He he I just realized what the title looks like I'm asking.
Really though, the rainy season is coming and we are missing a window and the back access door, if that's what you call it. We can cover those up, but I'd like to put a cover over the trailer or string a tarp over it so we can still work on it. Does anyone have any recommendations on covers or ideas to keep the rain out? Storage isn't an option. What's worked and what hasn't? Pictures are always good! Is there a brand that we can get?
thanks
ingrid
1967 24' Tradewind #19104 ~ Forums #4449
thanks
Sheez...the rainy season hasn't let up here Check out stefroberts pictures she has/had a nice temporary cover. It basically looked like a poly tarp over a steel frame. Unfortunately mine just sits out in the middle of the back yard with plastic taped over any open holes. It is either work on the airstream or build a shelter....what a choice.
Aaron
WBCCI #2449 AIR #2495
Vintage units aside, I've read several times here that you don't want to place a tarp or cover on an Airstream, particularly the newer ones since it can cause damage to the shell coatings. Keep in mind I have no direct exp with this, just passing on what I've read here. It could also apply to the vintage units as well, but I doubt it. Do a search.
Hi Dave, I use one of the ClearSpan round top buildings for my showroom in Quartzsite and I can vouch for their high quality. The vinyl covering is extra thick giving it durability, the frame is plenty sturdy, and the center skylight is a big plus. It really lights up the interior. The only drawback is the dark green outside color. In Southern climates, it can get plenty hot in the summer sunshine. As for sturdy frame, we had wind/sand storms last year in Quartzsite with winds in excess of 55 mph and our building was steady as a rock with virtually no flapping. Other buildings were disintegrating! The only crimped metal building self distructed. Outside it looked like the pictures of the hurricanes in Florida, only thing it wasn't rain moving horizontal at 50+ mph, it was dirt!
When their website opens, select Shop Online, then go to page 337 to start.
The key to any of the fabric buildings is to anchor them securely!
This looks like a beefier version of the CoverIt product. Looks like a good warranty, too. I guess my only question would be what one would do after 15 years and a good 'ol Texas hailstorm?
Cheers, Dave
"Finish." AIR #4188 1994 34' Limited / 2002 Chevy 3500 CC 4x4 D/A Equal-i-zer Hitch / Jordan Ultima 2020
Aaron
Yeah our rainy season is actually "sprinkle" season to most of the US. I'll check out her pix.
ingrid
Mine is a vintage. no shell coating that isn't already going to come off...but it's good to know that. I'll still look into it.
ingrid
I have had mine for one year, and my CCD is not covered. I wish I had a building for it though. I too fear that drapeing it with a cover might do more harm than good. My biggest fear is hail!
May mother nature continue to smile on Airstreams.
I made a pole barn from 3 different sources. One is just regular 4x4 treated posts (10 of them). Second is 5-v crimp galvanized roofing in 16 foot lengths, and third is the vinyl covered garages that Sam's Club etc. sell.
This 3rd componet is 1 1/2 inch tubing that forms the framework of the roof. I discarded the vinyl tarp and used the galvanized roofing folded over the top. The tubing is inserted into the 4x4 post in a 3" deep hole drilled in the top and anchored by cross bolts.
It has proved very sturdy in the last 4 hurricanes in the last 6 weeks. None were direct hits, but we got lots of wind in the 40-50 mph range.
Sorry I don't have a digital camera to show it off with (yet)!
PM for better details.
You wouldn't want to just "cover a vintage one with a tarp" either...the movement in the wind, however slight, will scratch the aluminum, especailly if it's polished!
Whatever protective covering you use should be held away from the surface of the trailer and be secured carefully.
Shari
Hi Dave, the ClearSpan fabric buildings probably have about a 5-7 year lifespan on the fabric covering. And, you can order replacement covers thru FarmTek. You may find better prices in the closeout section of FarmTek's catalog. Farmtek has a clearance center called Scroungecentral.com and I picked up my showroom which is 14x24x10 for about $480 plus about $120 freight. As for hail storms, I've been in one in Austin and it was down right scary. Hail the size of softballs was breaking out car windows and going right thru convertible tops.
The affordable protection against against hail damage is one of those metal covered carports you see advertised along the road. That's what I have here in Corpus Christi. I went to one of the dealers got the name of the manufacturer in Victoria, then went to the manufacturer and told him I wanted a longer, taller model. I wound up buying the frame thru the dealer, then purchased metal panels to go on it from a company here in Corpus Christi. I wanted a better quality metal panel, and I wanted a green color and was able to order them at a local steel company. The same panels are regularly available from Mueller Supply or other metal building supply company. For a square tube frame for a 14x22x11 I paid about $650 and the metal wall panels were about $800. The hardest part was handling the long wall panels to get them up. Its been up about 4 years and is holding up well.
Again, anchorage is very important and using plenty of those self-drilling screws when attaching the panels is key to keeping the wind from taking it away.
Enjoy!
Yeah, that's basically what I ended up getting. Poured a 20.5x40.5 concrete slab, and got a 20x40 building that a company out of San Antonio is installing for me. It'll be 12' at the apex, which gives me plenty of wiggle room up top. Plus it will be wide enough if I need to open the awnings while it's in there.
It hopefully will be here and installed by Wednesday evening, so I can bring the Limited home from the covered storage I've been renting for it. Otherwise (gasp!) it might have to sit out in the open! Perish the thought!
Cheers, Dave
thanks
Ingrid, check out temporary RV covers. They cost from $300.00, and have a vinyl cover, and aluminum frame, usually are around 12ft tall.
Here is the dealer's name/address, & email:
Greene Frogge Shelters
1222 S. 38th St.
Tacoma, WA 98418
Phone (253) 472-3704
Fax (253) 475-1194 froggy@nwrain.com
No price given on their website.
