11-19-2013, 03:45 PM
1969 23' Safari
Athens
, Georgia
Haven't run water in trailer yet-winterize?
I am in the final stages of renovating my AS and have never run water through her. I have an empty, fresh holding tank, water pump, toilet not in yet, bath not been used, never hooked up to outside water while working on her. Stupid question-is there anything I need to do to winterize?
11-19-2013, 04:11 PM
Alamo Heights
If there's no water in any pipe or tank, there's no winterizing to be done.
David
Zero Gravitas 2017 Flying Cloud 26U | WBCCI# 15566
11-19-2013, 04:13 PM
1972 31' Sovereign
Lexington
If there's never been any water in the system, you don't need to winterize. Chris says that nothing will freeze until it gets to absolute zero, in which case we will have other problems!
Kay
11-20-2013, 06:58 AM
1969 23' Safari
Athens
, Georgia
That's what I figured, but wanted to be safe, not sorry. Thanks!
11-20-2013, 07:39 AM
retired USA/USAF
2001 30' Excella
Somerset
, New Jersey
Close the door !!!!! That's about it.
Does it get cold in Georgia ????
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
11-20-2013, 07:45 AM
Princeton
, New Jersey
YOU have never had water in the trailer. The 69 Airstreams used copper pipe, copper is not as forgiving as plastic, and unless you replaced all of the piping and are sure there is no way any water could still be in there I would at least blow air through it, opening each faucet one at a time, to be sure.
2004 Excursion 4x4
11-20-2013, 07:50 AM
Figment of My Imagination
2012 Interstate Coach
From All Over
, More Than Anywhere Else
Some antifreeze added to the holding tanks would not be amiss, either. Even if the tanks are dry, keeping the valve seals wet with antifreeze now may prevent leaks later. Propylene glycol isn't as good for restoring rubber as is glycerine, but it's better than nothing.
11-20-2013, 10:05 AM
1976 25' Caravanner
Salt Lake City
, Utah
This may be a dumb "newbie" question but how much antifreeze do you advise adding to the holding tanks. My recently purchased '76 Caravanner has empty tanks. I've blown out the water system and added antifreeze to the sink and tub traps and poured a little down the toilet to moisten the seals. Just curious as to how much more in the gray and black tank would do it. Thanks.
11-20-2013, 10:14 AM
From All Over
Doesn't take much. Just enough to cover the seal. You can always add more later if it evaporates. But I can't give you an exact quantity because the gemoetry of each system is different in the particulars, even if they're generally the same.
11-20-2013, 01:55 PM
Princeton
, New Jersey
You can not drain all the water out of the gray and black tanks just because of what is on the bottom and side walls of the tanks. So evem after a good draning you can assume water will migrate to the low point, the drain valve. I put about a cup of auto antifreeze in those tanks just to be sure ice does not effect the valves
2004 Excursion 4x4
11-20-2013, 02:45 PM
1976 25' Caravanner
Salt Lake City
, Utah
I'll pour some antifreeze into those tanks tonight! Thanks much, gentlemen.
11-20-2013, 05:08 PM
1972 31' Sovereign
Lexington
If you're concerned about evaporation of antifreeze in the toilet, do what I do. Cover the toilet seat with plastic wrap to seal it after the antifreeze is in the toilet. It'll be good for the winter with no evaporation.
Kay
11-21-2013, 03:38 AM
1969 23' Safari
Athens
, Georgia
Copper has been replaced with Pex. Faucets haven't been put in, yet. I'm pretty sure there is no water lying around, just more so about lubricatin whatever to keep thin dogs from getting brittle.
11-21-2013, 03:45 AM
1969 23' Safari
Athens
, Georgia
It can get to about 10 degrees at the coldest. Were in north Georgia. I could run a small space heater in there on those nights-no propane on-AND keep the doors closed
New black tank, BTW, no water in it. I think that I will but some antifreeze in the sink and toilet. Wait, I don't have a toilet, yet! Lol
11-21-2013, 03:47 AM
1969 23' Safari
Athens
, Georgia
Thin dogs from getting brittle?!! Thanks auto-correct. I meant things from getting brittle.
