Old 11-07-2019, 10:31 AM   #1
1976 31' Sovereign
Terre Haute , Indiana
How to bypass hot water heater in 1976 31' Sovereign
The last 2 or 3 years when I've winterized my Airstream (76 Sovereign 31' with rear bath), I have never been able to figure out how to bypass the water heater, so I end up filling the darn thing with 10 gallons of antifreeze to get water everywhere.
There is only 1 valve for the water heater (in the little closet next to the toilet) and I'm not sure what it does but it doesn't seem to bypass anything. The manual just calls it a water heater valve, not a bypass, and most bypasses I'm familiar with have 3 valves.
So am I missing something? Is there a way to bypass it?
thanks!
Clay
ClayDC is offline   Reply With Quote
Old 11-07-2019, 10:37 AM   #2
1981 31' Excella II
New Market , Alabama
It probably did not come with a bypass like the newer trailers. If it does it would be right next to the heater. This is assuming you can get to the back side of the heater. I am not as far north as you but blowing out the lines and putting some antifreeze in the P traps seems to get it done. There is a drain plug on the heater usually made of some plastic like Nylon. Remove that and drain the heater then replace it and blow out the lines with air. All faucets, shower, toilet valve should be purged. Do them one at a time and give the air compressor time to catch up. Set the pressure on the air compressor no higher than 60 psi. Get you one of these.
https://www.amazon.com/Winterize-Mot...s%2C180&sr=8-1
Perry
Old 11-08-2019, 11:47 AM   #3
1976 31' Sovereign
Ok that's what I was thinking. Looks like I'll try to add a bypass in the spring. I went ahead and filled the system up again last night!
thanks!!
Clay
Old 11-08-2019, 12:50 PM   #4
Beverly Hills , California
Check this out:
https://www.airstream.com/wp-content...manual-137.pdf
See if page 37 matches what you are seeing. For step 9, I'd go with the pink stuff instead of Glycol.
Or, take a look at page 43 in this one:
https://www.airstream.com/wp-content...-manual-56.pdf
The previous one was for the Excella, although the winterization steps look the same.
JayTheCPA is offline   Reply With Quote
Old 11-09-2019, 10:50 AM   #5
Villa Park , Alabama
If it's ten gallons, isn't that a replacement hot water heater? I also have a 76 Sovereign with a dual-fuel water heater, but it's a very newly installed item. I also did not have a bypass. 10 gallons of the pink stuff just ain't cheap.
drmox is offline   Reply With Quote
Old 11-09-2019, 03:19 PM   #6
r carl's Avatar
Lin , Ne
You install a bypass kit similar to this.
https://www.ebay.com/itm/RV-Camper-T...ty!68521!US!-1
Old 11-09-2019, 03:26 PM   #7
Trnpk Crsr's Avatar
Baltimore , Maryland
Mid 70’s Airstreams came with 10 gallon gas hot water heaters. They did not have by pass valves.
Trnpk Crsr is offline   Reply With Quote
sovereign
Hot Water Heater Bypass Valve Access donreitz 2009-2015 Flying Cloud 2 03-17-2018 07:25 PM
Accessing the hot water heater bypass curmugeon Sprinter and B-van Forum 5 06-22-2016 12:44 PM
Hot Water Heater Works But No Hot Water Althea Water Heaters, Filters & Pumps 6 04-16-2016 10:45 AM
'86 sovereign water heater bypass Ssmookler Water Heaters, Filters & Pumps 1 11-17-2015 01:54 PM
Help, no hot water heater bypass in my 1975 31' Sovereign ShinyTwinkie Winterizing, Storage, Carports & Covers 5 11-30-2008 06:52 PM
