted by Nomadic1 View Post
Unfortunately I can't leave my property in the ozarks quite yet.
(it's saposto get down to 31 tomorrow night)
I'm not worried about that tomorrow night as I'll keep the catalytic heater going to keep myself warm.
But.... I'm off the grid. No water, and no power except hauling and solar/geny.
So... It's going to be hard to use compressed air to blow the lines... (I've got a 12 volt air compressor, but don't think that will work.)
I need to stay here a couple more weeks. I can deal with camping dry, (although it will suck not to have the toilet at night) just don't want broken lines.
And unfortunately I can't haul it out to go somewhere local to winterize it at the moment.
Suggestions?
Just drain the tanks and run antifreeze through and then drain the pump? Or...?
Pat
Thank you.
I'm just paranoid about hurting my baby.
I wish the manual was a little more specific, and user friendly...
I thought the furnace was The AC/heater from reading the manual.
(needing 3500 watts)
From an earlier post in this thread I saw the bit about running the furnace... And ran it for a few minutes. (also found the bit about it running the batteries down in a couple nights, and the furnace heating the pipes/tanks))
So tonight Ill run it on 60 (I've got a good sleeping bag and can deal for the couple more weeks I need to be up here)
And hook it to the geny tomorrow night if the solar doesn't bring it back during the day.
I just REALLY don't want to be disassembling my home to get to pipes!
Nomadic1 is offline   Reply With Quote
Old 10-24-2013, 03:49 PM   #20
RangerJay's Avatar
2002 19' Bambi
Northwestern Ontario , - on the backside of the map and just above the big green spot
Images: 44
Just to add a little bit of food for thought for you.
We have done a fair bit of late fall camping (it is our favourite time of year) in sites without electricity where overnight temperatures will dip below freezing. The furnace is a battery killer - and this needs to be managed around - our trailer is small (a Bambi) with a single battery.
Our normal routine under these circumstances is to go into "energy conservation mode" which simply means we don't waste any battery power - we try to time the activities that might have a larger draw on the battery to take place when the generator is running. When we go to bed I work to have the battery showing a voltage of 12.6 or higher.
Overnight we turn the furnace down low as you are suggesting and throw on an extra blanket (my job to get up first - turn the furnace up - and get the coffee going). After one nights draw on a frosty night the morning voltage check will rarely show battery voltage of 12.2 or less (once the coffee is on my next job is to fire up the generator).
If I can run the generator every day the usual minimum times are an hour in the morning and an hour in the evening to keep the battery topped up. I've found that when I can't meet that minimum generator time (i.e. weather or schedule) the battery will give me a 2nd night - but I wouldn't want to bet on a 3rd.
I have no idea how solar charging would work into this - but would think that keeping an eye on your batteries voltage will guide you.
And finally - propane use goes up a lot when the furnace is in regular use - I can go all summer without emptying a tank - but during cold-weather camping it is not uncommon for us to go through a tank a week.
Hope this helps.
Good luck,
Jay
Bambi - 2002 (The Toaster)
Pathfinder - 2009 (The Buggy)
"I'm not young enough to know everything ....."
(Oscar Wilde)
RangerJay is offline   Reply With Quote
Old 10-24-2013, 06:52 PM   #21
1996 28' Excella
Thank you very much for the thoughts.
A tank a week for a couple weeks I can certainly stand.
I'm developing an offgrid property with a metal building which will have living space, and serve as a large garage for my airstream... A few things are undone till I'm at the "pause for the winter" point, and I just can't leave quite yet.
I've got the typical pair of 30's, a pair of 20's I throw into the rotation, and a 100 pounder that sits as a reserve (not putting in the building's propane tank till the spring).
I don't use much juce except during the day to recharge my iPad, phone, and laptop. Already put in LED's etc.
(as I sit here in my wool coat and watch cap)
Not worried about me, 8 years as a Grunt... As I said, just worried about my stream.
Thank you all. I bought 3 gal of antifreeze today, and will be picking up a adaptor shortly if it becomes necessary.
Old 10-24-2013, 08:31 PM   #22
2013 25' Flying Cloud
Rosemere , Quebec
I always use antifreeze I do it every week-end with the FW, but with my old tt i had to to push on the pressure valve of the city water connection.
What do you do to have antifreeze in that pipe ?
Christian
2013 FC 25 B
F-150 ECO BOOST
WBCCI 20130
TAC QC-2
Pitou49 is offline   Reply With Quote
