Old 10-05-2014, 11:03 AM   #1
1991 29' Excella
Rockwood , Ontario
Help!! Antifreeze Leaking Out of Bottom of Trailer
Oh Boy!! First time trying it myself…a problem of course. Drained out all tanks, open outside petcock and drained whatever it drains. Mistake I made, and not sure, are the two valves inside the trailer on 2 grey plastic hoses to the front of the roadside wheels. Am I supposed to do something with them, and which way do I turn them?
This is what happened….got antifreeze ready, put pump on, went to jug number three, then turned on kitchen tap, it ran pink, then hot water kitchen tap, it ran pink, then started turning clear. We stopped everything, and someone went outside, and the antifreeze was leaking out from the underside of trailer in many spots. Looked under kitchen sink and saw pink stuff in the lower section.
What happened and how do I fix it?? I have a feeling it's off to the dealer for winterizing and storage…I am really upset
breezyway is offline   Reply With Quote
Old 10-05-2014, 11:10 AM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
If you are seeing antifreeze under the sink and several places under the trailer I have to ask did it freeze before you got around to installing the antifreeze?
Did you blow down the system first? I use 3/4 of a gallon of antifreeze. Why do you have 3 jugs, Canadian measurements? Do you have a hot water bypass and did you close it before adding antifreeze?
2004 Excursion 4x4
Old 10-05-2014, 11:18 AM   #3
1991 29' Excella
Rockwood , Ontario
Not Freezing Yet Here
Ok, I did not blow out the system, and I did this method last year, with no trouble that I know of. Last year we used 4 1 gallon jugs.
Do you think it had something to do with the grey valves??
Old 10-05-2014, 03:07 PM   #4
HowieE's Avatar
Images: 12
If you used 4 gallons you do not have a bypass on the hot water heater or you did not use it.
Get and use a bypass.
In Canada you are going to have to blow the city connection or you will have water trapped in that leg and the metal regulator will crack.
Before you go much further I would get an air adapter to the city water connection ad pressurize the system. You will hear any leaks. Fix them before going any further. And don't forget antifreeze in the traps, about a 1/2 pint.
2004 Excursion 4x4
Old 10-05-2014, 04:01 PM   #5
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
My system takes 2 full gallons to winterize. And the water heater is bypassed. Plus, I add about 1/2 gallon to each of the grey and black tanks. So a total of 3 gallons.
Hot Water tank leaking on bottom cuckooman Water Heaters, Filters & Pumps 15 05-31-2009 11:32 AM
Winterizing-Adding Antifreeze JaceBeck Winterizing, Storage, Carports & Covers 13 09-25-2003 04:45 PM
Freezing RV Antifreeze Raptorrider2001 Winterizing, Storage, Carports & Covers 1 01-13-2003 01:33 PM
RV Antifreeze Quality jcanavera Winterizing, Storage, Carports & Covers 8 11-27-2002 03:32 PM
Can I use "regular" antifreeze in my holding tank? Luckydog Airstream Motorhome Forums 6 11-25-2002 07:01 AM
