Old 01-13-2009, 04:12 PM   #1
Whirlaway's Avatar
2008 27' Classic FB
Anytown , Massachusetts
How to clean road salt and spray off underbody of AS?
Any suggestions on how to remove the road salt and spray from the underbody of the AS? Living in the Northeast - New England this is a constant problem from November to April.
I was considering the self serve car wash but I think the number of quarters needed would be huge.
Thanks in advance
Life Is Not A Dress Rehersal
It's okay to have too much fun
WBCCI #8701* TAC MA-1 * NEU UNIT
Gracie...A Liver & White GSP
Get busy livin', or get busy dyin'." - The Shawshank Redemption
Whirlaway is offline   Reply With Quote
Old 01-13-2009, 04:15 PM   #2
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
I would simply wet it down, get one of those telescoping washing thingies (professional term), soap it up a bit and rinse it off. I don't think you need to have high pressure...in fact I'm pretty sure higher pressure will force it's way into the underbelly.
Old 01-13-2009, 05:53 PM   #3
Kevin245's Avatar
I suppose you fashion a pvc spary bar and hook it to your garden hose. Then pull the trailer over it. Place a couple of 2x4's beside the pipe where the tires cross.
I agree that you should keep the pressure low to avoid pushing water in to places you don't want it.
We always use cold water to rinse road salts off the motorcyclee. Not sure that it makes much difference but the owner's manual says not to use warm, or hot water.
Eleanor Roosevelt
Old 01-13-2009, 06:11 PM   #4
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
The thingie would work especially as it would permit the use of soap. Salts will be mixed with dirt and unless you get the dirt off, the salts will remain. There are thingies that attach to garden hoses and ones that are without. We bought a cheapo plastic one—perhaps at Camping World—and it started to fall apart after a few uses at the movable joints at the end parts. I fixed it with a drill and nuts and bolts, so it'll last a while longer. I'd suggest getting better quality than I did.
There are small power washers available that don't have much pressure and that maybe an alternative. However, I'm unsure how long they last. The medium size Delta one I bought several years ago—I think it's 2,700 psi—was poorly made. They replaced the wand on warranty; I replaced the junky hose. Eventually I'll get another brand wand. Anyway I would never direct 2,700 psi on any part of the trailer—it's not like a car or truck. I crank it down a lot or use a garden hose.
The suggestion about using cold water makes sense—hot water dissolves salt crystals into a solution that can be driven into things where the crystals wouldn't fit.
And, salts live on all year, I think. The crystals get ground into the pavement and the spray gets into the dirt alongside the road. When it rains the salt solution comes back like a zombie to attack. When the road gets wet, note the white solution on the pavement for a while. They use a lot of mag chloride here in Colorado; I don't know whether the rock salt used in the NE acts the same way, but I would think salt is salt. There is no escape.
Gene
Old 01-13-2009, 09:44 PM   #5
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
There are RV brushes that feed water thru the handle. That'd be my choice.
Hensley Arrow. 9-cpm solo, 15-cpm towing
Old 01-14-2009, 07:39 AM   #6
Whirlaway's Avatar
2008 27' Classic FB
I appreciate the ideas for getting rid of the salt.
I do have a brush that sprays water out. I will try that first and I did not know hot water would be a problem. That's why I enjoy posting questions here! There is so much knowledge on this board.
Thank you.
Ocean Salt Exposure henw Cleaning, Stripping & Polishing 3 05-27-2008 09:24 PM
Hello From Salt Lake City CH53 C/C Member Introductions 4 04-19-2007 12:41 PM
What about seaside salt air? 26.982 amu Winterizing, Storage, Carports & Covers 26 01-31-2006 08:40 AM
Need mentor in Salt lake city! please!! ob1coby General Repair Forum 2 06-28-2004 07:20 PM
Underbody repairs raebaker06 Belly Pans & Banana Wraps 2 08-20-2003 01:45 PM
